April 26th, 2012, 07:04 AM | #1 |
Join Date: Jun 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S Posts: 334
Front Left Blinker Stays On
Hey guys, I haven't posted in a little while because I've been busy but since this is a safety issue I think I should look into getting help to get it fixed soon. My front left blinker stays on, and my left rear blinker does not turn on. Is this a bulb issue? I don't have the equipment to check the electronics of anything, so I won't be able to see if my relay is bad.
Would this be a simple case of a burnt out left rear bulb? I've only had this bike since July 2011, so it hasn't even been a year. It seems odd that the blinker would burn out. Is this covered under the 1 year warranty? |
April 26th, 2012, 09:22 AM | #2 |
i had the same problem on my ninja. If i recall i had a burnt of bulb. Check the bulb first
April 26th, 2012, 10:20 AM | #3 |
Join Date: Apr 2012 Motorcycle(s): 1988 FJ1100 Posts: 165
Agreed, check the Bulb first. Pop it out and flick it with your finger, if you can see the filament moving around you have a bad bulb.
High output motorcycle stators, rotors and replacement regulators/rectifiers. www.racetechelectric.com |
April 26th, 2012, 03:55 PM | #4 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
I had a similar problem; I took the front left blinker apart and discovered one of the connectors was loose, so I connected it properly and taped it up, and that fixed the problem. You could check the front and back both to make sure everything is snug.
April 26th, 2012, 04:06 PM | #5 |
Join Date: Jan 2012 Motorcycle(s): Green 2012 Ninja 250SE and a Yamaha fino scooter (my wife's really) Posts: 355
sounds like a bulb to me number one check if a light dont work is to check the bulb
bulbs can either last for years or last a few weeks so No if its a bulb it will not be covered by the warranty .
Be safe ride smart .....a dumb rider is a dead rider |
April 28th, 2012, 02:34 PM | #6 |
I looked at the bulb and it looked fine since the filament was still attached on either end. I took the seat off and checked the connector that leads to the L Rear turn signal and it looked fine. I reconnected them to make sure there wasn't a connection issue either and that didn't work.
UGGHH! I wish it was a blown bulb. Any other ideas? |
April 28th, 2012, 03:02 PM | #7 | |
also found this might help http://www.mickeywebpages.com/users/...ia_FLASHER.gif sometimes a bulb can look fine but be blown
April 28th, 2012, 03:42 PM | #8 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
Or put a paperclip in the connector for the rear bulb, that should make the front blink but really fast. Then it's either the socket or bulb. Sometimes you can't tell a bulb is blown by looking at it, swap it out or test it with an ohmmeter
Trust me, I'm a banana! |
April 30th, 2012, 10:33 AM | #9 |
If you didn't move the bulb to another socket, then you haven't ruled out the blown bulb. Not all breaks in the filament are obvious.
Installing cyclegear led front blinker issue | CycleCam303 | 2008 - 2012 Ninja 250R Farkles | 3 | March 9th, 2013 06:37 PM |
Direct me: front blinker | kchava | 1986 - 2007 Ninja 250R Tech Talk | 4 | December 13th, 2011 04:02 AM |
[crash.net - MotoGP] - Dovizioso stays up front at Sepang | Ninjette Newsbot | Motorcycling News | 0 | October 8th, 2010 02:52 AM |
Front right blinker doesn't come on but light on console blinks super fast | kchava | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 6th, 2009 07:02 PM |
