Old February 13th, 2018, 06:03 PM   #1
squirrel
Motorcycle(s): 2001 CBR929RR 2001 ninja 250
Air/fuel mixture screw o rings. How big of a deal are they?
Hey all first time post. So I recently picked up an 01 model and did the usual carb cleaning removing both jets. Noticed the rubber o rings that are supposed to be under the washer and spring were destroyed. Now I have just the air fuel screws in with the spring. I have them out 2.5 turns and the bike idles beautifully but when I give it the slightest amount of gas the bike bogs and dies. But when the choke is on it will idle up to around 4K or so. I’m stumped. Anyone have any input?
squirrel is offline   Reply With Quote
Old February 13th, 2018, 06:15 PM   #2
I wouldn't expect it to run right without the o-rings in place, but it sounds like there may be internal blockages, something is not assembled or adjusted correctly, or the diaphragms are damaged.
Old February 13th, 2018, 06:24 PM   #3
squirrel
The diaphrams are in good shape. Everything looked pretty good. Soaked jets in carb cleaner. While the diaphrams were out i used carb cleaner and with the straw attachment squirted through all the holes until the carb cleaner was shooting out of another spot on the carb lol I know that sounds kinda vague but it seemed clean to me. The butterflies looked in sync to me but I’m no expert. Changed spark plugs from cold weather ngks to the number 7s that is supposed to be there. Bike fires right up. Can’t figure it out. Just wondering if the absence of that o ring is throwing the a/f ratio off enough to cause it to bog only under acceleration and not by way of choking 🤔
Old February 13th, 2018, 06:34 PM   #4
squirrel
I should also add that the air box isn’t on. It’s just the carbs sitting in the boots.
File Type: mov 97DA6490-3CCE-47FA-8372-FB61EC47F256.MOV (35.52 MB, 10 views)
Old February 14th, 2018, 05:16 AM   #5
ducatiman
ducatiman's Avatar
I'd not be too quick to delete a factory part...especially a pilot screw sealing ring.
Those orings seal the metering tip preventing false air from being introduced. You'd be well served reinstalling new ones.
THEN get your airbox on and re evaluate from that point.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old February 14th, 2018, 06:07 AM   #6
squirrel
Well yea I wasn’t planning on leaving the washer off indefinitely. Was just wondering if the fact that it’s missing give me the symptoms I’m experiencing. Also have you you guys heard of these? (Look at the attachment) if so what are your thoughts?
File Type: jpg 094CD33E-8ABD-4F06-A425-575D38A30D3A.jpg (49.6 KB, 15 views)
Old February 14th, 2018, 06:43 AM   #7
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
It is not going to run without the air box connected.
I was not used to working on CV carbs. They will not take the throttle without the air box. If pods are installed you are going to spend a lot of time working out the rejet.
Cafe Racer is offline   Reply With Quote
0 out of 1 members found this post helpful.
Old February 14th, 2018, 11:53 AM   #8
Ceeloo Yello
Motorcycle(s): 250
Those don't look like they would fit, I bought some for a harley off of ebay and they worked well.
Old February 14th, 2018, 02:55 PM   #9
Ghostt
Ghostt's Avatar
Easy adjustment mixture???? It's not had to get to, and you set it once, and that's it.
Another BS item, like snake oil
violente et ignorantia
ZX-2R BLOG
Old February 14th, 2018, 05:36 PM   #10
Ceeloo Yello
Motorcycle(s): 250
I find it useful, no need to look for the bent screwdriver every time I have to rebuild the carbs.
Old February 14th, 2018, 06:50 PM   #11
Ghostt
Ghostt's Avatar
How often are you rebuilding the carbs?????
ZX-2R BLOG
Old February 14th, 2018, 06:56 PM   #12
Ceeloo Yello
Motorcycle(s): 250
At least 2-3 x a year sadly.
Old February 16th, 2018, 12:09 PM   #13
Ceeloo Yello
Motorcycle(s): 250
Which is another reason I want to join the EFI conversion club.
Old February 18th, 2018, 05:57 PM   #14
Cafe Racer
Not sure why you need to rebuild a carb 2-3 times a year. The only things I can imagine is rusted gas tank, get an inline filter, cheap rebuild kit parts or you are doing something wrong.
I have two injected bikes. One Honda and the other a Harley. The Harley is my road bike. I keep it on a Harley Service plan. The Harley has a tuner, cam mods, intake mods and exhaust. It belchs put almost 90 HP and 101 foot pounds of torque. I can't even set the idle let alone the mixture. You need a computer and the Harley program.
Harley puts on a computer during any engine service.
The other is a Honda Big Ruckus. It is a fuel injected 250cc engine. You have to take what you get. It has no super tuner or any way to alter fuel/air that I know of.
I like carbs. I can tune, clean and rejet them in my sleep.
My old CX500 has carbs. My 305 Honda Dream and Honda Elsenor even have points, holy cow!
Old February 18th, 2018, 06:04 PM   #15
Ceeloo Yello
Motorcycle(s): 250
I blame it on having E10 for gas & the fact that I don't ride as often as I should,
my 2007 has less than 7000 miles on it. As far as tuning being a non oem efi computer makes thing a lot easier.
Old February 18th, 2018, 07:43 PM   #16
Try adding some Stabil 360 treatment for ethanol gas, and drain the floatbowls if it's going to sit for a while.
Old February 19th, 2018, 06:19 AM   #17
Cafe Racer
When I know I will not be riding for a week of so I run the carbs dry. The exception is the Harley. No shutoff valve I can see. You have to disconnect the fuel line which I would not do.
Old February 20th, 2018, 12:46 PM   #18
Ceeloo Yello
Motorcycle(s): 250
Thank you,
both are good things to try.
what is the best idle screw mixture vmax 2008 - 2012 Ninja 250R Tech Talk 9 July 1st, 2017 10:45 AM
Air fuel mix thumb screw 02337 1986 - 2007 Ninja 250R Tech Talk 7 November 21st, 2013 09:37 PM
Mixture screw turns. simook 2008 - 2012 Ninja 250R Tech Talk 7 October 13th, 2013 07:26 PM
Enrichening the Fuel Air Mixture? Scattcatt 2008 - 2012 Ninja 250R Tech Talk 28 September 22nd, 2011 06:27 PM
Wanted: Air mixture screw washers and O-rings dtmbcorp Items Wanted 2 August 4th, 2010 10:51 AM
