Old January 12th, 2019, 01:37 PM   #1
dodgerdad
dodgerdad's Avatar
California Naked Fighter
A few months back I bought a stock 2007 non-runner with the intention of making it my project bike. The bike is now running and maintenance has been done, many thanks to board members help on the tech forum. Originally I was going to go the cafe route but it looks like it will most likely fall between the category of naked and street fighter, hence the name.
This is my first post in which I'll be documenting the progress of my project. I will avoid reaching out for help here (i'll post separately on the tech board) so I can focus on completed modifications and installations. Wish me luck!
Here are the "before" photos after I got it home:
Old January 12th, 2019, 02:02 PM   #2
dodgerdad
dodgerdad's Avatar
Coilpack conversion
Since the bike will be pretty much naked I decided to ditch the ignition coils and mounting brackets for a cleaner look. I paid $28 for a pair of used coil packs and $9.95 for the wiring harness on Ebay.
It was a pretty simple swap, just involved a little soldering for the wiring and had to drill out the spot weld for the mounting bracket. After that I just cleaned up the metal that used to be covered up by the mounting bracket sprayed and it with gloss black spray paint.
1st official mod completed!
Last futzed with by dodgerdad; January 12th, 2019 at 09:47 PM. Reason: typo
Old January 12th, 2019, 04:46 PM   #3
Snake
Snake's Avatar
Good looking bike!
Old February 26th, 2019, 07:32 PM   #4
dodgerdad
dodgerdad's Avatar
Naked-er
I've been spending some time on cleaning up the body lately, almost done. Only thing left to trim will be the front portion of the rear fender then I'll move on to the rear frame section.
Here's an update with photos:
-covered up the tank screw holes
-trimmed the front fender
-removed back portion of rear fender
-removed rear seat latch assembly
-trimmed side covers/fairings
-trimmed saddle (will clean it up more once the tail light & seat fabric arrive)
Don't mind the zip tie & Home Depot'd lighting mounts I'm trying to keep it street legal throughout the process even if it's a little scary looking
Next on the list will be fitting the tail light, fastening down the saddle, and cutting the rear frame section. Oh and putting some plastic goods up for sale to aid the continued economic burden
On a side note, I've become rather eager to weigh this thing once I'm done. All the stuff I've removed from the bike seems to be adding up much more than I would have expected.
Old March 25th, 2019, 02:26 PM   #5
dodgerdad
dodgerdad's Avatar
Saddle up!
After an embarrassingly sticky, failed attempt at re-covering my saddle I swallowed my pride and dropped it off at a professional upholstery shop.
It actually looks like a real (small) saddle now that the foam isn't visible at the rear!
Last futzed with by dodgerdad; March 25th, 2019 at 02:27 PM. Reason: typo
Old March 25th, 2019, 06:05 PM   #6
Coming along very nicely!!!
Old March 25th, 2019, 06:59 PM   #7
Raddad70
Motorcycle(s): Honda cx650, 2005 ninja 250
Smile
Seat looks great! I will be upholstering my seat soon also a custom job. If you don’t mind me asking what did it cost
Raddad70 is offline   Reply With Quote
Old March 26th, 2019, 06:08 AM   #8
dodgerdad
dodgerdad's Avatar
I paid $70 at a small local shop. Seemed a bit high but I was too lazy to shop it around.
Old April 8th, 2019, 07:50 PM   #9
Milpool
Motorcycle(s): GPX250r (pregen Ninja 250)
Will be good to see it finished! I love how these bikes look all streetfighterised.
Milpool is offline   Reply With Quote
Old June 10th, 2019, 02:13 PM   #10
dodgerdad
dodgerdad's Avatar
Swingarm & exhaust
I stripped the swingarm then primed it with etching primer. After that it was black wheel paint followed by a wheel clear coat. I've finished up the exhaust so I decided to take it for a short ride this weekend before I wrap it.
The exhaust held up well but turned out much louder than I prefer so earplugs will be in order for future rides.
Next up will be ordering tires so that I can swap out my wheels with the black ones I have standing by. I plan to wrap the exhaust while I wait for my tires & have them mounted to the black wheels.
(Couldn't figure out how to rotate my photo )
Old June 10th, 2019, 07:16 PM   #11
Ceeloo Yello
Motorcycle(s): 250
Top notch work so far
Old June 21st, 2019, 03:20 PM   #12
dodgerdad
dodgerdad's Avatar
Wheelin'
I received my new tires in the mail, I bought the Shinko SR741 & SR740. This week I had the new tires mounted to my new-to-me black wheels (it had silver ones before) and swapped over the rotors. I hadn't planned on messing with the cush drive but I found the slop was ridiculous. I couldn't ignore it so I sacrificed one of my wife's tuperware lids and when to work. Turned out to be very easy work and now zero play.
I plan to scrub in the tires on some local canyon roads tomorrow. I'm very curious to see if I actually notice a difference now that I snugged up the cush drive.
Next up will be silicone spraying the exhaust wrap and then doing something about those unsightly rearsets.
Old June 21st, 2019, 09:26 PM   #13
I got those tyres on my street newgen. Really works well!
Put Ninja 300 rearsets on. Really improves the look! Doesn't have that machined industrial look that aftermarket rearsets have.
Last futzed with by DannoXYZ; June 22nd, 2019 at 07:27 PM.
Old June 22nd, 2019, 06:33 PM   #14
Raddad70
I second the 300 rearsets. I think the color would be a close match to your exhaust. Could you install some db killers or fiberglass batting to quite them down?
Old June 23rd, 2019, 08:00 AM   #15
dodgerdad
dodgerdad's Avatar
how are those tires holding up? I put 89 miles on mine yesterday to scrub them in.
Last futzed with by dodgerdad; June 23rd, 2019 at 08:00 AM. Reason: typo
Old June 23rd, 2019, 08:03 AM   #16
dodgerdad
dodgerdad's Avatar
Looks like the color would certainly match up well. I ordered the afermarket ones so we'll see how it goes.
As for the exhaust, there's no way to repack them without really tearing them apart. I haven't heard of DB killers, I'll look them up. Worse case, I may swap them out for aftermarket exhausts that have a removable baffle.
Old June 23rd, 2019, 02:25 PM   #17
Doesn't look like those mufflers can use noise inserts.
Not that difficult to drill out rivets.
Then wrap inner pipe with ceramic muffler packing.
https://www.amazon.com/dp/B011PW22DE/
Use safety-wire to loosely hold in position.
Stuff back into muffler.
Install new rivets.
Old June 23rd, 2019, 02:28 PM   #18
I've put about 2000-miles on mine. Barely tell they've been used. So I anticipate I can get 8-10k miles from them.
Old July 5th, 2019, 04:10 PM   #19
dodgerdad
dodgerdad's Avatar
Rearsets
Rearsets are finally installed. They were a true test of patience because they do not come with instructions, just a diagram of how they look once assembled. Assembly took some trial and error, then came installation. Installing them took some time to ensure the right hardware was used and installed in the right order.
I got them them fitted hand tight and adjusted so this morning I removed them, disassembled them, applied loctite on all the fasteners, torqued everything down and reinstalled them.
Hope to take them for a quick spin tomorrow.
Old July 25th, 2019, 03:24 AM   #20
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
I ditched the skinny front tire for a 120. You also have to ditch the front fender or fab one.
Cafe Racer is offline   Reply With Quote
Old July 25th, 2019, 06:14 AM   #21
dodgerdad
dodgerdad's Avatar
My fender is trimmed (not widened, though) however I went with the stock tire sizes.
Old August 18th, 2019, 05:43 AM   #22
dodgerdad
dodgerdad's Avatar
Clip-ons
Installed new clip-ons yesterday. Task was a bit more tedious than I had expected due to cutting the bars, drilling them and adjusting them. Once in proper position, with grips installed, each screw was removed individually for Loctite and then reinstalled and torqued.
I had anticipated an "unfinished" look so I had ordered some large body plugs to use as caps on top of each clip-on which I think cleaned things up a bit.
Photos show clip-ons without and with the caps.
Old August 20th, 2019, 07:48 AM   #23
dodgerdad
dodgerdad's Avatar
De-evapped!
Had some time to kill this weekend as I wait for my new headlight so after having run the bike a few weeks with the evap system bypassed (but all parts still installed) I removed the system. This was done strictly for aesthetics as the bike is naked exposing the ugly evap equipment. Easy way to clean up the left side of the bike.
Old September 5th, 2019, 07:07 AM   #24
JasonJ
Motorcycle(s): 1980 Yamaha XS850G Midnight Special, 32k Miles; 2000 EX250F, <5000 Orig Miles
Were those the Ninja 300 rearsets you used, or some aftermarket ones? They look great, as does the entire bike!
JasonJ is offline   Reply With Quote
Old September 5th, 2019, 08:23 AM   #25
dodgerdad
dodgerdad's Avatar
Thanks.
I used aftermarket rearsets designed for the 250/300 (same fit as pregen).
Old October 2nd, 2019, 08:57 PM   #26
LadyGogo75
Name: Ladylyn or Lyn
Motorcycle(s): 2010 Yamaha FZ6 S2
It looks really cool. I also did that before when I had a Ninja 300 back in 2010.
LadyGogo75 is offline   Reply With Quote
Old January 3rd, 2020, 03:47 PM   #27
zhowfast
New"ish" Member
Motorcycle(s): 2000 Ninja 250
Have any updates on this project? I am digging the pipes! Where did you get them and what brand are they? Do you think they would fit well on a bike that still has stock fairings? They look angled in pretty sharply towards the tail.
I didn't know what I didn't know 'til I knew it
zhowfast is offline   Reply With Quote
Old January 4th, 2020, 06:54 AM   #28
dodgerdad
dodgerdad's Avatar
Thanks for the compliments. The project is done, just haven't had time that coordinates with good weather to take it out for a spin and snap new photos. Hoping to shoot some photos next week.
The exhaust cans might fit with stock fairings if they don't bump the tailsection, you'll just have to remove the rear pegs. With custom stuff it'll take some measuring and testing (and frustration). Keep in mind that you need to create a an adapter for it to slip on to the existing exhaust pipe because the cans are titanium and can't be welded to steel. I'll post the exhaust link below.
https://www.amazon.com/gp/product/B0...ldnSite=1&th=1
Old January 4th, 2020, 08:23 AM   #29
Not titanium, especially for that price.
  • The exhaust is made of aluminum with stainless steel connector
  • Hexagon shape looks very attractive and cool
  • Stainless Steel Welding Adaptor Allow To Fit Pipe 38mm - 51mm
  • It Is Universal Muffler Can Be Used For Dirt Bike, Street Bike, Scooter, ATV, Quad And Any Other Bike With Pipe Diameter 38-51mm
  • ¡ïManufacturer warranty for 90 days from date of purchase
Old January 4th, 2020, 08:26 AM   #30
zhowfast
New"ish" Member
That doesn't seem too hard... I am not a huge fan of the stock exhaust I'll see what it takes and maybe post some pics!
Old January 4th, 2020, 08:26 AM   #31
It comes with this cone-adapter which can fit most exhaust tubing. You'll need to make middle section that reaches forward and connects to where stock header pipes end.
Old January 4th, 2020, 08:32 AM   #32
Easiest way is to mount muffer first (note custom brackets in photo above). Once muffler is fixed in 3D-space, you can them make middle section that connects to header pipes.
I'm not fan of that conical adapter because it doesn't have positive seal with lots of surface-area. It'll leak unless it's welded to mid-pipe section as final step. Check out how stock and various aftermarket exhausts are desgined on pre-gen/new-gen bikes. I have comparison here: https://www.ninjette.org/forums/showthread.php?t=338180 . Best solution is conical mid-pipe that continuously expands to muffler-inlet diameter as that'll maximize performance. Tyga exhaust is best for new-gens, makes most power-gains of +22% more than stock!
Some photos (ones that survived Photobucket purge) and videos of using that cone-adapter to fit universal mufflers to various exhausts. Stock and Tyga exhaust. Had to trim off tip of 38mm cone to fit Tyga 42.5mm exhaust pipe. el cheapo muffler from ali #2
Old January 4th, 2020, 09:40 AM   #33
zhowfast
New"ish" Member
I knew a continuously expanding "cone" is ideal for more performance and if I could have it my way I'd like to go with a full system. There aren't too many options for first-gen ex's. Their either discontinued or used (which isn't a terrible option). I looked at your comparison and had a thought. As long as the exhaust port side of the system is the same diameter or close would any aftermarket full system work? I saw some of the ones you pictured were like that. The only difference I saw was the header length and the route they took towards the back of the bike. That maybe be a stretch but I am generally clueless when I comes to exhaust systems/ exhaust compatibility and I don't have access to a welder so I can't really piece something together. I guess the biggest question is:has the basic shape of the 250cc engine changed that much over time to where I couldn't make it work? I also like your idea of mocking it up from the muffler towards the front of the bike...
Old January 4th, 2020, 03:36 PM   #34
dodgerdad
dodgerdad's Avatar
That's exactly what I thought as well, but my welder confirmed it.
Old January 4th, 2020, 11:55 PM   #35
Why would anyone selling titanium muffler not market it as such? And charge at least $200? That is wholesale cost of Ti muffler based upon materials cost alone. I assure you, no one at factory is mistakenly selling mufflers for $10 when it costs them $200 in materials.
You need new welder.
Last futzed with by DannoXYZ; January 11th, 2020 at 04:11 PM.
Old January 9th, 2020, 12:47 PM   #36
What you can do without welding is to make mid-pipe that fits both ends as best as possible and use hose-clamps to hold together. Once you have muffler in place, measure length and bend-angle needed to join to header. Get pre-bent tubing similar to this: Amazon - muffler tubing. Size ID so it fits snuggly over header outlet. Cut 2" slit lengthwise with hacksaw so you have 2x 180-degree sections. Slide over header-outlet and tighten with hose-clamp.
On muffler end, get step-up adapter with 2.0" OD to match inlet of muffler. Or 38mm OD to match inlet of cone-adapter. Scan Walker and Dynomax catalogue to find adapter that matches what you have. Amazon - muffler pipe adapters
Once you've gotten everything cut and fitted with no gaps and no straining. Take entire bike with all exhaust pieces fitted to welder and have them join it all together. No leaks or rattling. I usually charge $100 to TIG-weld 2x exhaust mid-pipe sections. If pieces are well-fitting, I just tack it together on bike before taking off. Then fully weld it off bike. Takes about 30-minutes for dual-exhaust system.
Stock street fighter/ naked headlight? Sharkride 2008 - 2012 Ninja 250R Farkles 1 November 1st, 2015 01:19 PM
