Old May 1st, 2023, 12:13 PM   #1
teh_d3th_st4r
Squid Hunter
Motorcycle(s): 1986 GPZ250R, 1990 Yamaha FZR400, 2002 Ducati 748
Rear Shock Question for 86-87
I prowled around the forum looking for an answer, but came up with nothing.
I have an 86 and the suspension is super tired.
Will the 08-12 rear shock bolt in like it does with the pregen?
I already bought stiffer fork springs and 15w oil.
Last futzed with by teh_d3th_st4r; May 1st, 2023 at 12:18 PM. Reason: image link
teh_d3th_st4r is offline   Reply With Quote
Old May 1st, 2023, 12:56 PM   #2
teh_d3th_st4r
Squid Hunter
Also, will the 13-17 300 shock work?
That would give me some dumber, more expensive, unnecessary optinons.
Old May 1st, 2023, 02:41 PM   #3
thedrewski86
thedrewski86's Avatar
Assuming the '86 is the same as my '05, yeah, they bolt right up. I run a 300 shock and did zero modding to fit it. It's not a bad upgrade either.
Don't think, look!
Old May 1st, 2023, 02:44 PM   #4
teh_d3th_st4r
Squid Hunter
I don't have a pregen to compare it to.
Just looking for someone with an OG Ninjette that knows for sure.
Old May 1st, 2023, 03:16 PM   #5
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
From what I can see online, it looks like the '86 uses a very similar shock (a lot like the EX500 design, with threaded preload adjuster) and it says the length is about the same. If it were me, I'd try it.
My understanding is that the 300 uses the same shock as the NewGen, possibly with slightly different valving inside. Either one should work the same for a swap.
Old May 1st, 2023, 03:54 PM   #6
teh_d3th_st4r
Squid Hunter
Well, I guess the worse case scenario is that I have a spare shock laying around for the next pregen 250 I turn into a canyon carver.
Now all I need is a single sided exhaust (literally almost bought a whole bike because it already had a Muzzy installed)
Old May 2nd, 2023, 12:07 PM   #7
Which spring did you buy? For pre-gen or new-gen shock?
Check out my comparison here: https://www.ninjette.org/forums/showthread.php?t=337292
Best to stick with existing shock for its smooth preload-adjusters. Much better than new-gen or 300 design with just 5-click adjustment.
Old May 2nd, 2023, 08:30 PM   #8
teh_d3th_st4r
Squid Hunter
I'm gonna get a shock from the 300. Little stiffer and a little taller.
The rear shock is completely shot, and I'm a little too heavy for the bike anyway (~200lbs) I'm also not taking it racing or anything, just a little casual shredding.
Old May 2nd, 2023, 09:33 PM   #9
teh_d3th_st4r
Squid Hunter
The pregen muzzy pipe fits on this thing, right?
I'm having a hard time even finding a picture of an 86-87 with a single sided exhaust.
Old May 22nd, 2023, 11:31 AM   #10
teh_d3th_st4r
Squid Hunter
LOL, the fork springs from race tech can't fit inside 86/87 fork tubes.
Dude in customer service is all:
"My spec sheet says they're supposed to be 36mm or 37mm"
So I sent him a picture of my calipers showing 35mm...
"You sure someone didn't swap forks at some point?"
DUDE, just update your database. I don't even want to return the springs. I'll definitely own another pregen at some point.
Gixxer rear shock question - rear stiffness too high cookiebug79 2008 - 2012 Ninja 250R Tech Talk 20 January 17th, 2015 08:19 AM
Rear shock question LoneRonin 2008 - 2012 Ninja 250R Tech Talk 5 September 22nd, 2014 03:09 PM
rear shock question ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2010 05:43 AM
Quick rear shock question demp 2008 - 2012 Ninja 250R Tech Talk 6 May 11th, 2010 12:14 PM
ZX600 Rear Shock Question krbreton 1986 - 2007 Ninja 250R Tech Talk 4 June 15th, 2009 11:31 AM
