Old June 16th, 2012, 02:37 AM   #1
indr
New engine direct from Kawasaki
Anyone know if it's possible to order?
indr is offline   Reply With Quote
Old June 16th, 2012, 07:54 AM   #2
jonthechron
Motorcycle(s): magHitVE
Already assembled, I don't think so.
I know you can buy all parts individually, 3000$ for the engine parts and tranny add an other 1000$ if you want the carbs...
Old June 16th, 2012, 12:12 PM   #3
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
just find a used one, there not that much money
----> My Youtube! <----
Old June 16th, 2012, 07:41 PM   #4
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
hey man, how's it going?? ya end up heading out west? I had got those shims from you if you remember...
regarding the engine did you blow yours? When I blew mine I started looking and a used engine was the best option you can get one for about 500-600 bucks...
I was lucky enough to get it warrantied though
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound
LoneRonin is offline   Reply With Quote
Old June 18th, 2012, 04:13 AM   #5
indr
Yeah. I'm in BC. Been here since last autumn. It's beautiful here as was the trip on the Trans-Canada.
I ended up having the shims sent to me because I needed them for a valve adjustment. Which is where I ****ed up the engine. I either dropped something inside or set the chain timing wrong. Last I started it up, there was a loud knocking noise when cranking. I'm having a hard time finding an engine so I'm thinking of opening it up and doing a rebuild.
Old June 18th, 2012, 04:55 AM   #6
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
rebuild with
je pistons std comp
beet cams
yoshi carbs
ninja250r81 is offline   Reply With Quote
Old June 18th, 2012, 09:20 AM   #7
LoneRonin
LoneRonin's Avatar
I did the same thing...valve adjustment gone wrong and same symptoms...
Old June 18th, 2012, 09:31 AM   #8
engines are cheap. fixing your mistake is usually cheaper.
[topix.net] - Essex/Suffolk: Motorcycles Direct acquires Colchester Kawasaki dealersh Ninjette Newsbot Motorcycling News 0 May 11th, 2012 12:40 AM
Direct me: front blinker kchava 1986 - 2007 Ninja 250R Tech Talk 4 December 13th, 2011 04:02 AM
[topix.net] - Motus Motorcycles Completes World's First Direct Injected V4 Engine Ninjette Newsbot Motorcycling News 0 January 23rd, 2010 10:02 AM
[motorcycle.com] - Motus builds direct injection V4 engine Ninjette Newsbot Motorcycling News 0 January 19th, 2010 10:51 PM
