Old April 23rd, 2017, 04:10 AM   #121
Originally Posted by Ram Jet View Post
Where do you get them? It's apparent you recommend the spacers whether or not you play with the jet needle height.
By the way, I highly recommend Loctite Super Glue "Professional" over Krazy glue Zap-A-Gap etc. Available at Lowes, Home Depot etc.
Bill
From me.....sorry, trade secret Yes, any jet kit needle will dance up/down in the little white needle retainers, the spacers work perfect...mimic the stock needle "nail heads", eliminate any up/down slop... the retainers were originally designed (by Keihin) to secure *stock* needles in place. Next time you have a slide and adjustable jet kit needle in your hands...hold the retainer down, push the needle up....if ANY freeplay...they dance.
In a constant effort to improve my methods, i'm now using axle grease to form and hold the orings in place prior to bowl installation. Heat cycles and pressure will insure the orings form and stay in place....easily removed when required.
Fear not... giant globs of grease are removed....no invasive slop...no migration...clean and neat as always.
Good questions, comments and discussion...thanks for your interest Bill!
Gordon
Last futzed with by ducatiman; April 23rd, 2017 at 05:12 AM.
Old April 23rd, 2017, 06:02 AM   #122
Ram Jet
Ram Jet's Avatar
a pretty obscure area to enable "accidental damage"....not like its Grand Central Parkway..what the hell would even bring you in there?
2 1/2 turn is just a starting point, adequate to start/run, pilot screws should further be fine tuned , bike hot...each side for highest idle speed, best throttle response...aka the sweet spot. An EGA (exhaust gas analyzer) would offer optimum results...but simply not practical nor realistic for vast majority of owners. A well tuned (valves adjusted!) 250, once warmed.. should offer re start at touch of the button, effortless rev, drop back (no hang) from RPM to a steady consistent idle....meanwhile deliver great MPG.
Good questions and comments. Thanks for your interest, Bill.
Thanks Gordy. About those needle jet (slide needle) spacers you seem fond of. I guess you'd recommend them - your rationale makes sense. Could you sell me a couple? I don't plan on diddling with needle height unless I need to. I want to see the impact of my larger main jets first.
Cheers,
Bill
Old April 23rd, 2017, 06:39 AM   #123
Originally Posted by SLOWn60 View Post
That's what I expected. Plus there's probably customs/border brokerage fees etc.
There are no brokerage fees into Canada if you stick to USPS, and I've never had to pay any tax or fee for packages coming into the US. Randomly, Canada does add tax and/or import duty to packages coming in, but not all the time. Unfortunately, with the size of the carbs, the medium flat rate box may be the only reasonable option. Sometimes a plain box (not flat rate) comes out cheaper, depending on weight though.
I ship motorcycle electronic parts to Canada regularly, and a package I sent last week was $23.70, but that box is too small for a pair of carbs.
You can explore all the options on the USPS web site. Sometimes the guys at the local Post Office are not familiar with all of them. Then if you use a 3rd party postage company like Shipping Easy to print the labels instead of the USPS site, you can get a small discount on postage.
Old April 23rd, 2017, 07:40 AM   #124
Ram Jet
Ram Jet's Avatar
Gordon
Grease is a good idea. Sooner or later you probably would have to use acetone and scrape the old cyanoacrylate glue out on the next rebuild.
Bill
Old April 23rd, 2017, 10:44 AM   #125
^ easy cleanup, non invasive, no long term ramifications, most importantly...effective and does the job!
Old April 27th, 2017, 03:52 PM   #126
currently doing these, owner interested in "how bad" hence before pics (I usually forget) to contrast with after (when completed)
Old April 27th, 2017, 06:38 PM   #127
a couple of AFTER pics...any better?
Old April 27th, 2017, 07:22 PM   #128
Ram Jet
Ram Jet's Avatar
Like new
OK, gig's up. Who is your supplier of new Keihin carburetors?
Bill
Old April 28th, 2017, 07:13 AM   #129
roundhouse
Motorcycle(s): 04 250R
HOLY SMOKE! That looks great!
roundhouse is offline   Reply With Quote
Old April 29th, 2017, 09:43 AM   #130
some completed pics....
replaced old with ALL new *tight* vac hoses inside/outside
Seems to be common...the last few sets I've done I've discovered a rash of loose vac hoses (at fittings)....just loose enough to cause minor leakage when warm I think...best to renew at time of refurb.
Old April 29th, 2017, 11:12 AM   #131
To report some new updates with Custom Carb Services:
NEW OPTION...full vacuum hose replacement (4 or 5 depending on series and model) to tighten up those old, loose, failing hoses. The inner decel valve hoses included, of course...$20 flat fee, labor and parts. Does NOT include fuel inlet or vent hoses.
LABOR RATES going up a slight bit.
Please PM for your particular needs, quick estimates and questions.
Thanks, Gordon
Old May 6th, 2017, 12:42 PM   #132
roundhouse
WOW! GREAT WORK!
Bolted on the carb put on the tank and started right up. purrs like a kitten. I forgot to choke it and it still started and idled without hesitation. I guess with all the crap I have gone through to get this bike running I am glad I finally got someone who knows carbs and is honest. Paid a local guy $100 to rebuild the carb and he ripped me off.
thank you Gordon. Money well spent.
Old May 6th, 2017, 12:56 PM   #133
Originally Posted by roundhouse View Post
WOW! GREAT WORK!
Guilty on both counts! Glad it worked out. And for you.....yeah, baby, yeah!
Old July 7th, 2017, 08:49 PM   #134
Ghostt
Ghostt's Avatar
Ducatiman has done it again, this time he did my EX500 carbs.
The bike sat for 4 years outside in the elements, add to that they are 26 years old, way overdue for a refurbishment. He did find a issues with them including a bad diaphragm.You can see the slight moisture induced discoloration/corrosion in the pictured bowl, its in the other as well. Unfortunately, 4 years outdoors does take a toll.
Thank you @ducatiman for delivering once again top quality workmanship. They look better new, and will perform the same. You will not get the same level out of a can of Carb cleaner and a toothbrush, not even remotely close.
He has the knowledge, tools, equipment, and most importantly pride in his craft, and it shows.
The before and after pictures speak for themselves, this is why he does my carbs, and why I personally recommend his services without hesitation on the forums.
If anyone is on the fence about sending him yours, you need to just do it, and you'll be glad you did. It's money well spent without a doubt.
violente et ignorantia
ZX-2R BLOG
Old August 10th, 2017, 01:12 PM   #135
Another shout-out for Gordon's amazing work!!! I bought a derelict 2008 250R that had been sitting around for 2-years and was all gummed up. Here's what carbs looked like when I brought bike home.
I managed to get crispy algae off, but it was still all clogged up everywhere else inside. Bike wouldn't start properly, needed choke full-time to barely idle. Would die as soon as I gave it any throttle.Trying to run engine this way eventually caused it to hydrolock with fuel from leaky floats and break starter-gear. See DIY Starter Gear repair..
So I sent off the carbs to Ducatiman and got them back surprizingly quick!!! Using combination of alien-tech , black-magic, good ol-fashioned expertise and skill, he completely refurbished them. Replaced vacuum hoses and upgrade fasteners to allen-buttonheads which gives them a really modern high-tech look!
Installed them, and bike started right up and idled with no problems!! Crisp throttle-response on road, couldn't be any better!! Highly recommend Gordon's carb refurb service; some of the best money I've spent on this bike!
Last futzed with by DannoXYZ; August 10th, 2017 at 02:34 PM.
Old August 10th, 2017, 04:04 PM   #136
Ram Jet
Ram Jet's Avatar
I have never seen carbs as funky as those in over 50 years of wrenching on bikes. Ducatiman be da man!
Bill
Old August 11th, 2017, 05:10 AM   #137
just yesterday did this nasty 1990 KDX200 Keihin carb...sitting a few years
Old August 11th, 2017, 05:12 AM   #138
and this for JacRyann...................
Old August 11th, 2017, 05:19 AM   #139
Ram Jet
Ram Jet's Avatar
the pilot screw tips can easily be cleaned, the washers safely reused, only there to protect the oring from damage by the spring.
Who replaces the EPA caps? not needed at all
A few drops of crazy glue in the corners of the bowl lands hold the bowl rings in for assembly, compression and heat cycles "form" them. So easy even a caveman....
The stainless buttonhead screws are a matter of long term convenience.
I use all these components in all my carb services and refurbs, they work.
And I believe my *shipped* price is quite competitive.
It's essential to remove the EPA caps. My bike spent it's first 9,700 miles with the left carbs pilot jet screwed to the seat (closed) and the right carb one turn out.
Bill
Old August 11th, 2017, 05:28 AM   #140
Agreed...and standard procedure within my service.
I've personally owned late 90's Kaw ZX6R with *2* closed pilot screws right from the factory....the others near just 1 turn out..how did they run at all?
Note for update and clarity....(within the quote above) no longer using the crazy glue to hold bowl orings...standard grease works fine...under compression and a couple of heat cycles..the orings form, fit and seal perfectly....remove effortlessly when necessary.
Old August 11th, 2017, 06:36 AM   #141
Bill
I've seen that with our Ninja 500. Idle screws were different by almost 1 turn.
My son went through a HD carb for one of his buddies. He found that the idle mixture screw was completely bottomed. Had a cap on it, so it came from the factory that way. Never ran right. Wonder why...
Old March 5th, 2019, 03:34 PM   #142
Want to advise those members interested or in need....I'm now incorporating petcock service within Custom Carb Services.
This addition is both sensible and convenient as carbs are dependent on (if not held hostage to) clean, concise fuel flow via the historically problematic factory vacuum petcock.
These days, an original equipment new Kawasaki petcock in the $90 neighborhood....a clean/refurb done affordably, at a fraction of new.
I'll be stocking internal parts, alternative replacement screens (if missing) and basic salvage spare parts.
Each unit must be inspected on a case by case basis to evaluate internal condition and serviceability.
I do suggest those sending carbs to consider sending their petcock as well.
I'll also entertain solo petcock repair as well for members in need. If you've got a non-working junker on the shelf...consider refurb, good to have a working spare.
Please PM for further info.
Thanks, G
Old March 17th, 2019, 08:12 AM   #143
New diaphragms pre-installed on slides...I'm still working out details of a new slide "exchange service"...but a perfect set now in stock, ready for immediate shipment.
Offering a choice...a seamless, "drop in" alternative to avoid the risky diaphragm replacement procedure or to eliminate an extremely expensive dealer new purchase.
Furthermore... I'm placing a $$ bounty on slides with worn, torn, deformed, ripped, pinholed diaphragms, I'm reimbursing (reasonable) shipping charges via immediate Paypal as well!
Thus aiding others as well....if ya got 'em, send em! Simply PM for shipping info and further detail.
Rather than an ebay stranger, please support a fellow member... as I'm here to support you.
Old March 29th, 2019, 07:38 AM   #144
a couple recent "victims", though not 250....1st pic Ducati (38mm downdraft Mikuni) and 3 of before/ after EX500
After a medical "slowdown" affecting me in 2018 .....I'm still at this and constantly upgrading and perfecting equipment, materials and methods.
Call it what you choose...refurb or restoration but final results go way beyond "carb cleaning".
Last futzed with by ducatiman; March 29th, 2019 at 10:00 AM. Reason: clarification
Old March 29th, 2019, 05:06 PM   #145
greg737
Motorcycle(s): -
Gordon, I've got a set of GSF400 carbs I would like to have you refurbish (a rack of 4 Mikuni BST32SS carbs). Is this a job you would do? I have a package of replacement parts from Litek, O-rings and such.
Old March 29th, 2019, 06:03 PM   #146
Yes greg. What year is your Bandit? I actually did a set a few years ago.
Better if we communicate privately off ninjette board...
Hit my email gordon@customcarbservices.com I'll respond quickly.
Old May 11th, 2019, 07:21 AM   #147
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
deep clean/repair
i pm'd ya about issues i'm having with red.
"trying not to get old"
Old May 11th, 2019, 01:20 PM   #148
occupied all morning, just answered
Old May 12th, 2019, 07:12 AM   #149
maverick9611
MOTM - Feb '18
will ship out mon or tues
Old June 3rd, 2019, 07:33 PM   #150
inconer
Motorcycle(s): 2007 ninja 250
SHOUT OUT
Huge shoutout to Ducatiman, He recently refurbished my carbs that had been on a bike sitting for almost 4 years. Carbs came back looking brand spanking new and from the time they left my house to when i got them back was not more than 3 days! He really is excellent at what he does and i will use him for sure the next time i have carb problems.
inconer is offline   Reply With Quote
Old June 4th, 2019, 12:48 AM   #151
Ram Jet
Ram Jet's Avatar
Nobody's touching my carbs but Dukeman! Not even me.
Bill
Old June 4th, 2019, 04:29 AM   #152
Wow, blindsided. I am honored, gentlemen.
For both o' ya'......
Old December 22nd, 2019, 06:36 PM   #153
finished these for a Ca. member today, as close to new as I can possibly get them, as clean inside as outside
Last futzed with by ducatiman; December 23rd, 2019 at 06:59 AM.
Old December 22nd, 2019, 08:20 PM   #154
Very nice, Gordon!
Old December 22nd, 2019, 09:43 PM   #155
Old December 24th, 2019, 03:40 AM   #156
Ram Jet
Ram Jet's Avatar
Originally Posted by Snake View Post
Nice Job Gordy. No, I'm not tired of making carburetors great again.
Gordon would you be interested in dipping a 1956 Mercury Outboard Motor carburetor in your ultrsonic cleaner? I hate to purchase one cleaner for one job. The carb would be stripped except for the throttle valve.
Merry Christmes,
Bill Albertson
Old December 24th, 2019, 04:14 AM   #157
Always interested in broadening horizons......a bit of a recent oddball, refurbed a Carter carb off a 1949 International pickup truck.
Pending inspection...I'll do better than just ultrasonic...PM with some contact info....we'll coordinate.
Last futzed with by ducatiman; December 26th, 2019 at 04:11 PM.
Old February 11th, 2020, 06:21 PM   #158
refurbed these for a West Coast member, finished today
Old February 15th, 2020, 01:28 AM   #159
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Holy balls I just put these back on my bike....somewhere along it's life my 09 250 lost its R, and @ducatiman found it and gave it back. Its got a growl I haven't heard since its first couple of thousand miles, and after adjusting the pilots it's nimbler than ever.
Old February 15th, 2020, 06:48 AM   #160
Great to hear success Cal. In your case, a number of very minor issues were found and corrected but no major smoking gun. Perhaps cumulative stuff.
Above and beyond the norm, I focus effort and detail on certain obscure components.
Going forward, remember to consistently use an ethanol treatment/stabilizer such as Startron, Stabil 360, whatever. Keep them pilot jets clean!
Thanks for kind words, G
Full service manual says to turnout one carb pilot more than the other....why? RcTechnologies 2008 - 2012 Ninja 250R Tech Talk 17 March 25th, 2015 09:45 AM
[roadracingworld.com] - Race Tire Service To Provide Trackside Dunlop Sales, Service Ninjette Newsbot Motorcycling News 0 February 20th, 2012 11:10 PM
[motorcyclistonline] - Sargent Cycles Custom Seat Service Ninjette Newsbot Motorcycling News 0 February 12th, 2011 07:30 AM
