Old May 29th, 2017, 06:37 PM   #1
ROB654
Motorcycle(s): 08 NINJA 250,EX500,YSR50,86 VFR750
Track build
I started working on my track build again. I got most of the parts in for the build. It's a 2008 Ninja 250. I'm setting it up for track days and racing. I haven't raced in many years. I've been really missing being on the track.
I'll take any input or helpful thoughts with this build
ROB654 is offline   Reply With Quote
Old May 29th, 2017, 06:46 PM   #2
ROB654
Here's what I got done so far. I put in a set of tapered steering bearings, Factory shift detent and remove a lot of weight saving non needed stuff
Old May 29th, 2017, 07:06 PM   #3
Old May 30th, 2017, 04:39 AM   #4
Here's what I've done to mine.
- Woodcraft clip-ons
- Woodcraft rearsets
- TrailTech Vapor gauges
- Hotbodies bodywork
- Galfer SS brake lines
- Galfer disks
- Shaved kickstand bracket (no highsides allowed)
- Tyga full stainless exhaust system
- Motionpro Rev2 throttle set
- 428 chain and aluminum rear sprocket (sprocketspecialists.com)
- K-Tech rear suspension
- Progressive front springs with gold cartridge emulators
- Barnett clutch and springs
- Fully safety wired
- TechEdge wideband for tuning
- DynoJet tuning kit
I need to review the rulebook, but I believe I'm allowed to increase compression. So in off-season I'll rebuild engine and put in some 12,5:1 pistons.
Old May 30th, 2017, 04:47 PM   #5
ROB654
Latest additions to build
Aluminum fairing bracket
Blue aluminum oil fill cap
Woodcraft ignition elimination harness
Old May 31st, 2017, 04:27 PM   #6
dustinang87
Motorcycle(s): Ninja 250r, Ducati 1098, Honda Grom
where did you pickup that fairing bracket from?
dustinang87 is offline   Reply With Quote
Old May 31st, 2017, 05:00 PM   #7
ROB654
I what to say eBay a few years ago. But let me see if I can find any paper work on it
Old June 2nd, 2017, 02:36 PM   #8
ROB654
How much should I drop the triple clamps. What should the measurement be from the top triple clamp to the top of the fork tube?
Old June 2nd, 2017, 04:56 PM   #9
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
About 12mm for stock. Salt to taste once you get on the track.
Dave Wolfe is offline   Reply With Quote
Old June 5th, 2017, 10:22 AM   #10
I have 15mm drop on mine with the pre-load adjusters 2 full-turns in. I weigh 82 kg.
Howlinhoss's Track Build howlinhoss Ninjettes At Speed 38 August 18th, 2015 06:34 AM
2010 Track Build Floki 2008 - 2012 Ninja 250R Tech Talk 57 June 24th, 2015 12:34 PM
08 Ninja 250 track build ROB654 2008 - 2012 Ninja 250R Farkles 10 May 14th, 2015 08:32 PM
08 r6 Track/Race Build csmith12 Pictures 48 May 3rd, 2015 08:34 PM
Need help with Track build jmk420 Ninjettes At Speed 35 June 24th, 2014 05:59 PM
