#1 |
Join Date: Mar 2012 Motorcycle(s): '09 Ninja 250r [RED] & '06 Ninja 250 [WHITE] Posts: 162
Hey gang,
I just picked up an '09 last night. it is in excellent condition except for the front right blinker that is busted from it tipping over. One big issue though. The brake light doesn't fully work. It turns on and is illuminated, but when I use either brake it doesn't get brighter. I have not checked the bulb yet, but really think it may be a disconnected wire that triggers the bulb to its brighter filament. Any thoughts, tips, or a wiring diagram available? Thanks! Last futzed with by CalvinAmI; May 14th, 2012 at 07:24 AM. |
#2 |
The bulb has two filaments. Odds are you just need a new bulb.
#3 |
Resident Lurker
Join Date: Jan 2010 Motorcycle(s): R6, Strom, 250R, CH80 Elite Posts: 78
What Alex said. The odds of you needing a new bulb because the brake light filament broke and the tail light is still working is much higher than a rat ate through your brake light wire and left everything else in tact.
The tail and brake light typically use the same connector, making it that much more unlikely that you are having a wiring-related issue.
When was the last time you checked your tire pressure? ![]() |
#5 |
I changed the brake bulb with two others that work properly in my other bike.
Still not working correctly. When I depress either brake, the light just stays the same. What are the chances one of the switches are stuck? I am gonna go check to see if both filaments are illuminated when on. BRB.... |
#6 |
You should be able to look at the filaments in the bulb to see if both are lighting up. If they are, one of the switches is stuck.
#7 |
Problem fixed. The rear brake spring thing was unscrewed too much activating the switch.
While I had the rear light out of the socket, I replaced it with a 27LED red light =) No time wasted =) Thanks again with the help on this matter! |
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL | coelgrim | 2008 - 2012 Ninja 250R Tech Talk | 16 | March 11th, 2013 05:10 PM |
Front Brake Switch Doesn't Light Tail Light | ajcadoo | 2008 - 2012 Ninja 250R Tech Talk | 19 | January 30th, 2013 07:06 PM |
fuel gauge light doesn't work. | jon.b.calderon | 2008 - 2012 Ninja 250R Tech Talk | 1 | January 20th, 2013 11:03 PM |
My rear brake doesn't work?! | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 16th, 2012 03:30 PM |
Brake light works but tail light doesn't | DirtyBoy | 2008 - 2012 Ninja 250R Tech Talk | 19 | May 27th, 2009 07:18 PM |
