Old June 29th, 2014, 10:29 AM   #1
NinjaNinja2012
Motorcycle(s): 1969 CL175, 2012 Ninja 250R
Suspension Upgrades - For a skinny mof**ka
hello errrbody!!! so i am not satisfied with the way my ninja is handling....it seems as though the suspension is nervous in front and rear and will not hold itself very smoothly through a corner....I am pretty sure this is because of my weight, i weigh a WHOPPING 130lbs in full gear......what can I do about this, I really want to feel like this thing is just gliding and I have full confidence in it I just haven't been able to get there!!!! any suggestions would be enormously appreciated!!!!
NinjaNinja2012 is offline   Reply With Quote
Old June 29th, 2014, 12:03 PM   #2
Congrats, you're the same weight as me. I just got finished installing Ricor's Intiminators and 5w oil. I've had 0.585 springs in the forks for a while. No riding impressions yet, as I don't have a front wheel on it, but the ride was very promising (albeit a bit too firm) with 10w oil. Very excited to see how it feels now.
Old June 29th, 2014, 11:15 PM   #3
NinjaNinja2012
skinny dudes rule
great to meet u brother!!! its a hard knock life for us skinny dudes....lol so i just scoped out those intiminators and it appears as though they don't make any for my year.....bummmer......let me know how it rides after you get that front wheel on!!!
Old June 29th, 2014, 11:45 PM   #4
Kscreations08
Fresh Deli Meat
Kscreations08's Avatar
Motorcycle(s): 2009 250R Ninja -Neener-
Skinny guy thread!!
Lol It's def a hard life gentlemen. How about finding pants?! Am I right? I am doomed to wear a belt for my entire life
We shall call thee "Seahorse." -Antiant on Couvade Syndrome
Kscreations08 is offline   Reply With Quote
Old June 29th, 2014, 11:49 PM   #5
You all suck.... Imma strap 45lbs to your bike next race.
Old June 29th, 2014, 11:55 PM   #6
Kscreations08
Fresh Deli Meat
Lol Csmith, I think it'll be a long time before my weight difference has me coming any where near you in a race. Those corners though. FOSHIZZLE!
Old June 30th, 2014, 01:01 AM   #7
NinjaNinja2012
Forsaken to a life of belts my skinny brotha!!! so rough!!! lol Sooooo I've been doing some research and this is the package im gonna go with from racetech!! all specified for my weight...once i get the money together lol
Gold Valve Emulators: FEGV S3501
HP Fork Springs: FRSP S2838
Gold Valve Shock Kit: SMGV S3601
Nitrogen Fill Bolt: SPNV 0512
HP Shock Spring: Now Available
"I don't know the key to success, but trying to please everybody is the key to failure." -Bill Cosby
Old June 30th, 2014, 01:15 AM   #8
Kscreations08
Fresh Deli Meat
^^^^I just heard a really loud CHA-CHING noise when I read that, That has to take some bank
Old June 30th, 2014, 11:29 AM   #9
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
They'll fit. I have them in my bike with the same size forks (uses the same FEGV S3501 emulators).
According to RT's calc, the rear is sprung for about 220lb, while the front is too soft even for a tiny person like you. Just swapping to springs with the correct rate should help a ton, even without the fancier parts.
Last futzed with by InvisiBill; July 2nd, 2014 at 08:51 AM. Reason: Fixed link
Old June 30th, 2014, 04:48 PM   #10
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Seems swapping to an r6 or zx6 forks would be easier (and maybe cheaper)
PS - I like being skinny!! I can eat anything I want and never gain an oz!
Old June 30th, 2014, 04:52 PM   #11
130lbs is what the bike was designed for. if its stock suspension, check your tires. they're probably old, dry rotted, and out of round.
Old June 30th, 2014, 05:04 PM   #12
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
@choneofakind where did you get your springs?
Old Lemon is offline   Reply With Quote
Old June 30th, 2014, 05:49 PM   #13
Lol, the bike is still squishy with a 130lb rider, especially when you get on the brakes. diiiiive.
Anyhow, my springs are from the ex500. RT says I should use a 0.64 or something but I figured a tad soft for street was fine. Stock is 0.44, 0.585 is much better. I'm working on improving that damping with the Intiminators.
Old June 30th, 2014, 06:55 PM   #14
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
i doubt it is your weight, you are actually under the weight for the springs. more then likely it is something you are doing in the corner to make it feel unstable.
TEAM ALFALFA
www.apexassassins.com
Old June 30th, 2014, 06:56 PM   #15
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I did .80 springs and emulators from racetech, and the stability under braking was night and day difference. Now i have great ground clearance when going through corners.
TEAM ALFALFA
Old June 30th, 2014, 09:06 PM   #16
mr2peak
Motorcycle(s): Hyper 821
I'm also right around 130lbs. I went with .70 springs and 15wt oil and it feels a bit harsh for the street.
mr2peak is offline   Reply With Quote
Old July 5th, 2014, 08:22 PM   #17
NinjaNinja2012
Could be something I'm doing no doubt. Could also be a combination of rider and bike which could be improved by an upgraded suspension. The thing that leads me to believe it's more bike than rider is I have rode other bikes and they seem to at least not "jump" in corners when I hit a bump, it absorbs the impact, as it should.....I won't be getting the nitrogen fill bolt or gold valves, just springs and emulators....will cost around $400...
Old July 6th, 2014, 12:09 AM   #18
mr2peak
Springs and emulators should set you back less than $300 all told with new fluid. Save that other $100 and shop around a bit more
Old July 6th, 2014, 04:34 AM   #19
FWIW, I've gotten some riding time on my setup. Not bad I think you'll like the improvement.
There's still some mounds in the road that send me flying off the saddle, but it's the back end that does it, not the front. The front goes right over, the rear launches me.
Suspension Upgrades or Tires? Manimal 2013 - 2017 Ninja 300 General Discussion 104 August 3rd, 2015 09:06 AM
200lb rider on an 11 yro pre-gen; suspension upgrades? aelath 1986 - 2007 Ninja 250R Tech Talk 42 February 1st, 2015 07:40 PM
Budget suspension upgrades? Worldtraveller Ninjettes At Speed 40 October 11th, 2014 02:59 AM
Jacket for Skinny Guy JustRidin Motorcycle Gear 9 October 27th, 2012 07:08 PM
Suspension upgrades: which first? cuong-nutz Ninjettes At Speed 11 November 29th, 2011 06:44 AM
