Old July 23rd, 2017, 11:00 AM   #1
///M
Motorcycle(s): 94 Ninja 250
No Start
Hi all, first post here. Recently picked up a non-running 94 250 that has supposedly sat for 2 years.
I have gotten it to run a couple times (not with starter, but with bump starting and a push from a friend). It will not start just with the starter.
When I was able to get it to run, it would die anywhere below 2000 rpm. Also the idle would hang quite often until I messed with the idle set screw (leaning out maybe?) Carbs were cleaned by the previous owner. And today I have not been able to get it started yet.
Things I have done so far is new spark plugs (NGK CR8HSA), fresh oil, checked spark (although seemed weak. Resistance of the coils were both 3.1ohms).
Also now it seems to be stuck in 1st gear. It feels like it goes into neutral (and can click back down into what would feel like 1st), but it is still stuck in gear. I know I am not in a higher gear because I haven't had it in 2nd gear as of yet. I've tried rocking the bike back and forth to get it into neutral but have not had any luck.
Last futzed with by ///M; July 26th, 2017 at 11:39 AM.
///M is offline   Reply With Quote
Old July 23rd, 2017, 11:10 AM   #2
My first guess is that the idle circuits in your carbs are clogged from sitting, and the previous owner missed curing that when he cleaned them.
Could your transmission trouble be related to the feature of this transmission that helps you find neutral? When the bike is stopped, you can go from neutral to 1st and back to neutral, but not past neutral to 2nd until the engine is running and you're moving. You should be able to get it into neutral by moving the bike back and forth a little though. From 1st gear, lift the shift lever up all the way firmly, which would get you into 2nd on most bikes, and it should go into neutral.
Welcome to the board, Jon!
Old July 23rd, 2017, 11:13 AM   #3
///M
I'll pull the carbs and clean them tonight.
As far as the transmission goes - I am unsure. It feels like it normally would for shifting from 1st to neutral for vice versa - just it will stay in 1st. It doesn't feel like there's a lockout like if you try to go to 2nd. In days prior I haven't had issues with it.
Old July 23rd, 2017, 12:10 PM   #4
See what the transmission does when you have the engine running after the carb clean.
Old July 23rd, 2017, 01:17 PM   #5
///M
Will do, I will report back this evening.
Old July 23rd, 2017, 07:22 PM   #6
///M
No luck tonight.
Cleaned the carbs (were very clean) and adjusted the floats - adjustment was a few mm off.
Tried to start it and didn't seem to have fuel getting to the cylinders. Once the float bowls filled with fuel, I didn't see any gas more gas moving through the filter.
I've checked for vacuum leaks (and am 95% sure all vacuum lines are connected). Did not see any cracks or obvious leaks when the carbs were out.
Old July 23rd, 2017, 11:05 PM   #7
NaturalFlavored
Motorcycle(s): 250r
Is the chock on or off?
I've found. out if the chock is all the way on but when your taking it off it dies, due to the idle screw isn't set right.
If you suck on the vacuum fuel line does fuel flow constant? Be sure 100% there is no vacuum leaks, I've worked on a carb scooter and it had a lot of issues if there was any air leaks.
Valves ok too?
NaturalFlavored is offline   Reply With Quote
Old July 24th, 2017, 04:32 AM   #8
///M
Valves ok too?
I've tried with the choke off, half on, and full on. Same result with either setting.
As far as valves go, I'm going to do an adjustment today or tomorrow. I didn't have a set of feeler gauges that were small enough, so I'll be picking up a new set. Maybe a compression check should also be next on the list?
Old July 24th, 2017, 06:15 AM   #9
As far a the running issue, I would remove the air filter and give it a quick shot of starter fluid before cranking to see what it does. Make sure you are charging the battery between attempts. If it sputters to life you know almost certainly that you have a fuel-related issue. Did you check the inline filter inside the fuel line at the carb inlet for a blockage? You may need to have the carbs professionally cleaned and adjusted. There could be an issue with the carb diaphragms also. Pull the fuel line, apply vacuum to the petcock, and confirm flow.
For the transmission, I would make sure you have gotten it into 1st gear. Keep tapping down while rocking the bike forward and back. It would be odd if it were stuck in gear and wouldn't change. I'm thinking it may not be in 1st, and you are clicking up looking for neutral from a higher gear.
Old July 24th, 2017, 09:09 AM   #10
///M
It does not fire up or even try to kick over when spraying starting fluid.
I've verified that it does have spark on both cylinders.
Old July 24th, 2017, 09:48 AM   #11
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
time for a compression test
Old July 24th, 2017, 10:03 AM   #12
It would be really odd that it doesn't pop at all if there is spark.
You may need to open the throttle while cranking to allow the Starter Fluid to get past the closed butterflies.
Last futzed with by jkv45; July 24th, 2017 at 02:59 PM. Reason: typo
Old July 24th, 2017, 02:32 PM   #13
///M
You may need to open the throttle while cranking to allow the Starter Fluid to get bast the closed butterflies.
Already tried that as well.
Old July 24th, 2017, 04:22 PM   #14
What colour is the spark that you saw when testing?
Was it yellow/red?
Or white/blue?
Old July 24th, 2017, 04:25 PM   #15
///M
Was it yellow/red?
Or white/blue?
White.
Old July 25th, 2017, 06:25 AM   #16
I dunno. At this point I would plan to pull off the carbs and go through them.
If you have spark, the carbs are going to be the main focus.
Old July 25th, 2017, 06:31 AM   #17
///M
Already had them apart. Floats needed adjustment.
Also got the transmission back into neutral after playing with it for some time.
Old July 25th, 2017, 11:16 AM   #18
Did you look at the diaphragms? I still think there's something not right.
Good to hear you got it into neutral. Hopefully there's not a significant problem that keeps it from doing it when needed.
Old July 25th, 2017, 11:34 AM   #19
///M
Diaphragms looked brand new, and slid up and down easily.
Old July 25th, 2017, 11:46 AM   #20
Hmm...
You removed the Main Jet and Jet Holder/Needle Jet and cleaned them, right?
Old July 25th, 2017, 11:52 AM   #21
///M
Hmm...
Correct. Everything was torn down and cleaned out.
Old July 25th, 2017, 12:49 PM   #22
ducatiman
ducatiman's Avatar
What methods did you use to *clean the internal passageways and circuits?
And how did you confirm each circuit was, in fact, *clean?
Did you also address the starter circuit?
*IMHO a better term is actually *clear*
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old July 25th, 2017, 06:43 PM   #23
///M
I'll shoot you a PM sometime soon.
I did a quick oil change and it was chocolate milk. Did a leak down test and found the headgasket was leaking. Pulled it apart, and it was leaking between the cylinders, as well as from one of the water ports.
Already took it to the machining shop at my college, and the head is true and not warped. Same story with the cylinders.
Old July 29th, 2017, 12:59 PM   #24
///M
Got it running today! Fired right up, runs fantastic now.
Old July 29th, 2017, 01:37 PM   #25
That's great news! How is the transmission shifting?
Old July 29th, 2017, 04:03 PM   #26
///M
Smooth as butter through all gears! Rode for a few hours this afternoon and had no issues whatsoever.
Old July 29th, 2017, 04:08 PM   #27
Excellent.
Old July 30th, 2017, 11:48 PM   #28
Ram Jet
Ram Jet's Avatar
I'd be careful with the starting fluid, it's been said that that stuff will ruin your diaphragms.
Bill
Old July 31st, 2017, 06:22 AM   #29
Bill
I haven't heard that, but it's nasty stuff.
I only use a small amount of it if I need to confirm there's a fueling issue. I've had temperamental engines start right up with just a tiny shot, and not need it after that.
Definitely don't ever spray it until it drips - just a light shot is all you should ever use.
Old July 31st, 2017, 08:17 AM   #30
Ram Jet
Ram Jet's Avatar
I was just passing on what our resident carburetor Guru Ducatiman said. Glad you're not using much of it.
Right Dukemeister?
Bill
Old July 31st, 2017, 08:47 AM   #31
///M
All I did was take the plugs out and spray a quick shot into the cylinders. No worries about the carbs
Old July 31st, 2017, 09:05 AM   #32
Ram Jet
Ram Jet's Avatar
Excellent and good thinking.
Bill
Old August 10th, 2017, 06:57 PM   #33
///M
Hey guys, couple issues I've had over the past few weeks of riding (or well, 3 full days of riding as I've been on vacation as of late).
If I'm cruising through town (30mph) or really anywhere below 6-7k rpm (mind you I am just cruising, not accelerating or decelerating) it will begin "bucking" or seem like there may be a misfire (or something of the sorts). Also it idles fantastic when cold (and does not require any choke no matter the ambient air temperature). When hot it'll idle for roughly 5 seconds and drop RPM until it stalls. If I am on the throttle and accelerating through the midrange RPMs it does not have a single issue. It only arises when maintaining low speeds.
Would this be an issues with the carbs? And if it is, would it be an adjustment or would it be dirty idle circuits? Another thought was a possible vacuum leak (going to replace all lines when I get home from my trip, along with fuel lines just for safe measure).
The issues vanished completely after I opened it up getting on the interstate (WOT all the way to redline through 3rd gear) and then returned the next day (and has not gone away since then, no matter how hard or easily I run it).
Gas is fresh (tried with 87 and 93). I'd also like to add that it starts a lot quicker when cold than hot. Cold it'll start with no choke after a couple seconds and idle at 1700rpm. Hot it will take a solid 5-7 seconds of cranking and slight bits of throttle added to get it to go (and then require throttle to keep it idling).
Also would like to add that after 3 tanks of fuel it averaged 55 mpg all tanks of mostly 50mph-ish twisty roads.
Would my float adjustment possibly have it too rich?
Sorry for the long post. Mixture of thinking out loud and questions :P
Old August 10th, 2017, 07:21 PM   #34
NaturalFlavored
Motorcycle(s): 250r
At first I thought carbs or vacuum leak until you said it's better cold than hot.
Heat expands while cold retracts so there must be something else. I'm not too familiar with bikes, I'm not sure how different they are from cars especially with carbs.
Old August 10th, 2017, 07:35 PM   #35
Ram Jet
Ram Jet's Avatar
I would check the pilot air screws. If you haven't already, pull the EPA plugs, unscrew the pilot screws and examine the "O" rings. If they have deteriorated replace them and adjust the screws out from their seat 2.5 turns. It's worth a check to be sure. This will entail carburetor removal if you haven't removed the EPA plugs previously.
Bill
Old August 11th, 2017, 06:06 AM   #36
Sounds carb related to me.
Cleaning, adjusting, syncing, and maybe a shim on the needle should make it run properly.
Because it starts cold better than hot, I think it's getting too much gas. It should need some choke if it's stone cold, and it shouldn't idle that high wihtout any. A vacuum leak is a possibility.
The "bucking" would be another indication that something isn't right in the carbs. Probably too rich, but look at the plugs for clues.
Float height should be checked and idle mixture screws are best set in the range of 2.5 turns out for starters.
When working with carbs, think in terms of throttle position (1/8, 1/4, 1/2, etc) instead of RPMs to get a better idea of which circuit needs adjustment.
Old August 11th, 2017, 06:11 AM   #37
///M
Just for a quick frame of reference - I set the idle high out of personal preference.
I added a couple shims to the needles with no change. I'm thinking I might have adjusted the floats too far? I did a pretty major adjustment (bike was running lean when I tested it previously, and there's a good possibility of me incorrectly measuring the 17mm float height).
Also the idle mixture screws are 3 turns out, I'll try 2.5 turns out. I'll also pull the plugs (when I get home from vacation that is) and see if it's running overly rich, and likely replace them while I'm at it (plug chop might be some good info?)
Bill - o-rings looked brand new when I pulled the carbs apart last.
Old August 11th, 2017, 11:56 AM   #38
If you take the plugs out, you can just put about 1/2 a teaspoon of gasoline in each cylinder and it will work at least as well as starting fluid, which my be half evaporated by the time you get the plugs back in.
Old August 15th, 2017, 07:02 PM   #39
///M
Hi all, lack of reply since I've been too busy riding.
Once I adjusted the floats down to run leaner, the bog is gone. Also after a recent plug change, it is currently at a near perfect A/F.
Old August 15th, 2017, 10:33 PM   #40
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
That's the best reason for being away from the board! Glad you got her going and on the road.
Can't start - stuck in gear Felginator 1986 - 2007 Ninja 250R Tech Talk 25 November 22nd, 2012 06:09 AM
Cannot start in gear. setasai 2008 - 2012 Ninja 250R Tech Talk 6 March 4th, 2012 10:18 PM
Stuck throttle after Area P install & new needles The Blue Rider 2008 - 2012 Ninja 250R Tech Talk 6 July 25th, 2011 09:01 PM
[topix.net] - Motorcycle sales stuck in low gear down under Ninjette Newsbot Motorcycling News 0 May 18th, 2010 05:40 AM
[topix.net] - Motorcycle sales stuck in low gear down under Ninjette Newsbot Motorcycling News 0 May 14th, 2010 10:20 AM
