November 16th, 2011, 01:55 PM | #1 |
Join Date: Oct 2011 Motorcycle(s): ninja 250r, crf 50 Posts: 120
New Owner - has different size tires than factory, tire pressure question
I've got a 2010 and it has a Bridgestone Battlax bt090r 140/70/17 m/c 66h tire on the rear, and a battlax bt090f 110/70/17 m/c 54h tire on the front. I weigh 155, and the question is What air pressure should these be run at? I tried searching but haven't seen anything about the bt090's.
November 16th, 2011, 03:14 PM | #2 |
Air pressure is a fickle thing. You will not get 100% straight answers on your question. It just depends on to many factors. Temp, Weight, type of riding you wanna do, weather (wet) and so on...
A good starting point might be 30/31 (rear/front) and adjust + or - for temp and riding preferences.
November 16th, 2011, 03:23 PM | #3 |
thanks chris, just didn't know if it would be much different with the bigger tires.
November 16th, 2011, 04:02 PM | #4 |
So, where's the reverse?
The front tire size and load rating is the same as the stock IRCs so you can run them at the stock PSI of 28. The rear is just slightly wider and has a higher load rating so you can run them at the same stock PSI of 32 as that will be sufficient enough to meet or exceed the load capacity of the OE tires. That's my understanding at least. If I'm wrong, I'm sure one of the vets here will chime in. Also, like Chris mentioned, air pressure can depend on a number of factors.
November 16th, 2011, 04:05 PM | #5 |
also, don't know how much it matters, but they are radials.
November 16th, 2011, 04:37 PM | #6 |
I think you're still fine going with the stock PSI or the figures that Chris suggested. The radials will probably feel a bit softer than the bias OE tires so you could probably pump the front up to 30 PSI.
Edit: I found a DIY where one of the members (former) ran the BT090s with 30/30 front/rear and that seemed to work for him. Last futzed with by Boom King; November 16th, 2011 at 04:43 PM. Reason: Found link |
Tire pressure question | krapzed | General Motorcycling Discussion | 5 | August 6th, 2014 11:00 AM |
Track Tires and size question | tooblekain | Ninjettes At Speed | 33 | August 20th, 2013 08:22 AM |
Tire Pressure Question | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 28 | September 19th, 2012 07:50 PM |
Measuring tire pressure when tires are hot... | Mr.E | 2008 - 2012 Ninja 250R Tech Talk | 10 | January 22nd, 2012 05:17 PM |
aftermarket tire pressure question | Sound Wave | 2008 - 2012 Ninja 250R Tech Talk | 12 | April 28th, 2010 07:44 PM |
