Old September 28th, 2014, 04:20 PM   #81
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
Originally Posted by Foxrider64 View Post
Might want to specify which Alex- there are about 100 of us on here.
Talked with the Florida spec 250 guys today- scheduling conflict of the endurance race at JGP later that month might limit who I can get to go. I'm trying to recruit more little ninjas.
Well you. Duh.
I should have room for a bike, rider & gear in my rig. So if you're along 75 south and the travel is the only thing stopping you, lemme know.
Hmm, if that offer still stands at that time, I may meet you in Atlanta...or Forsyth, or Macon, or somewhere along the way. You staying all three days?
Postwhores are COOL! ~Allyson
Old September 28th, 2014, 04:30 PM   #82
Yes um, not making the trip for anything less.
Old September 28th, 2014, 05:01 PM   #83
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Originally Posted by Floki View Post
What would cause them to fail a chain during inspection? Mine has two noticeable tight spots that you can hear click while riding.
Going to a track to ride faster than you normally ride I would think you want everything on your bike to be tip-top.
Have you seen video of chains coming off at speed? It's deadly!
Old September 29th, 2014, 08:40 AM   #84
Foxrider64
Hello Moto
Foxrider64's Avatar
Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F
This weekend is an "open" weekend meaning that there is no private org renting the track.
What this means is that there is no tech inspection. If something is noticeably wrong like bodywork hanging off or license plates still attached you will get "meatball flagged" and required to fix it.
In regards to your chain- clicking is bad. It means unnecessary friction and more heat. If a chain seizes or snaps at speed- even on a 250 it can detonate the engine, lock up your rear wheel or can catapult off and become a missile to other riders. Clean it as best you can- focus on the links that are stiff. Cleaning might free them up- if not, please buy a new chain. I don't want to be hit by a flying chain
Foxrider64 is offline   Reply With Quote
Old September 29th, 2014, 09:10 AM   #85
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
Thanks guys. I couldn't find much information on when you should replace a chain. I ordered new chain and sprockets but will be doing the gear oil and diesel fuel trick this weekend. I also am not sure on how to adjust tension on my bike because it lacks fairings so I have just been setting 2 inches on the rear stand of slack, which tightens to about 1.5in with me on it
Floki is offline   Reply With Quote
Old September 29th, 2014, 09:14 AM   #86
When to replace a change is simple really. Replace if any of the following conditions exist.
Visible damage
Clicking that is not solved by lube or returns shortly after lube
Chain will not stay within slack spec
Chain stretched beyond adjuster/axle specs
Old September 29th, 2014, 09:16 AM   #87
My trailer will hold currently hold 3 bikes. By the time of this trip, my open trailer will hold 4. So I got you if you need a lift.
Old September 29th, 2014, 09:20 AM   #88
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
phew just had a scare, went to start the truck to go longboarding and it wouldn't start. Clicking noise led me to believe it was the starter, not the cheapest part in the world for sure. Jacked it up to check it and discovered it was missing a bolt and the other bolt was hanging on by a thread luckily I managed to hop on the bike over to ace hardware and pick up the bolt needed and it's all good
I could be interested in joining up around atlanta/macon or so
Old September 29th, 2014, 09:25 AM   #89
I am more than happy to haul ya but... if you want your truck and such available at a moments notice and you go that far, might as well drive the rest of the way. Jennings is only 4 more hours past macon. ijs
Offer still stands homie, if you want to save some serious gas $$$, hook up with me near cincy. If cincy is about the same trip as Mid-O for you, then lemme pick you up there. Not only that, I gotz mad driving stamina. You can arrive at the track fully rested and ready to ride.
Old September 29th, 2014, 10:06 AM   #90
Floki
Motorcycle Nurse?
Floki's Avatar
We are all pitching tents on the track right?
Old September 29th, 2014, 10:08 AM   #91
hhahahahaha sure, let's "pitch tents"
Old September 29th, 2014, 10:08 AM   #92
Foxrider64
Hello Moto
Foxrider64's Avatar
I will be camping- yes.
Old September 29th, 2014, 02:04 PM   #93
ally99
Ninja chick
ally99's Avatar
Chris, are you bringing your apartment tent? If so, I'll rent a room from ya! Otherwise, I'll probably stay in a hotel.
Old September 29th, 2014, 02:05 PM   #94
The taj mahal will be open for public viewing. lol
Old September 29th, 2014, 02:17 PM   #95
Foxrider64
Hello Moto
Foxrider64's Avatar
Let me re-phrase...
If my wife and kids join we will be at the Days Inn in Lake City. They likely won't join so I will bring the tent and sleeping bag- and possibly space heater. Club racer on a budget here
Old September 29th, 2014, 03:29 PM   #96
CC Cowboy
CC Cowboy's Avatar
Let me re-phrase...
Valdosta is much closer.
Old September 30th, 2014, 06:24 AM   #97
Foxrider64
Hello Moto
Foxrider64's Avatar
I meant Lake Park
The Days Inn is only 10 miles north of Jennings
They also offer a discount to JGP riders
Old September 30th, 2014, 06:29 AM   #98
CC Cowboy
CC Cowboy's Avatar
I meant Lake Park
That's where I stay. I don't camp (unless it's in a RV).
Old September 30th, 2014, 06:30 AM   #99
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
Can't wait to have my skill up to PAR to join you guys and keep up somewhat!!
.. maybe they will be by then!!
Qomomoko is offline   Reply With Quote
Old September 30th, 2014, 08:12 AM   #100
CC Cowboy
CC Cowboy's Avatar
I thought you ran track days at Homestead. If you can ride there you can ride Jennings. Actually, Jennings is better to improve your skills,
Old September 30th, 2014, 11:30 AM   #101
Foxrider64
Hello Moto
Foxrider64's Avatar
Luis- if you are able to join I might have a spot for you. Make it up to Ft. Myers and we can split fuel up to JGP
Old September 30th, 2014, 11:32 AM   #102
Qomomoko
yes but a little slow..
thanks man.. hope so...
I hope to pick up some new gen 250 parts from a forum member here and up grade the bike to 17Rims and install Diablo Rosso II, 110/70 and 140/70
.. she should be ready by Oct 25 HMS and for sure for Jennings
Old September 30th, 2014, 11:33 AM   #103
Dew et! Dew it!!!!!
Old September 30th, 2014, 01:57 PM   #104
ally99
Ninja chick
ally99's Avatar
I'm getting a new rear tire and a bike service Oct 13, so she'll be good and ready for Jennings!
I'll be in novice because, well, I'm a permanoob. Just how I roll.
Which days are most folks riding? I'm in for Saturday and Sunday.
Old September 30th, 2014, 06:26 PM   #105
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
what are the passing rules in novice at jennings gp?
Old September 30th, 2014, 06:27 PM   #106
CC Cowboy
CC Cowboy's Avatar
As far as I know faster guys pass slower guys.
Old September 30th, 2014, 06:28 PM   #107
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
in all of my novice groups it's been pass in the straight only, I meant if you can pass mid corner
Old September 30th, 2014, 06:30 PM   #108
CC Cowboy
CC Cowboy's Avatar
Only if you're faster!
Old September 30th, 2014, 06:31 PM   #109
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
well played cc, well played
Old September 30th, 2014, 07:15 PM   #110
There are none, just make it safe, it's pass or be passed.
Old October 1st, 2014, 06:22 AM   #111
Foxrider64
Hello Moto
Foxrider64's Avatar
This is not entirely true-
The CR will tell you that passing on the inside is not allowed and passing on the outside is only allowed when there is no avoiding it. They prefer passing only in the straights for novice group.
Intermediate can pass on the outside as long as there is 6 foot buffer- inside is still frowned upon.
Advanced can pass when ever and where ever they are faster.
Odds are no one will complain unless you are making dirty passes
Old October 3rd, 2014, 02:12 PM   #112
Floki
Motorcycle Nurse?
Floki's Avatar
These pads need to be replaced now don't they?
Old October 3rd, 2014, 05:49 PM   #113
CC Cowboy
CC Cowboy's Avatar
Only because you have the caliper off.
Old October 6th, 2014, 01:32 PM   #114
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
@Floki better safe than sorry.
Old October 6th, 2014, 01:47 PM   #115
What he said. They had a tad bit of life left but since you got it apart.... ya know.
Old October 6th, 2014, 02:26 PM   #116
Qomomoko
Applying book "Sport Riding techniques" at the track
Palm Beach International Raceway, October 5
Success? I hope or I am not all up there...
lol I got to clear up what the code is and where to get it lol
think the point is to use the "stuff" under embedded and not under "share" ...
Last futzed with by Alex; October 11th, 2014 at 12:03 PM. Reason: fixed videos
Old October 6th, 2014, 02:28 PM   #117
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Session 5
Session 6
Session 7
fixed that for you, hit quote on my post to see how
Old October 6th, 2014, 03:27 PM   #118
Qomomoko
thanks.. when quoting you it does not show the videos and their url/[x]...[y]... lol
Old October 6th, 2014, 03:32 PM   #119
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
correct you use the [youtube] [/ youtube] tags with only the video code from the end of the url
Old October 7th, 2014, 02:49 AM   #120
ally99
Ninja chick
ally99's Avatar
We are a month out!
Chris, when do you plan on buying your spot?
[roadracingworld.com] - Jennings GP Hosting Endurance Races In October And November Ninjette Newsbot Motorcycling News 0 September 20th, 2013 11:40 AM
[roadracingworld.com] - Jennings GP Hosting Its Own Endurance Races November 24 Ninjette Newsbot Motorcycling News 0 July 17th, 2012 10:20 AM
Jennings 4/1 CCS Cab305 Ninjettes At Speed 15 April 20th, 2012 07:33 PM
Backwards at Jennings dustoff Ninjettes At Speed 6 November 23rd, 2011 11:24 AM
November 20th at Jennings GP JS73 Ninjettes At Speed 9 November 19th, 2010 10:41 AM
Except where otherwise noted, all site contents are Copyright 2022 ninjette.org, All rights reserved.
