Old March 11th, 2019, 06:42 PM   #1
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
WTB carb slide / diaphragm
Diaphragm is torn on one side of my newly acquired 09. Let me know what you got!
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old March 12th, 2019, 11:55 AM   #2
Ceeloo Yello
Motorcycle(s): 250
Sounds like a job for Ducatiman.
Old March 12th, 2019, 08:12 PM   #3
CynicalC
CynicalC's Avatar
I just need the part, but thanks for the suggestion.
(Oh I see, I didn't realize he sold parts also, I'll send him a message!)
Last futzed with by CynicalC; March 12th, 2019 at 09:31 PM.
Old March 12th, 2019, 08:16 PM   #4
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
I thought at one time Gordon said he had or could get just the diaphragm, though it's a bit of a pain to change.
Old March 12th, 2019, 09:33 PM   #5
Yes, there's some milling of cap on slide necessary to replace diaphragm.
Old March 13th, 2019, 08:47 AM   #6
ducatiman
ducatiman's Avatar
sorry, no diaphragm/slide for sale at this time
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 13th, 2019, 11:48 AM   #7
CynicalC
CynicalC's Avatar
Is there a write-up on this somewhere? The only ones I've seen done this way looked pretty gnarly.
Old March 13th, 2019, 01:12 PM   #8
Ceeloo Yello
Motorcycle(s): 250
U could always take a chance on ebay.
Old March 13th, 2019, 01:47 PM   #9
Ceeloo Yello
Motorcycle(s): 250
You can also check youtube for some generic howtos on diaphragm replacement on cv carbs.
Old March 13th, 2019, 02:11 PM   #10
ducatiman
ducatiman's Avatar
some info in this related recent thread
https://www.ninjette.org/forums/showthread.php?t=331389
Custom Carb Service
Old March 13th, 2019, 03:24 PM   #11
CynicalC
CynicalC's Avatar
Thanks for the tips, guys. So I take it the original diaphragm rubber is sandwiched between a flange on the top of the slide and that cap? And in the case that you don't reuse those caps, I assume the diaphragm is just glued back in place on the bottom side / in the center?
Old March 13th, 2019, 04:04 PM   #12
ducatiman
ducatiman's Avatar
Correct, but I'd advise to check with your vendor first and foremost, let HIM advise you precisely what needs be done.
Custom Carb Service
Old March 13th, 2019, 04:25 PM   #13
Ceeloo Yello
Motorcycle(s): 250
Good tip on doing both as I would guess that the weight difference of removing the retainer disk would also effect the vacuum movement due to different slide weights.
Old March 14th, 2019, 07:57 PM   #14
Z1R rider
Z1R rider's Avatar
sounds like mission accomplished! Nice job!
Old March 19th, 2019, 12:25 PM   #15
ducatiman
ducatiman's Avatar
2 used slide assemblys with new diaphragms installed now being stocked at all times. Ready to go, PM for info.
Custom Carb Service
Last futzed with by ducatiman; March 19th, 2019 at 12:26 PM. Reason: add pic
Old March 19th, 2019, 02:47 PM   #16
Z1R rider
Z1R rider's Avatar
nice job!
Old March 29th, 2019, 03:11 AM   #17
Tooch
Tooch's Avatar
Motorcycle(s): 2008 Ninja 250, 2015 zx10r, 2010 Ducati 848
I replaced just the diagrams pretty easily but depending on Ducamans price, I'd probably just go that route to save you some headache. 2 new diagrams on eBay are $70 for the pair
Tooch is offline   Reply With Quote
Old April 12th, 2019, 12:02 AM   #18
CynicalC
CynicalC's Avatar
I fixed it myself. Thanks everyone.
Last futzed with by CynicalC; April 12th, 2019 at 12:45 PM.
Old August 29th, 2019, 04:27 PM   #19
Hexadecimus
Motorcycle(s): EX250F, 1960 T100A, GPz900R, 74 XLCH, etc.
I've never seen a fix last. If you need a new one, which you probably will if you used some type of repair substance on the torn one, JBM industries sells replacements at a good price. The new owner is a git, but the equipment is good.
Hexadecimus is offline   Reply With Quote
Old April 18th, 2020, 11:45 AM   #20
Fixit
Fixit's Avatar
Motorcycle(s): Harley XL1200C, Kawasaki ex250
have a set of carbs for sale
If interested I will get pics of them to you.
Bikes from small to large.....2005 Ninja 250 --- 1974 Harley XLCH 1000 --- 2006 Harley XL1200C
Not as old as the picture to the left makes me look, just feel that way sometimes.
Fixit is offline   Reply With Quote
Old April 19th, 2020, 05:36 PM   #21
headshrink
headshrink's Avatar
I assume you're good, but I have one if you still need one. It's been drilled, but a dab of CA will return it to stock.
Ripped carb diaphragm and slide Rudiger Items Wanted 2 April 27th, 2015 05:57 PM
