Old June 3rd, 2012, 12:44 PM   #1
Trainsk8
Motorcycle(s): 2010 Kawasaki Ninja 250R
Carb Float Problem
I have a feeling that i fiddled with the carb a little too much... a couple weeks ago i tried lowering the floats just a bit the lean out the low revs so the engine wouldn't bog down as much. but then the whole bike ran very lean and partial throttle was non exixtent. Then today i had time and tried raising the floats to richen the fuel mixture. After 3-4 times of ripping the carb out and raising the floats the bike still stumbles to get going and partial throttle doesn't work very well. i even tried adjusting the fuel mixture screws but it still does the same thing. Can anyone help me?
Trainsk8 is offline   Reply With Quote
Old June 3rd, 2012, 01:27 PM   #2
Kygirl
Kygirl's Avatar
Motorcycle(s): 2008 ninja 250R 1979 SuzukiGS425E
Like a lot of people on this forum I've jetted, shimmed, adjusted my mixture screws, and synchronized my carbs several times. However, I've never adjusted my ninja from the stock float heights. So I can't offer much advice. =( Is your bike already jetted/shimmed/etc. and the float adjustment was a final thing to perfect it? If so sounds like a carb sync is a good idea. You've probably already done that, but if not it might help a bit. Hopefully someone will jump in soon and offer some good advice!
Kygirl is offline   Reply With Quote
Old June 3rd, 2012, 03:52 PM   #3
Have you measured the height that the fuel reaches inside the bowls?
There is a narrow specification for that (+-2 mm I believe), which is hard to reach just by guessing.
Old June 4th, 2012, 12:31 PM   #4
Trainsk8
yeah the bike's been fully jetted with a factory pro kit, and i just had the valves adjusted, and had the carbs synced the other day hoping that it would help. i did measure the float height
Carb float levels... corksil 2008 - 2012 Ninja 250R Tech Talk 9 January 29th, 2014 05:30 PM
carb problem radioflyer 2008 - 2012 Ninja 250R Tech Talk 1 July 19th, 2013 06:55 PM
ninja 250 float problem? xbox3bob 1986 - 2007 Ninja 250R Tech Talk 6 July 10th, 2012 06:05 PM
Carb - leaky float valve questions ako 1986 - 2007 Ninja 250R Tech Talk 34 June 15th, 2011 10:04 AM
Carb tuning take 2 - AEM wideband info & has ANYONE adjusted float height? rwheelz 2008 - 2012 Ninja 250R Tech Talk 6 March 30th, 2011 06:43 AM
