April 4th, 2012, 11:04 PM | #1 |
Join Date: May 2011 Motorcycle(s): Red 2009 Ninja 250R Posts: 47
Custom Rearsets
Hey Everybody. I recently found out that i can get access to the machine shop and CNC machines at my school. Ive always wanted to try my hand at metalwork so I figured id do so by making myself some rear-sets. Ive always been a fan of the woodcrafts but it has always bugged me while aftermarket rearsets look awesome alone, they always seem to look like a bolt on and never part of the bike. By this I mean, they never really match the lines or style of the bike. They're also pretty expensive while the cost to make my own would be minimal... so i figured id design my own. Im pretty competent with CAD but before I can start i need the dimensions of some rearsets so I can plan all the mount points. Does anyone have access to the dimensions of any rear sets? either the stock or aftermarket ones?
DIY Byson rear hugger, DIY flush mounts, replica pazzo shorty brake/clutch lever, MGP growler exhaust, random tank pad, Shogun spool/slider kit, Targa fender eliminator |
April 4th, 2012, 11:34 PM | #2 |
lol. Unfortunately I do not have the money for one of those. I also do not want an exact copy of any existing ones and would like to use my own design I just need dimensions like the spacing between the mounting holes, master cylinder rmount, etc. I would just get them off my bike but i am away from it right now and would like something more exact than just my own measurements.
April 5th, 2012, 05:32 AM | #3 | |
There is a thread somewhere here where a guy actually drew up some CAD models of some parts, a rear set is likely there. |
April 5th, 2012, 08:14 PM | #4 |
Thats awesome. Any idea how long ago that was? i cant seem to find any threads relating to it.
April 5th, 2012, 08:24 PM | #5 |
http://www.ninjette.org/forums/showt...highlight=mine
I think that's the thread he's remembering, but I'm not sure |
April 5th, 2012, 10:36 PM | #6 |
Cool thanks. Ill have to see if if can get the drawings for his adapters. It looks like i will only be able to get the dimensions for the rearset mount holes but it will do for now. If anyone has any more insight please let me know.
April 6th, 2012, 06:21 PM | #7 | |
It shouldn't be too hard to figure out. from there, all you really have to figure out is where you want the peg to be in relation to the mounting. If you want to make adjustable rearsets, you can take the mounting points, and extrude a block out and have a proprietary grid of mounting points for a second piece. I may do this myself haha, no time, though. |
April 6th, 2012, 09:36 PM | #8 |
I am actually going to make them adjustable. Also thinking of making them foldable but ill have to see how much that will complicate the milling.
As far as dimensions go what is worrying me is the relation between all of the break related stuff and the brake lever. I haven't taken a look at it in a while so I am not so sure how much freedom there is in placing the break switch and master cylinder in relation to the lever. As soon as i get the dimensions for the mounting holes ill start by designing the left side because it should be relatively simple. Gonna try to make it adjustable between standard and GP shift pattern. I also have finals coming up so progress will probably be slow the next couple of weeks
April 8th, 2012, 03:22 AM | #9 |
Join Date: Feb 2012 Motorcycle(s): '10 Ninja 250 Racer Posts: 95
I have been thinking of doing this at uni too
#77 |
April 8th, 2012, 06:51 AM | #10 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
May 12th, 2012, 12:15 AM | #11 |
Hey everybody. So now that finals are over I can get back to this. Here is what I have in mind so far for the folding pegs.
There will be a spring in that little gap to hold tension. Haven't worked out the proportions yet or how to mount them. I might also end up knurling the non folding part. Lemme know what you think. Also, does anyone know what grade of aluminum I should be using?
May 12th, 2012, 02:41 AM | #12 | |
#77 |
May 12th, 2012, 11:09 AM | #13 | |
May 12th, 2012, 01:11 PM | #14 | |
Join Date: Mar 2012 Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013) Posts: 492
Unless you have the peg already textured, ALOT of time on a lathe or a 5+ axis CNC machine I'm not sure how you'll get the diamond texturing all around. If I was you I would be basically making a rearset adjuster and sourcing pegs.
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips |
May 12th, 2012, 02:53 PM | #15 |
Yep thats solidworks. We actually have T6 aluminum bar lying around so it shouldn't cost me anything to make these.
I dont imagine its too hard to make. For the diamond pattern I just need to go over it with a knurling tool. after that cut the grooves on a lathe. then drill out the center and cut out the notches in the back and bottom. I don't know how to do the convex curves tho. If it doesn't work out i would probably just get some Rizoma folding pegs... those things are gorgeous.
Just Got new Rearsets | Enrgkid | 2008 - 2012 Ninja 250R Farkles | 34 | December 30th, 2014 05:15 PM |
[hell for leather] - A custom bag for your custom scrambler | Ninjette Newsbot | Motorcycling News | 0 | April 3rd, 2012 04:30 PM |
[motorcyclistonline] - Garwood Custom Cycles Unveils Custom Susan G. Komen For The Cu | Ninjette Newsbot | Motorcycling News | 0 | March 9th, 2011 06:10 PM |
[topix.net] - Dylan Robba s custom built is the future of Harley custom building | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2010 03:20 PM |
Rearsets... | Verus Cidere | General Motorcycling Discussion | 3 | March 22nd, 2009 12:09 PM |
