June 22nd, 2012, 05:30 AM | #1 |
Join Date: May 2012 Motorcycle(s): 2005 SV650S Posts: 195
New Bike Issues
So I finally picked up my bike! Well my friend drove it but its been sitting at the seller's house for a while so new gas helped. I put in a new battery, it starts with full choke and after a couple seconds I can move the choke to about 3/4 and it will idle around 3-4000 rpms.
I even got it to idle around 2 but after adding throttle it would shut off. It also stalled a few times. I noticed a line is loose and dragged on the ground from the front tire. I'm guessing its a speedometer line? It is connected to the tire and the other end has a metal cap like structure with a prong/wire coming out? When I asked my friend he said the speedo was not working. We had to drive it home with the choke at 3/4 and idle around 3-4000 rpm. He said it drove fine minus the stalling a few times. I need some recommendations as I've been waiting to get and ride the bike and now I'm afraid I will need to pay more to fix it or even just sell it. Kinda dissapointed. |
June 22nd, 2012, 06:01 AM | #2 |
To start you need to clean and adjust the carbs, replace the speedo cable, change the oil and the oil filter, replace the air filter, lube the chain, inspect the tire condition, and have the valves adjusted if it has not already been done.
June 22nd, 2012, 06:05 AM | #3 | |
As for the carbs cleaned I can't do that myself same for the valve adjustment and all. Oil change I could do if I had a center stand. |
June 22nd, 2012, 07:00 AM | #4 |
Yep, the speedo cable is fairly durable, so you can probably just reinstall the end into the back of the instrument cluster; it's pretty obvious where it goes.
Like DaBlue1 said, carbs almost definitely need to be cleaned. That's almost certainly your main issue. After sitting that long, the gas probably gummed some of the jets, leading your engine to be fuel-starved, hence the need for the choke. It's a pretty easy process if you've got an hour or two to learn, even a DIY on ninjette I think. You could try some fuel additives that're supposed to clear out that gunk, but once the carbs are gummed bad enough to significantly affect the bike's performance, I haven't had much luck with that stuff. Regarding the valves, I'd ask the previous owner about that specifically; hopefully he kept receipts/service records. That's generally an expensive maintenance item (~$200+) and people tend to neglect that, even when giving it to a shop for a "tuneup" because it can be a pain. Kawasaki suggests the valves be checked every ~7,500mi.
June 22nd, 2012, 07:05 AM | #5 | |
June 22nd, 2012, 07:43 AM | #6 | |
Join Date: Mar 2012 Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013) Posts: 492
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips |
June 22nd, 2012, 07:57 AM | #7 |
So, where's the reverse?
I wonder why he had the speedo line unplugged? Before you reconnect it, you might want to check if it needs to be lubed/greased. You can give SeaFoam a try but as someone else mentioned, if the carbs are really gummed up, there's no substitute for a cleaning. Personally, instead of using SeaFoam - a solvent based additive, I would go with a polyester amine (PEA) based detergent additive like Chevron Techron Concentrate Fuel System Cleaner or Gumout Regane Complete Fuel System Cleaner.
June 22nd, 2012, 08:54 AM | #8 |
I heard carb cleaning can cost around $450 bucks but I will try to get a friend that can do it. I have someone coming to check it out and maybe we could figure something out. I'd hate to shell out more money as I need to move soon so it wouldn't be fun.
I'm guessing the speedo line got disconnected, probably when he took the old battery out. Or it may have come out by itself. I'm not so technically inclined when it comes to motors and such I could probably find the carbs and remove them, putting all that stuff back would be an issue. |
June 22nd, 2012, 09:39 AM | #9 | |
Join Date: Apr 2012 Motorcycle(s): 2003 Kawasaki Ninja 250R Posts: A lot.
http://www.facebook.com/groups/DeMdNjPagrouprides/ I live my life a quarter mile at a time! Who is affraid of the big bad jiggles???? LOL |
June 22nd, 2012, 10:00 AM | #10 |
IC2(SW)
You left out a good wash & wax job
June 22nd, 2012, 10:08 AM | #11 | |
I've seen freshly-cleaned carbs gum back up (to really needing to be cleaned again) in a month of non-riding, so I believe mileage isn't really a factor. OP, if that mileage is right, the valves aren't an issue for you for a while, so you're good there. SeaFoam is great for keeping clean carbs happy, but if you're going to clean it, I'd check out the detergents that BoomKing suggested. Also as per BoomKing (good point here), definitely check the speedo cable for crud & re-lube before you put it back, if it's in condition to be re-used. I'm mystified why the speedo was disconnected; it goes nowhere even remotely near the battery so it wouldn't have to be pulled for that, and they're usually tight as hell from the factory, so I find it unlikely it'd just fall out. My concern is that the speedo cable is what "ticks" the odometer. Depending on how tricksy he is, it may've been pulled to stop from accumulating mileage on the bike (aka, that bike may actually have more than 1200mi on it). Not attempting slander, just throwing ideas around.
June 22nd, 2012, 11:27 AM | #12 |
You could be right but if I remember correctly the bike was bought in 2010 by the seller, according to the title, and it had just under 1000 miles. The person I bought it from rode it a few weekends for a while then had it tuned up and basically left it in the garage until now.
We did not drain the gas tank. I'm gonna pick up the fuel cleaner after work and maybe seafoam too. I've read of the speedo cables being loose in the ninjas before. |
June 22nd, 2012, 07:25 PM | #13 |
The speedometer cable went right back in to the instrument panel. As for the seafoam I put some in and then put 93 gas in there. It ran a little better. Still would stall and die when using little choke.
I got it to almost no choke and it idles low and rough but when you give it gas, dead! Does anyone have a good guide for cleaning the carbs out on the 2009 model. It was raining today so I did not get to do it. My friend has never done that but he will help me on Sunday. If I could get a good guide that would be great especially for the new gen model. I also bought new spark plugs too to replace. I hope this work...but who knows what will happen :/ |
Issues with my bike, trip in only 3 weeks help!! | sailorninja | 1986 - 2007 Ninja 250R Tech Talk | 6 | September 30th, 2014 05:22 PM |
Buying a New Bike, Possible Issues | Treyzian | General Motorcycling Discussion | 9 | November 26th, 2013 05:03 PM |
Help - Having engine issues with new-to-me bike | Candy green 06 ninja | 1986 - 2007 Ninja 250R Tech Talk | 32 | October 7th, 2013 09:59 AM |
issues starting bike in the morning | kittyslasher | 2008 - 2012 Ninja 250R Tech Talk | 4 | July 11th, 2013 11:23 AM |
Need Help--Issues Starting Bike | riding_the_edge | 1986 - 2007 Ninja 250R Tech Talk | 13 | December 14th, 2011 03:37 PM |
