Old October 17th, 2020, 02:43 PM   #1
SibSerge
Strange piece found in the oil.
Hi everyone,
I have found some piece of metal stuck to the magnet of the oil drain plug today. I checked various diagrams and cannot seem to find anything similar. Do you have an idea where this can potentially come from ? The engine and the gearbox are working just fine. It has a square cross section and seems to be made of a hard magnetic metal. It looks like a cut of a half circle. Thanks in advance.
File Type: jpg 1704C335-5054-49A2-9439-6A4A5468B8CF.jpg (37.5 KB, 13 views)
Old October 17th, 2020, 03:52 PM   #2
ducatiman
ducatiman's Avatar
darn if thats not a bent up hex wrench!
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old October 17th, 2020, 04:20 PM   #3
SibSerge
Its funny but that was the first thing came into my mind ! I though how did the allen key get here
Old October 17th, 2020, 04:59 PM   #4
aliens
Old October 17th, 2020, 05:03 PM   #5
I'd need some more photos, but I don't think that is hexagonal in cross section. The first post even says it's square in cross section.
Old October 17th, 2020, 05:28 PM   #6
SibSerge
Jim it is square, at first I thought it was some sort of spring that broke, but it looks rigid and the edges look cut, not cracked . It could also be some sort of home made stopper pin placed somewhere instead of oem by previous owners or shops. Mistery...
Old October 17th, 2020, 06:47 PM   #7
Kowalski
Kowalski's Avatar
Motorcycle(s): 2014 Ninja 300
Looks like the piece of a helicoil that you punch out after installing it.
Kowalski is offline   Reply With Quote
Old October 17th, 2020, 07:19 PM   #8
SibSerge
Thanks Keith, this seems to be quite possible. I know that PO had the plug hole rethreaded and I did fine alu shavings on the screen before, I wonder if this finding is related. As long as its not part of the engine I am not worried
Old October 17th, 2020, 08:37 PM   #9
Yes, that's what it is! I knew it looked familiar. I though it was bigger than that when I saw the photo, but it's a close up.
Is there a Helicoil in the drain plug thread? That makes more sense than a spark plug thread if you found it in the sump stuck to the drain plug.
Old October 18th, 2020, 03:38 AM   #10
SibSerge
Jim, I will check next time I do the oil change. It’s definitely not from the spark plug area. Both spark plug holes are intact and “original”.
Thanks a lot guys. This has been really helpful.
Old October 18th, 2020, 03:42 AM   #11
SibSerge
BTW to put the size into prospective that red tray in the picture is a cup from a 2 inch moly grease tube
Old October 18th, 2020, 07:24 AM   #12
Kowalski
Kowalski's Avatar
The shavings are from tapping hole to install the helicoil. If your only issue is finding this in your oil I’d say your good. Oil pans are really good at letting stuff fall to the bottom and not cause any issues.
Old October 18th, 2020, 08:54 AM   #13
Yeah, more proof that greasing the tap does not ensure that chips don't get in.
Old October 18th, 2020, 04:20 PM   #14
SibSerge
Thanks Keith, that makes total sense. Yes thats the only worry. Otherwise everything seems to be alright with the engine. I think this winter I will replace the screen cover with the pan from the new gen. Then I will not need to use this drain plug and will be using the one on the pan. I already got all the parts - the pan new gasket and the correct bolts.I just need to figure out the brackets for the fairings. Right now the fairings bracket is bolted to the screen cover.
Found shavings on the oil screen SibSerge 1986 - 2007 Ninja 250R Tech Talk 9 November 18th, 2019 12:40 AM
Strange oil leak after being knocked over achimedes 2008 - 2012 Ninja 250R Tech Talk 3 January 24th, 2019 10:43 PM
Some fun stuff found in oil screen LumaNinja 1986 - 2007 Ninja 250R Tech Talk 3 July 10th, 2018 10:01 AM
Found gasket when cleaning oil screen! Jessevelazco 1986 - 2007 Ninja 250R Tech Talk 13 March 11th, 2016 01:03 PM
Oil Leak, I think I found it but just needing some advice jaustin77 1986 - 2007 Ninja 250R Tech Talk 2 May 11th, 2011 12:56 PM
