Old March 9th, 2020, 01:30 PM   #1
Chloebelle
Meowtercyclist
Chloebelle's Avatar
Motorcycle(s): Harumi, 2007 EX250F
"Harumi" Updates and Concerns
Hi all! It's been a while since I've posted anything, but I'm slowly getting back into riding after multiple... Issues.
Late last year while riding to work, she was struggling hard to react to throttle (sputtering, intermittent power jumps), and then when she finally started to "wake up"... The damn chain hopped off and wrecked the tension adjusters.
So, recent work done:
-New chain and sprockets (actually managed myself, though a bit of a pain)
-Carbs cleaned and valves adjusted by a local shop (they were highly recommended by a friend, and Harumi definitely runs better now)
At present, I'm in need of a new front brake rotor, and was hoping to get some recommendations on where to get one, and what make/model. Aside from used and aftermarket stuff on eBay, I'm not finding a lot of info. I'm just looking for a decent OEM replacement, nothing to high-performance as I'm just a daily rider, and not into racing/GOTTAGOFAST. :P
Also: She's still having issues with losing power at high throttle, and I'm struggling to get her up over 40mph. She has an aftermarket air filter and box (K&N pod filter, like that when I got her), and the shop mentioned it may be due to the carbs not being properly jetted. Were there any other potential causes of this or cheap fixes? I'm not against switching her back to an OEM filter/airbox setup. A coworker who rides mentioned it may be a fuel delivery issue (clogged petcock or something)?
I'm kinda at a loss here and knowing what the best solution for either of these issues is. @__@
Chloebelle is offline   Reply With Quote
Old March 9th, 2020, 04:44 PM   #2
If it's not going over 40 mph, it's a pretty significant problem. My guess is one of the cylinders isn't providing any power at all. You can confirm by pointing a laser temp at both front exhaust ports after it's been running for awhile to see if one's much warmer than the other. Looks like Amazon isn't selling the exact same cheap one I picked up a few years ago, but this one looks close.
Old March 9th, 2020, 06:37 PM   #3
Chloebelle
Meowtercyclist
Chloebelle's Avatar
I'll definitely look into that! To clarify a bit, I CAN get her up past that, but she struggles to maintain speed as too much throttle seems to kill any power she has (revs drop significantly). I attempted the freeway the other day and got her up to 60, but it took a bit and she struggled at the top end.
These issues weren't as bad (or perhaps just not as noticeable) before I swapped out the sprockets, but the rear ended up being a different size meant to give more top-end speed... And 'top-end' is where she struggles. Might have to swap that back out for a larger one... (it was recommended by a friend, and I failed to realize the size difference until it was too late... OOPS).
Old March 9th, 2020, 10:25 PM   #4
Stumbling and struggling at high-end with large throttle-openings isn’t due to improper jets, but clogged carbs. Do search for “clean carbs ducatiman” to see numerous other bikes with similar issues (clogged carbs from sitting more than 3-months). Solution is to have them restored to factory fresh clean.
BTW - good to have you back!
Old March 12th, 2020, 12:59 PM   #5
Chloebelle
Meowtercyclist
Chloebelle's Avatar
So, what your saying is... the local "reputable" shop ripped me off and did a **** job? Wonderful... -__-
Hell, at this point I'll just try de-gunking via Seafoam. Worked last time... Well, before the chain hopped of and she had to sit for a few more months.
My next big spend for the bike needs to be front brakes (pads+rotor). Just need to figure out what rotor to get for her.
Old March 12th, 2020, 08:58 PM   #6
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
We had my hubby's bike in a local shop, and they couldn't clean the carb for crap, either. Took it to a local guy who had a hobby cleaning them and he got it right first time. Go figure.
Old March 13th, 2020, 06:41 AM   #7
ducatiman
ducatiman's Avatar
The old man type were brought up *needing* to learn and understand carbs.
The younger "FI generation" maybe not so motivated.
This old man here currently working on a 47 year old Keihin carbset from 1973 Honda 750 Supersport, returning to fully functional after neglect and abuse.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 13th, 2020, 06:49 AM   #8
It's worth a shot, but I'd try Techron Concentrate (1oz per gal) instead of Seafoam.
A better product, and stronger cleaner, IMO.
Old March 13th, 2020, 07:01 AM   #9
Sorry to hear you are still having problems after trusting your cycle to a respected shop.
Don't these "expert" shops take the cycles for a ride to see if they operate correctly? What kind of "professional" mechanic doesn't go for a test ride after major repairs?
It sounds like the carbs are not completely clean or adjusted properly. The jetting should be fine even with that filter, and it should pull all the way to redline and top speed if everything is correct. The petcock should be checked for flow (inside of the tank checked for debris as well), and also checked that all the lines are connected correctly.
Your gearing change isn't making it run poorly. It may decrease the acceleration somewhat, but it isn't going to make it run poorly, not rev completely, or not reach highway speeds.
I would take it back to the shop and tell them to fix it right - and test it before they tell you it's fixed.
Riding it in this condition is too dangerous.
Old March 15th, 2020, 11:07 PM   #10
Chloebelle
Meowtercyclist
Chloebelle's Avatar
I just may do that...
It was actually an older gentleman who runs the shop, and they did in fact fail to test ride... Or they would have noticed that it couldn't shift into gear and had that fixed BEFORE I showed up.
Some updates: I found that I can still accelerate up to even freeway speeds, it's just that there's a weird "dead zone" in the throttle. When I pull past it she starts getting power again. O_o
I'll try and clean/replace the petcock setup in addition to checking the temperature of the cylinders as Alex suggested.
Old March 16th, 2020, 07:06 AM   #11
That still suggests a carb issue.
A problem with the petcock or screens/filters usually shows up as a shutdown (for lack of fuel) after some run-time. After waiting a bit the engine will run again as the floatbowls refill (slowly).
You shouldn't experience a big "flat spot" that you need to get past. The Ninja's mid-throttle mixture is typically lean, but it should still run decent. Adding shims to the needles to raise them and richen the midrange is the typical easy fix. That is more likely to be needed if you go to a less restrictive air filter - so you may benefit from it.
When you pay a pro to get your cycle running right they should find and correct major running issues before delivering the cycle.
After service your cycle should have run like new - if everything was done correctly.
[superbikeplanet.com] - Back in Stock & Shipping: "Roberts" and "Lawson" Yamaha Art P Ninjette Newsbot Motorcycling News 0 March 13th, 2015 01:40 PM
[roadracingworld.com] - Triumph Updates "Classics" For 2014 Ninjette Newsbot Motorcycling News 0 October 3rd, 2013 11:10 AM
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl Ninjette Newsbot Motorcycling News 0 August 16th, 2012 04:30 PM
[sportrider - latest stories] - Chris "Teach" McNeil stars in "New Hire". Ninjette Newsbot Motorcycling News 0 March 5th, 2012 04:50 PM
[roadracingworld.com] - AMA Pro Racing Updates The Sunoco "Go The Distance" Award Ran Ninjette Newsbot Motorcycling News 0 July 21st, 2011 07:00 PM
