Old May 10th, 2015, 03:58 PM   #1
ROB654
Motorcycle(s): 08 NINJA 250,EX500,YSR50,86 VFR750
08 Ninja 250 track build
Starting to work on my 250R I bought this winter. I've got a few boxes of parts to start putting on it. I need to safety wire and get it prepped for racing. It's been 20 years since I've done this. I need to figure out what I want to use for a front master cylinder and which tires I want to go with.
ROB654 is offline   Reply With Quote
Old May 10th, 2015, 04:47 PM   #2
Old May 10th, 2015, 06:48 PM   #3
snot
sammich maker
snot's Avatar
MOTM - Apr '15
^^ this guy is a great resource.
Old May 10th, 2015, 06:59 PM   #4
cuong-nutz
cuong-nutz's Avatar
HalfFast Racing Team
Old May 10th, 2015, 07:24 PM   #5
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
can't wait to see her on the track mate!! Godspeed to ya!
xXecuterXx2 is offline   Reply With Quote
Old May 11th, 2015, 07:48 AM   #6
ROB654
I think for tires I'm going with the Bridgestone BT-003. I was just wondering if I should go with 110 or 120 on the front.
Old May 11th, 2015, 04:25 PM   #7
fred smoot
fred smoot's Avatar
Motorcycle(s): 1996 Ducati 900SS/SP 45k miles
build . . .
I use the BT-003s with 110 front and 140 rear. It weighs less than a 120.
'09 Ninja 250R track only SOLD
"If everything seems under control, you're not going fast enough." -Mario Andretti
fred smoot is offline   Reply With Quote
Old May 11th, 2015, 04:53 PM   #8
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
110 front should work well
Old May 14th, 2015, 07:41 PM   #9
ROB654
I started the tear down. Also doing roller bearing in steering stem. I need to decide weather I'm going to gold valves and springs in the forks or s
Just springs now. I also need to figure which fork oil to go with
Old May 14th, 2015, 07:46 PM   #10
ROB654
I'm having fun
Old May 14th, 2015, 08:32 PM   #11
Go springs first, then drop in emulators or intimidators if you need more fine tuning. I went 10w oil but that may not work for you. Additionally, if you hit up different tracks that require you to adjust your suspension, preload adjuster caps may allow you to adjust it enough to get by without much hassle.
ninja 250r track toy build htndfw 2008 - 2012 Ninja 250R Tech Talk 17 February 10th, 2021 10:59 AM
Ninja 250 track build Braden07 Ninjettes At Speed 56 July 15th, 2015 12:44 PM
ninja 250 supersport build simook Ninjettes At Speed 124 August 20th, 2014 02:14 PM
Ninja 250 Build JMod45 1986 - 2007 Ninja 250R Tech Talk 8 January 20th, 2012 08:32 AM
My track/race 250 'build' switch Ninjettes At Speed 14 April 22nd, 2010 04:45 PM
