Old June 26th, 2012, 09:29 AM   #1
Reyno2ac
Reyno2ac's Avatar
Motorcycle(s): Red 2009 Ninja 650r
Front sprocket change DIY?
Is there a DIY that shows how to change the front sprocket?
The main thing I'm worried about is realigning the rear tire, I'm not even sure if I need to do it.
Any help would be appreciated
Reyno2ac is offline   Reply With Quote
Old June 26th, 2012, 10:16 AM   #2
dubojr1
dubojr1's Avatar
http://www.ninjette.org/forums/showthread.php?t=10273
Old June 26th, 2012, 10:35 AM   #3
Reyno2ac
Reyno2ac's Avatar
Originally Posted by dubojr1 View Post
That one is nice, but it doesn't mention whether or not you need to realign the rear wheel.
Old June 26th, 2012, 10:56 AM   #4
if you loosen the chain adjusters, you need to realign the rear wheel.
Old June 26th, 2012, 11:08 AM   #5
Reyno2ac
Reyno2ac's Avatar
Well damn...How hard is aligning the rear wheel? Do I need any special tools?
Old June 26th, 2012, 11:13 AM   #6
dubojr1
dubojr1's Avatar
http://www.ninjette.org/forums/showthread.php?t=5586
Old June 26th, 2012, 11:13 AM   #7
dino74
dino74's Avatar
You shouldn't have to move the chain adjusters. I didn't when I changed mine...
CVMA #55
Old June 26th, 2012, 11:42 AM   #8
its really easy if you can split the chain. but if its riveted, it takes a little convincing to get the front sprocket off with the rear still setup and tensioned
Old June 26th, 2012, 12:05 PM   #9
xSean13
xSean13's Avatar
I couldn't get my front sprocket back in without having to basically take the rear wheel off. I tried loosening the axle nut & adjusters all the way & pushing the rear tire forward but still didn't have enough chain slack. Anyways, if you should have to remove the axle...it's just about impossible to get everything aligned and still insert it from the left side, so get everything aligned and put the axle in from the right.
Old June 26th, 2012, 02:38 PM   #10
dino74
dino74's Avatar
I had a hell of a time trying to use a breaker bar to loosen the nut. Went to harbour freight and bought a 1/2 impact wrench. Less than 10 seconds, the nuts was off. I love that wrench!
CVMA #55
Old June 26th, 2012, 05:33 PM   #11
Reyno2ac
Reyno2ac's Avatar
How'd you do it?
DIY- Sprocket Swap toku 2008 - 2012 Ninja 250R Tech Talk 166 March 24th, 2015 05:09 AM
Sprocket Change? csmith12 2008 - 2012 Ninja 250R Tech Talk 17 April 9th, 2014 03:20 PM
15 41 sprocket change gogiburn 1986 - 2007 Ninja 250R Tech Talk 4 September 22nd, 2012 02:05 PM
front vs rear sprocket change sharky nrk 2008 - 2012 Ninja 250R Tech Talk 8 June 25th, 2012 03:32 AM
Front sprocket change help! RedNinja21 2008 - 2012 Ninja 250R Tech Talk 35 April 12th, 2012 09:28 AM
