Old August 14th, 2012, 05:33 AM   #1
rmorse
Motorcycle(s): 2008 Kawi Ninja 250R, 2013 Honda CRF450R, 2008 Honda CRF250R, 2001 Honda XR400
Ticking/clicking noise?
Hey guys,
What would cause a ticking/clicking/slight rattling noise when the bike is running? Bike has just shy of 15,000 miles. The sound is more prominent at lower RPMS, but that might be just because there is less ambient noise.
Also, seems it only really happens when bike is under load. So, it's pretty bad at lower RPMs and going about 20mph.
I'm about to do an oil change and see if I hear a change.
rmorse is offline   Reply With Quote
Old August 14th, 2012, 05:54 AM   #2
dubojr1
dubojr1's Avatar
Valves? They should have been checked and and/or adjusted twice by now with 15k.
Old August 14th, 2012, 06:26 AM   #3
rmorse
Yea, I was thinking valves too. Previous owner said he checked/adjusted the valves back when he should have. I need to check them soon. Do you think it can wait until winter? Or do I need to spend a weekend and do the whole 15k service soon?
Old August 14th, 2012, 06:48 AM   #4
dubojr1
dubojr1's Avatar
I would say soon but I will also say that I have seen this engine go 40k miles with no adjustment...
Personally I did mine at 10k and I'll look at them again around 20k unless I hear anything unusual.
Old August 14th, 2012, 11:25 AM   #5
rmorse
Damn man. I just feel like this is going to take forever and be extremely challenging.
Old August 14th, 2012, 11:37 AM   #6
dubojr1
dubojr1's Avatar
I admit the first time is kinda rough. Once you get in there and have a better understanding of what your doing then the stress level comes down. Second time should be breeze. Some of the DIY's I've seen have you taking all kinds of parts off like the radiator and engine mount.... I found that to be unnecessary and time consuming. Take as little off as you need to get your feeler gauge in there.
Old August 14th, 2012, 11:39 AM   #7
rmorse
Yea....I just don't want to do it either. I'm planning on running it down to the beach not this weekend but next. How bad would it be to put ~500 miles before checking?
This is what I'll probably end up buying:
http://www.amazon.com/Hot-Cams-Valve.../dp/B000WJWTM6
Old August 14th, 2012, 11:40 AM   #8
dubojr1
dubojr1's Avatar
I did my 1st one in about 5 hours but of course I had to stop to get my shims. The trip was probably an hour of that time. With shims in hand and focused on the job at hand, I think it could be done in under 2 hours. Of course your tool selection and your confidence and skill level will be factors. I'm pretty comfortable taking the engine apart.
Old August 14th, 2012, 11:43 AM   #9
dubojr1
dubojr1's Avatar
500 more miles will set the self destruct feature we have off. It will blow it to smithereens.
J/k... it will be fine.
Old August 14th, 2012, 11:44 AM   #10
dubojr1
dubojr1's Avatar
I considered that until I found out my dealer sells them for $2 a piece. I only ended up needing two shims.
Old August 14th, 2012, 11:52 AM   #11
rmorse
Bahahaha. Good to know. I'll park it and rip it open when I get back from the beach.
Legit. I'll call them up and see what's up!
Old August 14th, 2012, 01:50 PM   #12
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Click it or Ticket
AFM #676
Supersports are for n00bs
Old August 14th, 2012, 04:20 PM   #13
abhijitz
Motorcycle(s): Many Two Wheels ..
umm that doesnt sound right. I had a similar sound on my DRZ and it turned out to be a shim split in half. If the bike still runs, stop running it any more. Take the head off and inspect the shims/buckets. (Turn the bucket upside down and notice for visible indention)
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
Old August 14th, 2012, 04:23 PM   #14
Stingray1000
Stingray1000's Avatar
Motorcycle(s): 2003 Kawasaki Ninja 250R
You going to OC on he 25th? Or Virginia Beach? I'm riding mine down on the 25th to OC, MD
http://www.facebook.com/groups/DeMdNjPagrouprides/
I live my life a quarter mile at a time!
Who is affraid of the big bad jiggles???? LOL
Stingray1000 is offline   Reply With Quote
Old August 15th, 2012, 07:09 AM   #15
rmorse
It's done it for like 500 miles so far, but gotten worse....
Yea man, OC.
In other news, the bike was hard to start yesterday when hot, and popped. It then started right up. New symptom of the valves being off or new issue?
Old August 15th, 2012, 07:11 AM   #16
dubojr1
dubojr1's Avatar
The hard start could be valves as well.
The "pop" can happen to any of us. http://www.ninjette.org/forums/showt...ht=loud+garage
Old August 15th, 2012, 07:16 AM   #17
Stingray1000
Yea man, OC.
Dud you might wanna take it to a shop just for a once pver before you make that drive... Meg and I will be down all that week if you wanna hang out at secrets or do some rides down coastal hwy or something.
Old August 15th, 2012, 07:21 AM   #18
rmorse
Yea, but I don't know any legit shops here that I actually trust to know WTF they are doing.....
We'll see on chilling. Probably won't be able to. My brother is in town from Germany, so this is a family get-together at the beach. Haven't seen him in like 2 years, so I'll probably be sticking with them lol.
Old August 15th, 2012, 07:36 AM   #19
Stingray1000
Yea we're staying with her whole family too so I understand. But if for one night you and her wanna sneak away and grab a beer with me and Meg you got my number punk lol
ticking noise jcsalazar 2008 - 2012 Ninja 250R Tech Talk 5 October 29th, 2014 12:24 PM
Clicking, and Squeaking noise. Gavin_Coffey 1986 - 2007 Ninja 250R Tech Talk 48 May 23rd, 2014 10:19 AM
Ticking/Clicking noise coming off throttle patw 2008 - 2012 Ninja 250R Tech Talk 15 September 4th, 2011 04:01 PM
Strange clicking noise started last night... help? modrummer 1986 - 2007 Ninja 250R Tech Talk 6 August 28th, 2011 05:38 PM
Ticking noise on front wheel? Betlog 2008 - 2012 Ninja 250R Tech Talk 10 July 11th, 2010 11:14 PM
