Old November 10th, 2012, 08:28 AM   #1
n4mwd
n4mwd's Avatar
Flush Mount Turn Signal DIY
This is my first attempt at a narrated and edited video. I thought I would make a DIY for installing Flush Mount turn signals.
Hope it helps.
My Ninja Blog
Old November 10th, 2012, 12:23 PM   #2
StephenA
Riding Ruby..
StephenA's Avatar
Motorcycle(s): 2014 Yamaha Bolt R-Spec, 2007 Ninja 250R
this is a very good tutorial, great work.
Unregistered
StephenA is offline   Reply With Quote
Old November 10th, 2012, 03:22 PM   #3
n4mwd
n4mwd's Avatar
Thanks. I noticed a few people were just bolting them on without adapter plates, or just sticking them on with something, but they end up looking like crap. So I decided to make decent adapter plates.
My Ninja Blog
Old November 10th, 2012, 08:37 PM   #4
Make a few more and sell 'em here and on eBay. Those signals certainly look popular enough!
Old November 10th, 2012, 09:12 PM   #5
n4mwd
n4mwd's Avatar
Tempting, but what I don't understand is why manufacturers don't make signals that just bolt up. There is at least one the bolts up to the newgen, but none that I could find for the pregen.
My Ninja Blog
Old November 10th, 2012, 09:16 PM   #6
The one's that bolt up to the newgen are still generics. The only aftermarket signals I've ever seen that weren't generic were OEM replica or "euro-style" lens replacements and such. It's hard to find bike-specific turn signals no matter what the bike.
Even the color-matched Asian Cycle flushmounts were generics that required drilling.
The 650R/ZX14 wedge-style ones are used on a lot of Kawasaki's bikes and I've seen "flush" lenses for those in addition to complete OEM replicas and tinted lenses, but that's the closest I've ever seen and a "replica" of the OEM style is hardly what most people want to replace stalky signals with.
Old November 10th, 2012, 10:58 PM   #7
Take advantage of those 2 filament bulbs.
Wire the dim filament in with the gauge cluster or tail light. You'll end up with running lights and turn signals. Much more visible at night, and well worth the 20 minutes it will take to cut, splice, and solder.
Old November 10th, 2012, 11:17 PM   #8
249cc
QrtLtrDog
249cc's Avatar
Motorcycle(s): '09 250
You have a godly voice sir.
249cc is offline   Reply With Quote
Old November 11th, 2012, 02:07 AM   #9
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
You have an awesome speaking voice! Do more DIYs, very clear and easy to understand and follow.
Ok, lame question... On a new gen, any idea how to do this? I have a flush mount that is dual filament but I'm simply ignoring the spare wire. Not even sure where to look for my gauge cluster light wire or how to go about hooking it up that won't be a pain to undo any time I want to remove the side fairing. :blink: it'd be cool to have running lights though!
<-- Linky
Old November 11th, 2012, 05:10 AM   #10
n4mwd
n4mwd's Avatar
I don't do enough night riding to make it worthwhile. But I was thinking about wiring them together to make it a little brighter.
LOL, that's the first time anybody has described it that way.
Thanks. I'll probably do more of them later on.
My Ninja Blog
Old November 11th, 2012, 10:02 AM   #11
D, it's still a good idea for visibility on foggy mornings or rainy days etc. I don't ride at night that often, but I figured it was a good idea for all the other times I'm riding. It makes me distinguishable as a motorcycle from the front, rather than just a car with a missing headlight. I think that's why many new sport bikes have started doing those corner markers in the edges of the headlight.
You'll need to find wiring that is switched with the ignition. So the running light in the tail light, or the license plate light, or the gauge cluster lights, etc.
Then you'll want to splice into the hot wire (red usually) and add wires that will lead to that 3rd wire on the turn signals. There's already a common ground on the turn signals, so no biggie there. If you add some quick-disconnects, it will be just as easy to disconnect as it currently is; only difference is you'll have to disconnect 3 wires instead of 2. Do it! It will be easy and running lights improve your visibility at night, dawn, and dusk. I have turn signals that are single filament with LED's in them (ridiculously bright and overpriced ones from superbrightleds.com ) and I wired in some relays to make them running lights that flash when my turn signals are used. I think it was well worth my time.
Check out how visible they are, even in a horribly out of focus picture:
and from the side:
Sorry for pic whoring in your thread D
Old November 11th, 2012, 12:10 PM   #12
n4mwd
n4mwd's Avatar
No problem. Now post one of it in the bright sun.
Even the incandescents have trouble in bright Florida sunlight.
No offense, but I don't trust night photos of LED lights.
My Ninja Blog
Old November 11th, 2012, 01:06 PM   #13
Just as bright as the oem lights, but they're more visible from the sides.
Old November 11th, 2012, 02:48 PM   #14
n4mwd
n4mwd's Avatar
I went to the superbrightleds.com and the brightest 1156 bulb they had was 220 lumens. That's about half the lumens of a standard bulb which is about 402 lumens. I want to replace all my bulbs on the 2007 with leds, but I don't want to do it if they aren't going to be as bright as the real bulbs.
My Ninja Blog
Old November 11th, 2012, 07:09 PM   #15
NevadaWolf
NevadaWolf's Avatar
I'll give it a shot tomorrow. My repair is in pause at the moment awaiting FedEx so I have tinker time before they get here.
<-- Linky
Old November 15th, 2012, 11:21 AM   #16
Another daytime shot I found on my computer for you n4mwd:
again, the numbers may be smaller, but they really seem just as bright to me in daylight as the standard bulbs. Maybe they're not, idk. But I've not had issues with people not seeing my turn signals during the day, and at night, people definitely see me better because they're wired as running lights.
Notice that I was responsible and at least attempted to control the glare output from my HID setup. It worked for the most part. I still did a projector retrofit though
Old November 15th, 2012, 02:42 PM   #17
n4mwd
n4mwd's Avatar
No offense, but those photos are daytime photos and not what a Florida cracker would call daylight. Both looked to be in the shade. Anyhow, they still look good for running lights. Do you have a photo of the actual turn signal operating in daylight?
My Ninja Blog
Old November 15th, 2012, 03:13 PM   #18
NevadaWolf
NevadaWolf's Avatar
@n4mwd ah, you folk in Florida just hog all the sunshine from the rest of the country.
Though, question for ya @choneofakind (or whomever), on my flush mount I have three wires. Red, black, and black/white. I've figured out the black is ground, red is blinker, and black/white is running light.
Right now I have red and black wired into the existing turn signal plug with the black/white hanging loose. If I clip the black/white straight to the battery, the bright filiment comes on solid and the dimmer one blinks really fast with the switch. The solid running light drowns out the blinker.
Any ideas?
<-- Linky
Old November 15th, 2012, 03:56 PM   #19
n4mwd
n4mwd's Avatar
You're from Nevada and you say WE hog all the sun. Heck, the last three months have been non-stop rain here. We are finally getting some decent riding weather around here.
That's odd. In my case, the red was the runner and the striped was the blinker.
Any ideas?
If your bike has similar wiring to the pregen, the black wire on the turn signal should go to the yellow wire on the bike (black/yellow on the newgen). That is ground. The running light wire should go to the tail light circuit. You could use the headlight wire if you are desperate, but if you want it right, it should go to the tail light running light circuit. If you do it that way, you can activate them by turning the key to "PARK" position. Otherwise, if you hook it to the headlights, it will only come on when the engine is running and NOT when in park.
Below is the pregen turn signal schematic.
My Ninja Blog
Old November 15th, 2012, 04:43 PM   #20
NevadaWolf
NevadaWolf's Avatar
Whoops, I lied.
My red is hooked to the bike's green. The black/white is hooked to the black/yellow on the bike, and the solid black is loose.
When i was trying to figure out which was which, if the solid black had power the running light came on. If the red had power, it blinked.
<-- Linky
Old November 15th, 2012, 06:20 PM   #21
n4mwd
n4mwd's Avatar
Whoops, I lied.
When you say red blinked, you mean with the turn signal switch on, right? Not blinking when hooked directly to a battery.
Anyhow, you need to connect black to the bike's black/yellow. And red to the bikes other wire which is probably a different color on each side. From what you are saying, the striped wire goes to the tail light.
My Ninja Blog
Old November 15th, 2012, 06:55 PM   #22
First one was woods, in a break in the trees. Freakin' bright day; broad daylight.
Second one was in the open in broad daylight. I had just gotten home from work on a half day, it was like 11:30 am summer sunshine. Sure there's the little bit of shade to cut the glare from one tree over my driveway, but it was bright that day outside.
Trust me when I say the cameras were compensating on both days.
Old November 15th, 2012, 08:10 PM   #23
n4mwd
n4mwd's Avatar
Um, yep, it compensated all the shadows away.
My Ninja Blog
Old November 15th, 2012, 08:25 PM   #24
Well fine don't believe me. I like my bike. You like your bike. No worries
Old November 16th, 2012, 05:34 AM   #25
n4mwd
n4mwd's Avatar
I like ALL Ninjas. But you need a vacation to a state that has real sunshine. And shadows. And skies that are blue instead of white.
EDIT: Attached a photo of what the sky is supposed to look like. Note the blue sky and distinct shadows. This was taken on the west bank of Lake Okeechobee looking east.
My Ninja Blog
Old November 16th, 2012, 08:44 AM   #26
NevadaWolf
NevadaWolf's Avatar
I'll tinker with it this weekend once I get the plastics dealt with. Trying to finish painting while still dry outside.
But yeah, while I was testing, the power was coming from the turn signal wire. So when I had red to green and the switch on, the light blinked (albeit very quickly).
<-- Linky
Old November 16th, 2012, 12:03 PM   #27
What's ROD?
Old November 16th, 2012, 12:04 PM   #28
StephenA
Riding Ruby..
StephenA's Avatar
haha it's like a mythical creature or something, saw a show on discovery channel one time about it..
Unregistered
Old November 20th, 2012, 04:27 PM   #29
Can a router table remove the lip from this steel bushing?
I just went to a shop and the guy kept telling me that I'd have to get it milled, but it seems like the machine you used could do it easily if it can do the same thing with steel.
Old November 20th, 2012, 04:55 PM   #30
n4mwd
n4mwd's Avatar
A router is made for wood. You can get away with plastic and even aluminum, but not steel. To remove that lip, why not just use an angle grinder?
My Ninja Blog
Old November 20th, 2012, 06:13 PM   #31
Thanks. I was hoping there was a different kind of blade or something.
Old November 20th, 2012, 06:55 PM   #32
conrya5
conrya5's Avatar
Motorcycle(s): 2010 Metalic Island Blue Ninja 250r
Great DIY video, simple, easy to understand, and to the point!
When I mounted mine I used nuts with a nylon insert in them to help reduce the chance of loosing one from vibrations?
conrya5 is offline   Reply With Quote
Old November 21st, 2012, 05:58 AM   #33
n4mwd
n4mwd's Avatar
I used lockwashers, but locknuts are a good choice too. Either will keep it from vibrating loose. I like locknuts better, but they didn't have any at the hardware store when I was there.
My Ninja Blog
Old November 21st, 2012, 06:06 AM   #34
n4mwd
n4mwd's Avatar
Cutting steel like that takes a much stronger bearing. If you used a metal cutting bit on steel in the router table, you would either burn up the motor or destroy the bearings in the router.
The easiest and cheapest way to remove the lip on that thing in the photo would be with a $10 angle grinder from Harbor Freight. A mill isn't the right tool either. An angle grinder isn't going to make it perfect, but it will work. If I wanted it perfect, I would use a lathe.
My Ninja Blog
Old November 21st, 2012, 11:11 AM   #35
ai4px
ai4px's Avatar
Motorcycle(s): 650r 2009 Vulcan 800 2005
This is really odd. The bike is plumb but the parking lot, car and truck in the background are tilted.
It's all about the curves. If you ride, you understand. If you have a stick skinny g/f and ride, you're 1/2 way there.
ai4px is offline   Reply With Quote
Old November 25th, 2012, 07:31 PM   #36
ai4px you should see my whole house!
jk, but that would be sweet.
Old June 23rd, 2014, 04:42 PM   #37
killerkeith
killerkeith's Avatar
your sig is my username.
Start>2008CBR125R>2007Ninja650R>2008BWS50>2007Ninja650R>2009Ninja250R>2009Versys 650>2009Ninja250 ST EditionCurrent
killerkeith is offline   Reply With Quote
Old June 23rd, 2014, 05:38 PM   #38
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
it's the [ you ] tag. Which shows the username of the dude that's currently logged on. Log out and it should say unregistered or something.
The Bike | The Truck
Flush mount turn signal Angel 2008 - 2012 Ninja 250R Farkles 4 June 12th, 2014 08:41 AM
WTB: Petcock, Front turn signal lights standard or flush with mount. agentbad Items Wanted 2 September 16th, 2013 12:37 PM
Flush Mount Turn Signal Options - Need Advice bbjminardo 2008 - 2012 Ninja 250R Farkles 14 February 19th, 2013 07:27 PM
Semi-DIY $0 flush mount FAIL! (Need Help) 00v_Lucky 2008 - 2012 Ninja 250R Farkles 19 July 11th, 2009 01:13 PM
DIY: Pregen Fender Chop/Flush mount turn signal mod brian997 1986 - 2007 Ninja 250R Tech Talk 8 March 29th, 2009 09:37 AM
