Old May 3rd, 2012, 04:12 PM   #1
2003ninja
Motorcycle(s): 2003 ninja 250
Need to repair the ninjas fairing...
I hit something the other day (dont know what.... just heard the sound) and cracked my lower fairing. I need a new one, and i can only find them on ebay for like 90 bucks, any where i can find one cheaper? i need a black one. Also my ninja was repainted by the old owner and is now black, but i dont think a new fairing will match the old paint, so should i buy a new set? thanks.
2003ninja is offline   Reply With Quote
Old May 3rd, 2012, 04:35 PM   #2
Stingray1000
Stingray1000's Avatar
Motorcycle(s): 2003 Kawasaki Ninja 250R
I got a side plastic or fairing if it's called that for the same bike for 40 bucks.... 90 seems like alot Can you send a link to what you're trying to buy on ebay?
http://www.facebook.com/groups/DeMdNjPagrouprides/
I live my life a quarter mile at a time!
Who is affraid of the big bad jiggles???? LOL
Stingray1000 is offline   Reply With Quote
Old May 3rd, 2012, 04:48 PM   #3
2003ninja
sure this ones more expensive
http://www.ebay.com/itm/87-07-Kawasa...#ht_2002wt_952
Old May 5th, 2012, 12:52 PM   #4
2003ninja
Bump... or i guess im not getting it fixed
Old May 5th, 2012, 12:56 PM   #5
is it bad enough that you need a new fairing?
Or can you just fiberglass the inside to strengthen it and then bondo/sand/paint the outside?
Old May 5th, 2012, 01:05 PM   #6
Ninja Justin
ninjette.org Ninja :)
Ninja Justin's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R SE
I am jealous... I have a 2010 Se.... so i have to buy OEM fairings...which are Fu***ng expensive...it costs just over $600 to replace both fairings... (which i have to do...) wish i could just spend $90 =D
http://www.ninjette.org/forums/group.php?groupid=23
The Anchorage Ninja's
Ninja Justin is offline   Reply With Quote
Old May 5th, 2012, 01:12 PM   #7
2003ninja
Its cracked like from the edge pretty bad and dented so i think ill need a new one.
Old May 8th, 2012, 05:45 PM   #8
globalmaa
Motorcycle(s): 1987 250R
I just repaired mine. all 4 pieces had cracks . if it is black plastic ( ABS ) it is an easy fix. you need a couple of hands do do it. someone to hold the pieces together and use a soldier gun. make stitch like marks across the crack about 1/2" on either side. when your done that now run the iron along the crack. if you really want a strong finish get some strips of abs , usually a clip board, cut it into strips and start melding it into the crack, when your done use some abs plumbers cement and cover the whole inside. on the outside use a 2 part bumper bondo to fill it the crack from the outside. the bumper bondo is flexible as well. sand and paint. i painted my whole bike with rattle can in my drive way. mine came out great and looks amazing.
globalmaa is offline   Reply With Quote
Old May 9th, 2012, 05:11 PM   #9
Palero
Palero's Avatar
Motorcycle(s): 1988 Honda Hawk GT 1989 EX250F (Died from left-turning car) 2011 EX250J (Died from SAME left-turning car)
Looks great!
Thanks for the tip.
Post more photos of your Ninja!
Palero is offline   Reply With Quote
Old May 11th, 2012, 05:54 PM   #10
globalmaa
here is a video of my ninja . there were a bunch of cracks and where the signals mount it was completely busted off. i pushed everything back as much as possible and started melted abs into the voids. no need to throw away your fairings. as far as paint i used duplicolour grabber green engine enamel and spraymax 2k cut in clear. total body and paint was under 100 bucks.
http://www.youtube.com/watch?v=8TNUj...ature=youtu.be
Fairing repair sidekick10121 1986 - 2007 Ninja 250R Tech Talk 8 March 17th, 2014 04:53 AM
paint and fairing repair qs crazymadbastard 1986 - 2007 Ninja 250R Tech Talk 2 May 29th, 2013 09:42 AM
How To Repair Busted Fairing BallsOfSteele 2008 - 2012 Ninja 250R Tech Talk 3 March 6th, 2013 11:26 PM
[topix.net] - Joe's Scooter Repair: Not limited to just scooters, they also repair AT Ninjette Newsbot Motorcycling News 0 August 12th, 2012 08:30 PM
How do I repair a fairing? PlaneGuy 1986 - 2007 Ninja 250R Tech Talk 14 October 10th, 2011 05:40 AM
