Old August 5th, 2010, 08:10 AM   #1
ninja man
ninja man's Avatar
Motorcycle(s): ninja250r , zrx1200r, vfr800, cb1300s.
air filter
just fitted a k & n air filter to help the little ninja breath more easily as iv got a full race system , bit of an improvement in 4th & 5th gear . top speed still 105mph so no change..
overall the bike accelerates better and smoother to red line
ninja man is offline   Reply With Quote
Old August 5th, 2010, 12:27 PM   #2
ScorpionNinja
ScorpionNinja's Avatar
my bike is 100% stock. i also have a k & n air filter too.
how was the fittment of your K&N?
how does the 3 bolts tighten up with the cover once you get the K&N pushed in all the way? tight as hell? kinda oddly? it doesnt seem that the cover can 100% fully "SEAL" up correctly with the K&N air filter vs the stock foam element.
mine was that way.
Old August 5th, 2010, 01:49 PM   #3
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
Did you re-jet after installing the filter? The bike will be getting more air (a little) so may need a little more fuel to balance that.
Is that 105mph at redline?
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old August 9th, 2010, 12:21 PM   #4
ninja man
ninja man's Avatar
mine was that way.
k&n fitted fine mate
yes mate .
Old August 9th, 2010, 01:37 PM   #5
how did you rejet? isn't yours FI and not carbs?
Old August 9th, 2010, 01:46 PM   #6
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
He stuck #100 needles through the fuel injectors and made them larger thus injecting more fuel jk lol
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old August 10th, 2010, 12:53 AM   #7
ninja man
ninja man's Avatar
yes its fI and not carbs , uk bike is 33bhp standard with full system its now 35bhp
Old August 10th, 2010, 01:08 AM   #8
so, how did you rejet?
Old September 2nd, 2011, 12:25 AM   #9
squaregamer476
learning stages
squaregamer476's Avatar
Motorcycle(s): black 09 kawasaki ninja 250
same with my filter. My cover just didnt sit in right. its bowing out a little. is there a remedy for that. thx^_^
squaregamer476 is offline   Reply With Quote
Old September 2nd, 2011, 12:53 AM   #10
squaregamer476
learning stages
do i have to rejet after putting in an K&n filter?
Old September 2nd, 2011, 02:39 AM   #11
Ricmon
Motorcycle(s): '10 Ninja 250r FI
Well, with my Pipercross... I had to be carefull so the air filter gets all in...maybe you are leaving some of the air filter out? it should be a tight fit.
Ricmon is offline   Reply With Quote
Old September 2nd, 2011, 02:43 AM   #12
Ricmon
If yours is really FI, you should have a red FI light in the dash. If it is....I advise you to:
1 -Remove the snorkel;
2 - NGK IRIDIUM spark plugs - model CR8EIX
3 - Do the zip tie mod -The easyest of them and you will REALLY notice the difference.
Old September 6th, 2011, 09:50 AM   #13
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
13k rpm with 14/45 gearing = 105.5mph. so 105 is about the max your gonna hit on stock gearing .
#1
greatwhiteninja is offline   Reply With Quote
Old September 6th, 2011, 01:00 PM   #14
If you are able to red-line 6th gear, then the only ways to get more speed are to raise the rev-limiter or go with taller gearing. Once the bike bounces off the rev-limiter, it won't go any faster
Old February 1st, 2012, 09:27 PM   #15
hackeron
Motorcycle(s): Ninja 250r (2009)
What's a zip tie mod?
hackeron is offline   Reply With Quote
Old February 2nd, 2012, 12:42 AM   #16
cuong-nutz
cuong-nutz's Avatar
This:
More throttle with less input needed.
http://www.ninjette.org/forums/showthread.php?t=26270
HalfFast Racing Team
This is an air filter??? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 15 July 15th, 2013 11:27 AM
K&N air filter to stock air box Graugaard 2008 - 2012 Ninja 250R Tech Talk 29 July 28th, 2012 06:33 AM
Anyone know an air filter I can replace the OEM filter with? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 5 July 22nd, 2012 09:34 AM
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su Ninjette Newsbot Motorcycling News 0 June 11th, 2012 06:00 PM
What air filter are you using? cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 14 April 14th, 2012 12:40 AM
