Old August 4th, 2012, 11:22 PM   #1
MasterCylinder
MasterCylinder's Avatar
Motorcycle(s): '90 ex250
Annoying lever rattle
Well since I've had my bike I've had this annoying rattle once I got up passed 6k rpm that I just couldn't figure out where it was coming. It bothered me because I thought it was the engine and that there was some unforeseen damage...
Anyways, long story short I was riding yesterday and discovered that the rattle is my clutch lever that was rattling because of how close I like to keep my clutch pulls to the handle bars.
I need ideas on how to make the lever not rattle. Go!
MasterCylinder is offline   Reply With Quote
Old August 4th, 2012, 11:56 PM   #2
Monkeytofu
I told you bro
Monkeytofu's Avatar
What type of lever are you using? A lot of after market levers for the 250 aren't made as big as the original so you get some loose lever rattle. The easiest thing you can do here is replace them with OEM handles but that's going to run you 10 or 15 dollars on ebay.
you could also try putting a washer in between the lever and the housing that the main bolt goes through. Make sure it's thin enough that it doesn't cause your lever to stick. You may even want to JB weld/glue (the washer not the lever ) it in place if you find one that gives you the perfect fit.
OEM replacement: http://www.ebay.com/itm/1987-2007-Ka...250d77&vxp=mtr (not sure if the cheapest ones available online, do some research and save some money)
~17 dollars
Last futzed with by Monkeytofu; August 4th, 2012 at 11:59 PM. Reason: holy grammar errors batman
Old August 4th, 2012, 11:58 PM   #3
MasterCylinder
Well I just ordered some adjustable ones off ebay. Hope it fixes it.
Old August 5th, 2012, 12:01 AM   #4
Monkeytofu
I told you bro
Monkeytofu's Avatar
They make them for the classic 250? I wouldn't see a reason for kawi to change the lever design from the classic to the current 08-12 "pregen" models but it could be different.
Old August 5th, 2012, 12:10 AM   #5
MasterCylinder
Well bollocks. Glad you mentioned that. I ordered the wrong ones =( stupid ebay.
*goes to cancel order*
Anyways, to answer your question I'm running stock levers.
Old August 5th, 2012, 12:32 AM   #6
Monkeytofu
I told you bro
Monkeytofu's Avatar
Good thing we caught it :O
Strange. Maybe it just changed from year to year. I always hear about these rattle issues from people but it hasn't affected me. I'm going to assume your handle bars are straight and the rest of the bike is in normal condition.
Give the washer thing a try.
You could make your own as well: http://faq.ninja250.org/wiki/My_clut...rev_the_engine But I'd recommend against it unless you have the steady hand for it.
Old August 5th, 2012, 01:03 AM   #7
MasterCylinder
Indeed! Yeah I'm not sure how I didn't notice it wasn't for pre-gen.
Handlebars look pretty straight to me. The engine just naturally vibrates so much it doesn't help.
I'll look into the washer idea. I thought about the shim thing before but it doesn't look like it'll be something do able in a way I'd be comfortable with.
Old August 5th, 2012, 11:42 AM   #8
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
Frugal shims - cut from coke cans
GeorgeRYoung is offline   Reply With Quote
Old August 5th, 2012, 06:10 PM   #9
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
Mine rattles at 8k. Unless I am on the highway. In which case it doesn't rattle until about 80 MPH.
dirty nasty is offline   Reply With Quote
Old August 7th, 2012, 05:10 PM   #10
Lychee
sail away
Lychee's Avatar
Strange. mine doesn't rattle at all, and I have a lot of free play. Perhaps add some grease to the points above and below the lever where the lever contacts the perch? Tighten the bolt and lock nut? Upgrade to EX500 perch and lever?
Old August 7th, 2012, 11:47 PM   #11
MasterCylinder
Go on
Old August 8th, 2012, 08:39 AM   #12
Lychee
sail away
Lychee's Avatar
Go on
http://faq.ninja250.org/wiki/I_want_...6_brake_levers
Old August 9th, 2012, 09:17 PM   #13
MasterCylinder
Ordered! XD
Fixed the clutch lever rattle but ... jones Jhon 2013 - 2017 Ninja 300 General Discussion 4 October 8th, 2014 09:43 PM
Annoying… speedo errors adouglas General Motorcycling Discussion 34 September 16th, 2013 05:43 PM
Annoying noise at 2,5-5 k RPM Graugaard 2008 - 2012 Ninja 250R Tech Talk 13 August 9th, 2013 08:24 AM
Annoying vibration at 6k RPMs jmisto 2008 - 2012 Ninja 250R Tech Talk 3 October 9th, 2012 05:02 PM
8-9k, annoying clutch lever rattle dimeified 2008 - 2012 Ninja 250R Tech Talk 8 January 30th, 2012 11:30 PM
