Old March 11th, 2010, 12:53 AM   #1
Davidb1986
Davidb1986's Avatar
Motorcycle(s): 2009 Ninja 250r SE green with Monster energy decals!!!
Tire pressure....
Ok I misplaced my owner's manuel so I'm going to ask a really stupid question. What is the tire pressure suppose to be in my 09 ninjette?
Davidb1986 is offline   Reply With Quote
Old March 11th, 2010, 01:00 AM   #2
Ramen
Frak It
Ramen's Avatar
28 up front, 32 in back.
It's also listed on that black plate attached to the swingarm.
Ramen is offline   Reply With Quote
Old March 11th, 2010, 01:00 AM   #3
Momaru
Momaru's Avatar
Standard is 28psi up front, 32 in the rear. I think it's on the checklist sticker under the pillion seat. Also, here's a link for an electronic owners manual
http://www.ninjette.org/forums/showthread.php?t=38832
Proud member of the Blue Army
Old March 11th, 2010, 01:01 AM   #4
Davidb1986
Davidb1986's Avatar
I should have remembered that is was on the check list but had a brain fart. The pain meds I'm on for my back injury does that to me.
Old March 31st, 2010, 08:38 PM   #5
Reswob
Reswob's Avatar
Motorcycle(s): 2008 Triumph Bonneville Black
Is 28/32 for Kawi's so called "average" 150lb rider? I weigh a good bit more than that, I'm thinking I should set it a little higher?
Reswob is offline   Reply With Quote
Old April 1st, 2010, 11:11 AM   #6
kevlarorc
noob motovlogger
kevlarorc's Avatar
Motorcycle(s): Black 2009 250r
Oh wow. I've had mine way too high. I had just looked on the sidewalls and I could swear it said 36 psi both front and rear. Gonna have to go adjust that lol
My Motovlog
"Damn, either shimming the needles fixes 90% of any problems with the 250Rs, or kkim owns stock in a washer manufacturer." -DmbShn41
kevlarorc is offline   Reply With Quote
Old April 1st, 2010, 12:20 PM   #7
you are reading the tire's max tire pressure. You should set the pressures to whatever the manufacture recommends on a sticker on the vehicle.
that being said, I run 28/28 on my bike.
Old April 1st, 2010, 06:15 PM   #8
Samer
Samer's Avatar
Motorcycle(s): 09 Ninja 250R SE
My dealer sets the pressure very high. 40 psi at the back wheel and slightly less at the front. I told them that the manual says 28/32 and they said the tire wear is reduced with higher pressure. Of course that is true but you get less traction too. So I've been setting my tires 2 psi more than the manual 30/34, roughly. The uncertainty on my gage is probably 1 or 2 psi anyway.
Samer is offline   Reply With Quote
Old April 3rd, 2010, 10:28 AM   #9
2WheelGuy
2WheelGuy's Avatar
The manufacturers recommended pressure is for the most extreme conditions they expect the bike to see, i.e. max load, worst roads, extreme temperatures, etc. They are also chosen to maximize tire life. I many cases the pressures are higher than the typical American sport bike rider will need, i.e. solo rider, good roads, moderate temperatures, aggressive riding. Most of us will sacrifice a little tire life for additional traction. That being said the recommended pressures for the 250 Ninja with OEM type tires is very close. I run 28-29psi front and 30-32psi rear depending on conditions.
On the new-gens with quality aftermarket tires pressure requirements can change drastically. It is best to check with someone knowledgeable with your type of tire. (The manufacturer web sites are little help.) For example I use 25psi front and rear with my Bridgestone BT-003 tires. I don't think you will find that published anywhere.
AFM #278
Old April 3rd, 2010, 10:53 PM   #10
Cedilla
Cedilla's Avatar
Motorcycle(s): 2009 Ninja 250 (sold)
I've been running 32 front, 34 rear. I had no idea what they were supposed to be. Seems to work fine for me. Should you run higher pressure in a radial, vs a bias ply?
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink
Cedilla is offline   Reply With Quote
Old April 4th, 2010, 09:33 PM   #11
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Wow is dealer charging by the pound?
Old April 13th, 2010, 06:40 PM   #12
ScorpionNinja
ScorpionNinja's Avatar
Just dont use "Firestone tires"
wait... that was only Fords with Firestones years back!
As for me,
Im about 180lbs.
My tires PSI
Front 28
Rear 30
Old April 13th, 2010, 08:18 PM   #13
Momaru
Momaru's Avatar
Originally Posted by ScorpionNinja View Post
Jwait... that was only Fords with Firestones years back!
Hehe, yeah... I remember that. Incidentally I've got a Ford with Firestone A/T tires on it at the moment, wonder if I should go check 'em
Old May 21st, 2010, 02:16 AM   #14
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
I've been checking my tire pressures once a week-fortnight, and I've noticed something that has got me quite disturbed. My rear tire goes from 32 psi to 17-20 psi whereas my front goes from 30 psi to 24-26 psi. I was just wondering if the drop in pressure from my rear tire was normal?
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old May 21st, 2010, 03:03 AM   #15
Not normal. Something going on with that tire, either a leak somewhere near the tire surface, or perhaps a bad tire valve.
Old May 21st, 2010, 04:01 AM   #16
miks
I'm lovin' it.
miks's Avatar
I assume there is only 1 fix, buy a new tire?
Old May 21st, 2010, 04:56 AM   #17
Thrak
Motorcycle(s): Lots
If the tire is bad, yes...
But it could be the valve stem leaking, in which case your tire is good.
Thrak is offline   Reply With Quote
Old May 21st, 2010, 08:14 PM   #18
miks
I'm lovin' it.
miks's Avatar
If my valve stem was leaking, can this be fixed?
Old May 21st, 2010, 08:21 PM   #19
Yup, they are cheap as heck and are often replaced every two or three tire changes anyhow. First thing to do is find where the leak is coming from.
Old May 21st, 2010, 09:03 PM   #20
where is the leak? If from the center portion of the stem, you can easily change the valve stem core with a new one and it should fix the problem.
If this is the problem, do you use valve stem covers/caps? If not, I highly recommend you do. This could very well be causing you your problems if you're not.
Old May 21st, 2010, 09:24 PM   #21
miks
I'm lovin' it.
miks's Avatar
I don't know where my tire is leaking, I do have a couple of small indentations on my centre tire surface that could be the cause. I do use valve stem caps, but I might change them to see if it affects it somehow. Ill try take a couple of pics of what small indentations Im talking about.
Old May 21st, 2010, 09:30 PM   #22
Xoulrath
Xoulrath's Avatar
Motorcycle(s): Current: '11 ZX-6R; Previous: '09 Ninjette; '08 ZX-6R (Ex-Wife '09 TU250X)
I set my tires to 30 front and 32 rear. The front feels a bit soft if I don't set it higher and the rear seems to give me enough traction at that pressure and should keep tire wear at bay.
Xoulrath is offline   Reply With Quote
Old May 21st, 2010, 09:33 PM   #23
use a soap/water solution in a spray bottle or brush it on where you think the leak is. When you find it, you'll see a small stream of bubbles coming out. Let us know where it's leaking from.
Old May 21st, 2010, 09:40 PM   #24
miks
I'm lovin' it.
miks's Avatar
Yeah I'll try it out now, but here are a couple of pics of the indentations on my tire. Sorry for the crappy quality, phone camera was used.
Is there anywhere where I can find out how to remove and replace valve stem caps?
Old May 21st, 2010, 09:50 PM   #25
miks
I'm lovin' it.
miks's Avatar
Okay I found the leak, its coming from the exact same indentation pictured above. I checked all the other indentations but they were fine. Is there another way to fix this apart from buying a new tire?
Old May 21st, 2010, 09:53 PM   #26
Reswob
Reswob's Avatar
Go to your local auto parts store and get get a valve core remover, and a new valve core. The remover is like a screwdriver with a special tip. You just stick it on the valve core and turn it counterclockwise and unscrew it.
Just remember, removing the valve will LET ALL THE AIR OUT OF THE TIRE!!! Have the bike up on rear stands before you do this.
EDIT: For a puncture in the tire, you can usually plug it. I wouldn't trust a tire plug on a motorcycle myself....
'08 Bonneville Black
sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator
Old May 22nd, 2010, 01:36 PM   #27
That type of puncture looks like new tire time to me. I'm fine with plugging nail/screw holes, but that looks like a cut from a larger piece of debris.
Old May 22nd, 2010, 01:40 PM   #28
plug it for now (have someone very experienced at plugging tires do the work) and start shopping for a new set of tires. You wanted to get rid of those IRCs anyway, right?
Old May 22nd, 2010, 08:12 PM   #29
miks
I'm lovin' it.
miks's Avatar
Would love to get rid of these IRCs but tires down here cost an arm and a leg. Will internally plug it for now at the shops and start looking around I guess.
If only there were people getting rid of some used tires down here
Old May 23rd, 2010, 11:53 PM   #30
miks
I'm lovin' it.
miks's Avatar
Took it to the shop this morning to get it plugged, came back after Uni to pick it up and guess what ... the guy said there wasn't a leak. It was perfect, he did everything to check, put the tire in a crate of water, pumped it to 40 psi and left it for 2 hours to see if the pressure would drop, nothing. He was nice enough to do this all for free, but I seriously don't know now ... I'm going to check my pressures every few days for a while to suss it out.
Old May 24th, 2010, 12:58 AM   #31
how did you check it the first time?
Old May 24th, 2010, 12:59 AM   #32
miks
I'm lovin' it.
miks's Avatar
2 methods.
1. Soapy water over the area
2. My spit over the area
Both times they were bubbling and showed signs of a leak.
EDIT: Let me make it more clear, the first time I would soapy water over the area, I could see bubbles forming and getting bigger, same with my spit.
Tire pressure gauges Soujyu General Motorcycling Discussion 44 April 4th, 2015 07:20 PM
Best tire pressure ... Davis937 1986 - 2007 Ninja 250R Tech Talk 17 February 17th, 2014 02:25 PM
Once more... recommended tire pressure AlexCWO 2008 - 2012 Ninja 250R Tech Talk 6 June 4th, 2013 11:36 AM
Tire pressure + Handling FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 4 March 28th, 2013 04:05 PM
Bt-45 tire pressure indr 2008 - 2012 Ninja 250R Tech Talk 1 July 5th, 2011 09:05 AM
