Old January 1st, 2024, 11:42 AM   #1
Ryan Small
Motorcycle(s): Ninja 250, KX 250f
Ninja starting issue and throttle issue
Hi all, this is my first post on here. I have a 2010 ninja 250r I bought as a project. It did t run when I got it so I took the carbs apart, replaced hers with new OEM ones and put a fresh battery in the bike. Reassembled everything and now she runs. It’s tough to start and sometime takes sone starter fluid to get going but once it’s running it idles well. The carbs are clean but when I twist the throttle I have to do so slowly or it will big and die. It also seems to stick a little and slowly return to idle. It seems as though it’s running too lean. Do I have to pull the carbs off to adjust the idle mixture screws or is there a way to do this while on the bike? I’ve heard they have caps on them but haven’t taken a look on my own yet! I have attached a video below.
Thanks in advance!
trim.53350DF2-40E2-4A4A-942D-C85B89CAF3DD.MOV
Ryan Small is offline   Reply With Quote
Old January 1st, 2024, 12:41 PM   #2
Hi Ryan, welcome! @ducatiman should be along shortly. He's the go-to carb guy here.
Until then, this page might help. In the first sentence it has a link to uncovering the idle mixture screws.
https://faq.ninja250.org/wiki/How_do...dle_mixture%3F
Old January 1st, 2024, 04:06 PM   #3
ducatiman
ducatiman's Avatar
I'd be concerned with idle jets/passages being totally clean.
I opt to drill the EPA caps, followed by levering them out. Just use care to not create damage where it doesn't exist. Note carb idle screws (caps removed) can be adjusted while installed, however some bodywork may need removal prior.
Best o' luck, just post if any further info needed.
Custom Carb Service
Old January 2nd, 2024, 11:57 AM   #4
Ryan Small
Sounds good, I was hoping I wouldn’t have to pull the carbs again but ohh well. At least I got lots of winter months still! I’ll pull them drill the caps and then reinstall. Also should have noted I shimmed the needles up two washers so that may have thrown off the air fuel ratio. The other thing I didn’t realize till after as well was that the needles in the left and right carb were different so I’ll try to make sure I install those in the proper carbs. Thanks for all the help @ducatiman I’ll try to update in a few weeks!
Old January 2nd, 2024, 02:38 PM   #5
ducatiman
ducatiman's Avatar
factory needle placement as such.................. N9VU in left carb and N9VW needles in right carb, they are lightly marked up at the top of each needle
Custom Carb Service
Old January 2nd, 2024, 04:03 PM   #6
Just for reference, when I got Ducatiman to restore my carbs to new condition, the bike immediately ran like new with no needle shims and all stock jets. All I had to do was adjust the idle mixture a little.
Starting issue. PLZ Help vani11a 2013 - 2017 Ninja 300 Tech Talk 26 October 6th, 2021 10:32 PM
Issue with 2005 ninja 250r not starting soulechives 1986 - 2007 Ninja 250R Tech Talk 11 September 2nd, 2015 11:01 AM
Ninja 250 throttle issue HerpDerp1919 1986 - 2007 Ninja 250R Tech Talk 36 June 25th, 2015 08:23 PM
ninja 250 starting issue ninjawing 2008 - 2012 Ninja 250R Tech Talk 21 October 1st, 2013 10:33 AM
Issue with old gen starting SON1C 1986 - 2007 Ninja 250R Tech Talk 3 July 13th, 2013 05:17 PM
