Old October 28th, 2012, 01:31 PM   #1
NewbieNinja
NewbieNinja's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250r, 2009 Suzuki GSX-R750
Most effective shift points?
Hi guys,
I've owned my ninja for about a month now but been riding my Gsx-r600 for a year now. When I go from a stop onto the onramp to the freeway it takes so long to get up to speed. I slowly realized that shifting at around 10k-11k is more effective then going all the way to redline.
So my question is, is this normal? Does it take you guys 10-15 secs to get up to speed as well when entering the freeway?
NewbieNinja is offline   Reply With Quote
Old October 28th, 2012, 01:40 PM   #2
Yea, it's normal casual riding and being courteous and predictable to other drivers on the road. It's what your supposed to do.
Your building most of this speed on the ramp right?
Old October 28th, 2012, 01:44 PM   #3
NewbieNinja
It just seems like the bike is struggling so hard.. -_-
Old October 28th, 2012, 02:11 PM   #4
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Peak power is around 10-11k on the stock ninjette and trails off a little after that.
menikmati is offline   Reply With Quote
Old October 28th, 2012, 02:15 PM   #5
Don't let the high rpms fool you, the bike loves em.
Old October 28th, 2012, 02:51 PM   #6
NewbieNinja
Well, see the dude I bought it from says its been jetted and it has a Yoshi exhaust on it already.. From most videos I've seen these ninjas are fairly quick from 0-60 after they've been jetted..
Old October 28th, 2012, 03:00 PM   #7
600 quick?.... no, not gunna happen. But, ok, lets assume something is up.
Does the bike run right?
Any bogging down anywhere through the rpm range?
Any slipping anywhere?
Clutch cable adjusted with a bit of slack?
Your weight geared up?
Airbox vs pods?
Air box clear?
Snorkle still installed?
Old October 28th, 2012, 03:10 PM   #8
NewbieNinja
Of course not.
Does the bike run right? Idle hangs at 4k for about 20secs when coming to a stop
Any bogging down anywhere through the rpm range? Nope bike pulls hard but slow
Any slipping anywhere? Doesnt feel like it
Clutch cable adjusted with a bit of slack? Yup, feels pretty solid.
Your weight geared up? Lol, a whopping 125lbs
Airbox vs pods? Airbox
Air box clear? Not sure yet
Snorkle still installed? Not sure yet
BTW, the bike only has 3800 miles on it.. :/ and thanks for the interest.
Old October 28th, 2012, 03:18 PM   #9
menikmati
Of course not.
Hanging idle? Idle speed should be set at around 1,350-1,500RPM when fully warm and throttle blips should not hang or dip below the set idle speed. Tinkering with the idle mixture screws can help fine tune your idle circuit.
Any bogging down anywhere through the rpm range? Nope bike pulls hard but slow.
Hard, but slow...?
Old October 28th, 2012, 03:21 PM   #10
Some references, Yue Pheng:
http://www.ninjette.org/forums/showt...ghlight=faster
Old October 28th, 2012, 03:22 PM   #11
menikmati
Might want to see what jetting you're currently running, main jets, needle height, idle mixture if the PO claims to have it properly jetted with a Yoshimura exhaust.
And a 2008 with only 3,800 miles, the bike probably sat for a long while between rides and may have gummy carbs.
Old October 28th, 2012, 03:27 PM   #12
Np, glad to help as I can.
Sounds like the jetting is slightly off, getting to much air or you have a vac leak somewhere. There should be no hanging of rpms, especially for 20 seconds. Hold out for someone who knows more about that than I. I am not your guy on that subject. It don't really matter how many miles are on the bike if mods where made and not done effectively.
We have some awesome members who post often enough to help you out if that is indeed the issue.
Old October 28th, 2012, 03:30 PM   #13
menikmati
@choneofakind will answer all your jetting questions as well as do all your physics homework.
Old October 28th, 2012, 03:34 PM   #14
NewbieNinja
Originally Posted by Motofool View Post
Ahhh, thanks for the link I was just getting there..
Old October 28th, 2012, 03:45 PM   #15
NewbieNinja, have you checked if your carbs are in need of cleaning? Slow to pull, hangs when coming to idle, and a low mileage bike point to dirty carbs in my mind, especially when you consider that it should be pulling solidly to freeway speeds with a full Yoshi and jetting.
right...
Old October 28th, 2012, 03:47 PM   #16
NewbieNinja
Yea, I figured something is wrong but I haven't gotten time to tear the bike apart yet.. But something is definitely wrong.. I just watched those 0-60 clips and I hate coming to stops because it takes so long to get back up.. O.o
Old October 28th, 2012, 03:54 PM   #17
NewbieNinja
right...
haha, Thanks, I have to reorder a new jet kit because I never got extras from the PO. Then gotta lower so the ol girl can ride it(5'0") then I'll have to tear apart the carbs and redo everthing.. I'm almost 100% positive I am running way too lean..
Old October 28th, 2012, 03:59 PM   #18
menikmati
You don't have to buy a whole jet kit, buy some jets from Jets R Us and some #4 washers to shim the needles with. I'd do the carb cleaning first though and then find out what main jets you're running before altering the jetting.
Old October 28th, 2012, 04:04 PM   #19
Clean them before you re-jet. You can't diagnose jetting on a carb that is not clean and functioning properly.
Old October 28th, 2012, 04:08 PM   #20
NewbieNinja
You don't have to buy a whole jet kit, buy some jets from Jets R Us and some #4 washers to shim the needles with. I'd carb cleaning first though and then find out what main jets you're running before altering the jetting.
Awesome.. didnt know they sold individual parts.. any ideas what I'll need? PO used dynojet. I plan on replacing airbox with the 1 piece KN and doing the Kleen air removal mod.. What size jets will I need? Thanks.
Also, will I need any needles, pilot jets and well needle jets(wtf?)
Old October 28th, 2012, 04:11 PM   #21
menikmati
As Chris mentioned earlier, clean the carbs first and make sure they're operating properly and then work on dialing in the jetting.
We won't know what jetting suggestions to give you until the carbs are performing correctly and what your current jetting is to serve as a baseline.
Old October 28th, 2012, 04:24 PM   #22
NewbieNinja
Yes, sir. I'll grab a bottle of seafoam tomorrow.
[RoadRUNNER] - Touring Tip: The Importance of Effective Wind Protection Ninjette Newsbot Motorcycling News 0 January 9th, 2015 12:00 PM
WTB: New gen shift linkage + shift knuckle + Woodcraft rear sets 675Raisinator Items Wanted 1 July 30th, 2012 05:59 PM
What are your shift points? tjb0012 2008 - 2012 Ninja 250R Tech Talk 37 January 7th, 2011 02:06 PM
[roadracingworld.com] - Proof That With Effective Marketing, Motorcycle Racing Can St Ninjette Newsbot Motorcycling News 0 December 15th, 2009 12:50 PM
[sportrider - tech] - Shift Points Ninjette Newsbot Motorcycling News 0 September 10th, 2009 06:00 PM
