May 4th, 2012, 10:21 PM | #1 |
Qtr Ltr
Join Date: Aug 2010 Motorcycle(s): 2009 Ninja 250R SE Posts: 64
Mystery Noise at 4800 RPM?
A couple of days ago, my 09 250R began making a strange noise. It sounds almost like a faint grinding metal on metal. I first checked the pads, and all was well. So I've been trying to track it down since. So far I've determined the noise only occurs right around 4800RPM. I can hear it at 4800 RPM in all gears, but I can not hear it in neutral. Has anyone had a similar issue or have any ideas?
Thanks! |
May 6th, 2012, 03:49 PM | #3 |
Qtr Ltr
If it hadn't began so suddenly then that would probably be the solution. As its only a certain RPM, I'm hoping its just resonance of a loose part or something. I'm planning to change the oil and put on a new right fairing tomorrow, so I'll have a chance to look everything over really good.
May 6th, 2012, 04:02 PM | #4 |
The Ninja is a noisy bike with a lot of sounds being "normal sounds" Sounds can be described differently by everyone. A video clip of the sound may help determine what it might be.
May 6th, 2012, 04:51 PM | #5 |
Join Date: Mar 2012 Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013) Posts: 492
check the pin that hold both passenger foot rests. After chopping my fender yesterday and checking that everything turned on correctly I noticed that one of those pins and C clip is loose. It doesn't grind as you describe it but it's a somewhat high pitch metallic rattling noise.
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips |
May 6th, 2012, 08:39 PM | #6 |
the levers vibrate at certain rpms. my keys also vibrate at certain rpms. recheck the torque on all the bolts on the bike and make sure nothings falling off, then put in some earplugs.
May 11th, 2012, 09:57 PM | #7 | |
Qtr Ltr
I'll be sure to update the thread if I can get a good recording of the noise. Perhaps this is a good excuse to buy a gopro or contour camera... |
Rasping Noise Above 8k RPM | Finesse | 1986 - 2007 Ninja 250R Tech Talk | 10 | April 11th, 2014 01:22 PM |
Annoying noise at 2,5-5 k RPM | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 13 | August 9th, 2013 08:24 AM |
Strange Noise at ~6000 RPM | forevertwowheels | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 20th, 2012 06:15 AM |
7k+ rpm makes strange noise | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 14 | June 11th, 2012 03:30 PM |
Rattling Noise from 8-9k RPM | 250fan | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 1st, 2009 10:52 PM |
