Old April 24th, 2012, 09:31 AM   #1
01subaru
Motorcycle(s): 09'cbr1000rr and girlfreind 12' ninja 250
what carb needle to use?
just woundering if you guys are changing them, and if you are what are you using? my bike has plmr exhaust, k&n pod, kleen air block off plate. thanks
01subaru is offline   Reply With Quote
Old April 24th, 2012, 09:33 AM   #2
Most people either raise their needles by shimming them up with washers, or they buy a jet kit from Factory Pro or Dynojet that include custom, adjustable needles.
Old April 24th, 2012, 01:58 PM   #3
01subaru
i just wounderd if some one has come up with one i can buy that works better then the stock one?
Old April 24th, 2012, 02:11 PM   #4
DevinWolfe
Which pedal is the gas?
DevinWolfe's Avatar
Motorcycle(s): '09 Ninja 250R SE
Jetsrus.com
Buy individual ones there. I believe people use a 110-118 main with no airbox and aftermarket exhaust.
Search around the DIY threads and youll find the info
Posted via Mobile Device
DevinWolfe is offline   Reply With Quote
Old April 24th, 2012, 04:20 PM   #5
Xepher2792
Newbie Researcher
Xepher2792's Avatar
Motorcycle(s): None yet
He asked about needles not jets...
Xepher2792 is offline   Reply With Quote
Old April 24th, 2012, 04:44 PM   #6
DevinWolfe
DevinWolfe's Avatar
My mistake, words are hard (at least on a cell phone). Here is a little info on *needles* in case you haven't seen it yet.
The DIY
http://www.ninjette.org/forums/showthread.php?t=9465
Other info
http://faq.ninja250.org/wiki/Ninja_2...le_Information
Edit: Not sure why I thought jets, as I am actually in the middle (taking a dinner break) of shimming myself, but some recommend changing to a 100 main jet also. I will likely be doing that after I see how the shimming works out.
Old April 24th, 2012, 05:17 PM   #7
not to my knowledge. The only needles that I know of are the ones that come in jet kits.
likely me. I've recommended that a few times lately to people doing snorkel removal + aftermarket filter + exhaust change because I had great luck going up one main jet size with those mods, and I'm not the only one in my area who's had the same results.
Here's the thing. You're in the mountains at roughly 6000 feet elevation correct? Make sure to test the different sizes of main jets back to back. You're high enough that you might actually be better with the 98's. It's all relative. Definitely test the 100's though, and stick with the ones you like best
Perfect carb needle shim washers 37coupe 2008 - 2012 Ninja 250R Tech Talk 4 April 5th, 2015 04:07 PM
WTB: Left over carb needle washers/shims agentbad Items Wanted 5 March 14th, 2015 12:20 PM
Carb Needle Shim Question/Bike Idle haloninja117 1986 - 2007 Ninja 250R Tech Talk 3 August 8th, 2014 01:14 PM
Need post needle shim carb help irishjohn 2008 - 2012 Ninja 250R Tech Talk 18 September 23rd, 2010 11:52 AM
carb needle shim gone wrong, help pls, 8-b brandonryanblack 2008 - 2012 Ninja 250R Tech Talk 27 January 11th, 2010 09:27 PM
