Old April 29th, 2020, 02:15 PM   #1
Jrey
Motorcycle(s): 2016 kawasaki ninja 650 ABS
Post 2016 kawasaki ninja 650 ABS hesitating after 5k rpms in any gear
Hey
I have a 16 kawasaki ninja 650 ABS 11k miles with full Yoshimura exhaust, K N high flo air filter (1 month old) and power commander V. Oil change and spark plugs done 2 months ago. Recently i road on higher elevation and came back down...rode some more and bike started hesitating, jerking like motion. Any suggestions on what it could be?
Jrey is offline   Reply With Quote
Old April 29th, 2020, 03:18 PM   #2
ducatiman
ducatiman's Avatar
a bad load of fuel perhaps? I'd purge and change for fresh first thing before digging deeper.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old April 29th, 2020, 03:22 PM   #3
psykown
Motorcycle(s): 2007 Ninja 250 "sold" 2014 ninja 300 "Gold" 2000 DRZ400S (Sold the POS) K7 GSXR600 (Also POS...see a pattern?
When my Husky TE510 had that issue it was some wiring that had the insulation rubbed off and was grounding out on the frame.
psykown is offline   Reply With Quote
Old April 29th, 2020, 03:30 PM   #4
ducatiman
ducatiman's Avatar
keyboard diagnosis so difficult to precisely nail....tantamount to guessing, throwing general possibilities.
faulty wiring issues a bit of a stretch on a '16 650 with just 11K.....no?
Custom Carb Service
Old April 29th, 2020, 03:33 PM   #5
psykown
Agreed, just stating that I had similar issue with similar mileage (granted with a lot of aggressive offroad and some tracktime)
on the flip side ive never in 6 years or so of riding had an issue with bad gas either or known anyone under the age of 50 or so to have had that issue either lol
Old April 29th, 2020, 03:35 PM   #6
psykown
actually that year I believe had a stva, i had a similar issue with my GSXR600 and it was that. Might be an easy thing to check?
Old April 29th, 2020, 04:53 PM   #7
Originally Posted by Jrey View Post
Hey
Did you gas-up at high elevation?
As ducatiman suggested, I'd start by draining the tank and refilling with fresh gas from your local station.
Easiest thing first.
Having a Power Commander increases the variables if fuel isn't the issue.
Old April 29th, 2020, 08:37 PM   #8
Do you have O2-sensor bypassed?
Old April 30th, 2020, 08:50 AM   #9
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
on my 2012 650, the fuel pump started going out at about 11,000 miles. would lose power at higher rpms. when i pulled the pump i found the filter sock full of dead ants. swapped the filter with no change. i guess the clogged filter starved the pump and killed it. as for the ants?? who knows
gantt is offline   Reply With Quote
Old April 30th, 2020, 08:56 AM   #10
ducatiman
ducatiman's Avatar
Ants inside a Kaw 650 fuel pump filter? SO glad I bought the Honda
Custom Carb Service
Old April 30th, 2020, 09:29 AM   #11
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Does it do it consistently? When it does it, does it do it in neutral when stationary ?
I had a similar issue on my VFR & it was down to a bad earth, but it only did it randomly, but was consistent when it did.
