May 12th, 2009, 01:12 AM | #1 |
Tire Pressure Question
Fact: The manual says the front should be set at 28 psi and the rear at 32 psi (cold).
History: When I got a nail in my rear and went to replace it, the dealer pointed out how my front was cupped from under-inflation. I was perplexed because I check my air at least once a week (it is actually in my Outlook calender), and always while cold. I figured the cheapo pen-type tire gauge I was using must be off, so I ordered a nice digital one that reads down to 0.5 psi. It turns out, the pen gauge wasn't really that bad.... but since I have gotten the new gauge (about 1,500 miles ago), I have been religiously keeping it to exactly 0.5 psi where the manual recommends. Current Situation: I was just out checking my tires, running my hand over the fairly new (1,500 miles) Perelli rear tire, and I thought I may have felt the beginnings of cupping or maybe feathering..... I'm not sure, I need a second opinion, but it may be starting. Out of curiosity I looked at the sidewall.... it lists it's maximum load rating at 42 psi cold. Hmmmm..... Qustion: Now I don't what to follow - is it the tire sidewall, or the manual? What do you all do? |
May 12th, 2009, 02:04 AM | #2 |
Join Date: Jan 2009 Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock Posts: A lot.
hey bob...i'm no tire expert, but this is what i do..
to make a long story short, i've determined for myself that the tires i've used on the bikes i've owned fall into an operating pressure range of 28 psi minimum, to between 32-34 psi maximum, under normal operating conditions. the max psi/weight information on the sidewalls i thought was for maximum tire pressures at the maximum allowed weight. my perelli sport demon rear says something like 42 psi max at 677 lbs. (don't quote me on that...memory call) in determining what range to run the new tires at, a friend who helped me mount them suggested this: start each tire on the high end, and see how they perform, slowly taking out pressure in incriments that i would decide (2 psi) and see how this affects the handling. do this till i reach the minimum pressure and determine which pressure works. i've never felt the difference in small pressure changes like i do riding the 250. determine why you've chosen the pressures you have. can you raise pressure to prevent cupping and still have the tire perform as you want? you may be trading tire life for the pressures you run for a given tire. research the net if you need to determine ranges, find what works and if that pressure is allowable, and you're comfortable with it, then DO IT.
Remember when sex was safe and motorcycles were dangerous? |
May 12th, 2009, 04:22 AM | #3 |
Follow the manual. +100 for the digital gauge. My old pen type gauge was off by 3-5psi.
May 12th, 2009, 06:46 AM | #4 |
Inflating to the max pressure on the side wall can be even worse for tire wear. The tire "baloons up" and you wind up riding on a very thin strip of tire the"chicken stripe". You can verify this by putting a small amount of dirt/dust on concrete and then ride through it and note the area of dust in the tire the "contact patch".
May 12th, 2009, 07:42 AM | #5 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Or, take a piece of old fashioned chalk and make two marks on the tire from sidewall to sidewall 180 deg apart. Go for a ride and look to see how much tire you are really using in the turns (old auto cross trick).
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
May 12th, 2009, 07:53 AM | #6 |
You also need to realize that while the tire pressure may be constant under any load, the shape of the tire is not. A 200 lb guy on the same bike as me at 120 lb will get more rubber. That will wear the tires differently. The OM specs are an average to go by.
It's not worth doing if you aren't completely stressed out about it. |
May 12th, 2009, 08:14 AM | #7 |
May 12th, 2009, 08:16 AM | #8 | |
May 12th, 2009, 08:36 AM | #9 |
Live Life
By golly I think they've got it
May 12th, 2009, 08:50 AM | #10 |
I'm not sure what the chalk test would be trying to show. Whether the tire is at 20 psi or 40 psi, it's still unlikely that someone will use the tire right to the absolute edge on the street, either front or rear. Seems to me that the amount of chalk that would be rubbed off it only related to how much lean angle the rider uses on that particular short ride, right? On a car tire I can see more benefit, as the chalk test would let you know if you've overinflated the tire and the contact patch becomes only a smaller portion of what should be firmly on the road when properly inflated.
As some have said in this thread, the max psi rating on the tire sidewall has nothing to do with the optimal psi once it's mounted on a particular bike. It's exactly what it reads, the max psi that the tire can be expected to withstand without risking a failure. The owners manual (or the swingarm sticker) on a bike state the recommended pressures that Kawi has determined to be appropriate for the OEM tires on that bike. That said, the world doesn't end if you go up or down a few psi based on your particular preference. Perhaps going up a few psi in front might lower the risk of cupping the tire, but on the other hand some tires are prone to cupping no matter what the pressure.
May 12th, 2009, 09:39 AM | #11 |
Live Life
Agreed that tire pressure does not affect contact patch on our tires to the extent that it does on a cage, and I would certainly defer to the resident experts on this issue.
However, from my limited experience on the Ninja, and from what I have read, tire pressure can have a significant influence on how the bike "feels" and that in turn could affect how aggressive / comfortable a "newer" rider might be in using the available contact patch. Without a track to go out and really learn how to wring it out and see how hard you can take it into a corner with minimal danger to yourself, your bike, and those around you it would seem that combining changes in tire pressure with chalk marking could help one find the happy balance. Remember guys I'm the flat-lands disadvantaged rider without any "real roads" to work things out on. PS - And an old fart too
May 12th, 2009, 09:50 AM | #12 | ||
May 12th, 2009, 10:33 AM | #13 | |
Live Life
If nothing else its an easy way of monitoring how much lean angle you are inputting (and makes for a good discussion right?).
May 12th, 2009, 11:20 AM | #14 |
That's me!
Join Date: Nov 2008 Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR Posts: 454
For commuting air up to 34psi. For a weekend ride go down to 28PSI (cold). Whenever I go up to L.A. I usually air up to 30-32PSI cold and when I get up there I'll drop it to 28PSI (well 30 PSI because the tires are warmed up at that point). The last time I had my tires changed they put 40 PSI in the tires and I thought I was going to die. I could feel EVERY little bump in the road and the bike handled horribly. At 28PSI (cold) the bike literally performs 100% better.
May 12th, 2009, 01:15 PM | #15 |
Thank you all for your input.
Since I didn't really have the new gauge until I go the new rear, I think I should keep that EXACTLY at OEM specs for the life of the tire to get better "sample data." The front, since it is the original tire still, probably won't reveal much from the change since it was already damaged. I'll revisit the possibility of airing up a little either if the rear starts getting badly cupped, or at the next tire change if necessary. |
May 13th, 2009, 12:16 AM | #16 | |
Join Date: Apr 2009 Motorcycle(s): '08 Ninja 250 Posts: 11
A chicken strip is the small unused portion on the edge of a tire. It is called a chicken strip because the rider is too "chicken" to lean over far enough to use it. It is not the portion of your tire in contact with the road, as you seem to have suggested. A contact patch is the portion of your tire that is in contact with the road at any given instant in time. This patch is about the size of a postage stamp for each tire, it does not encompass the whole circumference of the tire as your post suggests. Sorry, had to do it. |
May 13th, 2009, 08:04 AM | #17 |
I guess the only real solution is to fill your tires with Stuff insulation or replace them with the hard plastic kind on big wheels.
I'm not sure it's something the average rider really needs to worry that much about. If you are riding really hard, then I would go to someone that is a professional rider and ask them flat out. You may also try sending an email to the company and trying to track down a rider, not just a computer jockey. I've had good success talking to the people at Buell when I had questions.
May 13th, 2009, 01:07 PM | #18 |
Join Date: Dec 2008 Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick" Posts: A lot.
The pressures listed in the manual are a good rule of thumb, but one of the ways that you can fine-tune how your bike handles is by adjusting the tire pressure. The rider's weight directly affects it, so what works for one rider might not be right for another. As VeX said, what type of ride you're going on is important. The pressure you use for a long, twisty, mountain ride, should be different than the pressure you'd use for a long freeway/interstate/highway ride. That's because the tires aren't doing the same thing in those situations. I wouldn't necessarily change the pressure for short trips, but it depends on what you're doing.
Here's a good article: Tire Pressure-Not a Lot of Hot Air If you keep the pressures correct for your normal driving conditions you can improve the life of the tires and keep them from getting weird wear patterns.
< ATGATT > Sweat you can wipe off, Road rash you can't. HEY!! Unregistered!! Does your bike have a name? |
May 16th, 2009, 10:27 AM | #19 |
I'm 130-140 lbs.
Drive mostly 20-30 min. commute rides (freeway and fast city streets). Occasional twisty and foot-hill rides. 8700 mi. in 11 months For what it's worth. |
May 26th, 2009, 11:41 AM | #20 |
Ninja Newbie
So I decided to buy a little digital tire pressure gauge. I just went outside and measured my Ninja's tire pressure for the first time:
36 psi at the rear, 32.5 at the front. I weigh 66 kilos (145 pounds) and drive alone and without luggage. I always found the suspension of the bike to be quite hard, and after reading that the manual recommends 32/28 (front/rear) psi, I guess the somewhat high tire pressure will have affected that hard feeling! Cornering at higher speeds on uneven roads often felt a bit unsafe with my setup - I think slightly lower pressure should improve traction in those situations. It's already getting dark over here, but tomorrow I'll go down a little bit and try 34/30 psi, and the day after 32/28. Looking forward to testing, and I hope it'll improve the feel of the bike. |
May 26th, 2009, 11:42 AM | #21 |
It's actually 28F/32R.
May 26th, 2009, 11:48 AM | #22 | |
Lower pressures (to a point) will definitely give you more "feel". |
May 26th, 2009, 11:56 AM | #23 |
Front is still the OEM (the better one, I forget off hand), Rear is Pirelli Sport Demon.
May 26th, 2009, 12:09 PM | #24 |
Ninja Newbie
I got IRC tires on my '09 European 250R. I keep reading that they're a bit crap, but I don't have any others to compare them to, and I probably hardly ever drive on the limit. Before I spend money on better tires, though, I need biking boots and pants.
There are loads of amazing roads around my area, through forests and mountainous areas, fast corners, tight corners, hairpins with lots of elevation, you name it. I'm so glad I went through the hassle of getting a motorcycle license - riding around here is so much fun! My daily commute doesn't have any long straight roads either. So I guess going down from my currently high tire pressure will give me a better feel. |
May 26th, 2009, 12:37 PM | #25 | |
August 22nd, 2012, 05:21 PM | #26 |
Join Date: Jul 2010 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 41
Quick! Please! What PSI for Pirelli Sport Demons?
I way 135 lb. and I'm running Pirelli Sport Demons, 110/70/17 front and 140/70/17 in the rear. Best pressure?
August 22nd, 2012, 09:02 PM | #27 |
Me too, and I'm pretty happy with 1 pound over Kawi's recommended pressures. If memory serves that works out to 29psi front, and 33psi rear.
September 19th, 2012, 07:18 PM | #28 | |
just a thought....from the vstrom forum.
I was with Alex.S and Jiggles last night and they had sex....the video is on utube. :-) |
September 19th, 2012, 07:50 PM | #29 | |
Tire pressure question | krapzed | General Motorcycling Discussion | 5 | August 6th, 2014 11:00 AM |
Oil pressure light question... | Iffita | 1986 - 2007 Ninja 250R Tech Talk | 3 | October 9th, 2012 07:44 PM |
New Owner - has different size tires than factory, tire pressure question | 94fiveohvert | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 16th, 2011 04:37 PM |
aftermarket tire pressure question | Sound Wave | 2008 - 2012 Ninja 250R Tech Talk | 12 | April 28th, 2010 07:44 PM |
Oil Pressure Indicator Question | minuslars | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 17th, 2009 10:41 AM |
