August 7th, 2012, 12:52 PM | #1 |
Join Date: May 2012 Motorcycle(s): Ninja 250r 2012 Posts: 60
Gauge backlight
Is there anyway to switch the stock gauge to light up brighter? or a different color?
Rah |
August 7th, 2012, 02:34 PM | #2 |
Ninja on a Ninja member
You can use LED's but Im pretty sure it just makes the blue in th gauges brighter
August 7th, 2012, 02:56 PM | #3 |
i dont have any blue in my gauge...
Rah |
August 7th, 2012, 07:36 PM | #4 |
Join Date: May 2012 Motorcycle(s): Ninja 250 and Gsx-R 750 k8 (out of commission) Posts: 482
check this out fred. Its 100 bucks - looks pretty cool
http://www.ebay.com/itm/Motorcycle-M...item3cc92f6537 |
August 7th, 2012, 08:02 PM | #5 |
Then you can pretty much pick any LED colour... but white is the better option if you want everything brighter...
have a look @ this link I think it's a black gauge ninja but you'll get the gist of LEDs http://www.ninjette.org/forums/showthread.php?t=64261 |
August 8th, 2012, 08:40 AM | #6 |
Ghost Rider
Join Date: Jun 2012 Motorcycle(s): 2012 Ninja 250r Posts: 84
I too am interested in this mod. I've found some cool blue and green LEDs online and just wanted to see if anyone can verify them for me. They're T10 194 168 501 bulbs. Also, I checked out the thread linked in this one, and it says that you need an LED relay if you change the turn signal dash bulb. So if I don't swap that bulb out, then I wouldn't have to worry about the relay?
August 8th, 2012, 09:05 AM | #7 |
The relay is for led turn signals. For the indicator to be led, you'd need to do the diode mod. Search that here.
I replaced all the lights behind my gauges with green leds and the lights behind the warning lights with the respective color leds. All my leds were from superbrightleds.com i like it a lot. Posted via Mobile Device |
August 8th, 2012, 09:31 AM | #8 | |
Ghost Rider
August 8th, 2012, 09:49 AM | #9 |
Yeah you'll be fine. Those are on their own circuit.
August 8th, 2012, 11:39 AM | #10 | |
Rah |
Fuel gauge backlight issue | botguy2185 | 2008 - 2012 Ninja 250R Tech Talk | 3 | January 3rd, 2014 07:55 AM |
Koso rx-2n 7 colours backlight were can i buy it | bandit_fosky | Items Wanted | 6 | September 10th, 2012 12:16 AM |
