Old August 19th, 2012, 09:08 PM   #1
Monkeytofu
I told you bro
Monkeytofu's Avatar
possible oil leak?
hey guys, finally got my bike up and running and I'm running into problem... again.
every once in a while I'll see a bunch of smoke start coming out from between the engine and the left fairing. It comes out in a considerable amount for about 10 seconds then stops.
Any ideas for what to look for tomorrow? I'm not seeing any loss in power and my oil light is not coming out. I wiped the inside fairing with my fairing after I got off and all I got was normal road grime, nothing oily.
Old August 19th, 2012, 09:21 PM   #2
lgk
does it smell like burnt oil?
are you riding in the rain?
Old August 19th, 2012, 09:40 PM   #3
Monkeytofu
I told you bro
Monkeytofu's Avatar
Smells like burned oil. It rained yesterday, but my bike was dry today.
I'm not sure if it's something I used to clean my fairings or the heat tape burning on the bottom, or oil. There are so many oil based things down there.
Old August 19th, 2012, 11:38 PM   #4
EMSRacer07
EMSRacer07's Avatar
smell coming from the air box? could just be the crankcase venting off alot. mine does that too and sometimes smokes white a bit and can spit some oil out.
Old August 19th, 2012, 11:44 PM   #5
Monkeytofu
I told you bro
Monkeytofu's Avatar
I'm getting the smell from the smoke coming up so it's coming from the bottom. My headers had some liquid on them around the area where they bend into the engine.
I'm just shooting random ideas out but it could possibly be a loose valve cover? I tightened them to spec last time I checked.
Old August 19th, 2012, 11:48 PM   #6
EMSRacer07
EMSRacer07's Avatar
you know what it might be. I have had a liquid spray on my engine and leak on my headers and fairings and even got to around my leg area via gas tank. Turns out was my fork seals were bad and was spraying oil everywhere. Thought it was coming from valve cover too but was my fork seals. could look there. I used to get oil on the inside of my fairings and bottom side of my tank and would leak down on my boots. try looking there.
Old August 20th, 2012, 12:28 AM   #7
Monkeytofu
I told you bro
Monkeytofu's Avatar
I'll give that a look. Should I see oil come out of my forks if I pump my handle bars?
Old August 20th, 2012, 12:35 AM   #8
EMSRacer07
EMSRacer07's Avatar
probably not. mine would only get really oily on hot days and when i road around town so like bumpy roads but it all depends on the fork seals, thats if it is the seals. You could try to pump on the handle bars and see if alot of the fluid stays on the tops of the forks. look under the gas tank my forks were spraying that with oil
Old August 20th, 2012, 11:03 AM   #9
Monkeytofu
I told you bro
Monkeytofu's Avatar
I looked around my bike and no dice. Seems the oily stuff was just paint peeling off my headers so I don't it's the fork seals.
my inner fairings looked foil free and the ground under my bike had no spots. No idea what could be burning down there but I'll try riding it around today and seeing what comes up. I think it could possibly be the old heat tape burning up as it peels away from old age, so I'll replace that soon/ take it off and see what happens.
Old August 20th, 2012, 11:43 AM   #10
do you have a stock crank case breather that goes into the intake? or a separate breather element.
Old August 20th, 2012, 12:16 PM   #11
Monkeytofu
I told you bro
Monkeytofu's Avatar
I assume it's stock as I'm not familiar with this part of the motorcycle I'll check if you point it out to me.
Old August 20th, 2012, 12:19 PM   #12
do you have pod filters or a normal airbox. check under the airbox if you have it, theres a tube that runs from the engine crank case to the airbox. this is called the crank case breather and its there cause you know you have the pistons going up and down and gases expanding and stuff and it needs somewhere to go, so at the top of the case theres a hole that leads up through a snaking tube to the airbox for it to breathe. sometimes smoke from the oil comes through there but it gets sucked back into the intake and gets spit out the exhaust. if that tube isnt connected a little bit of smoke can come out. if it is open and oil gets splashed up through the hole, it can sit ontop the crank and make some smoke
Old August 20th, 2012, 12:54 PM   #13
Monkeytofu
I told you bro
Monkeytofu's Avatar
Oh ok. Yes, I have a stock airbox, the smoke comes out between the lower fairing and the exhaust. I don't know if it's the appropriate way to describe it but it's white and billows out for maybe 10 seconds. it comes out in a a 3/4 inch long area.
The breather tube is located near the center right?
About to go ride and see if the issue comes up again and if I can tell where in the day light.
Old August 20th, 2012, 01:47 PM   #14
where is your water reservior drain line located? look at your exhaust where the smoke comes from, is it all white? look at your water reservior, is there coolant on the outside? does it do it when its nice and hot on a hot day?
Old August 20th, 2012, 01:52 PM   #15
EMSRacer07
EMSRacer07's Avatar
yeah its right in the center. right under the carbs
Old August 20th, 2012, 11:44 PM   #16
Monkeytofu
I told you bro
Monkeytofu's Avatar
Last time I checked it was in the middle/ 1/3rd above the line. I'll check tomorrow.
My exhaust is not white, it doesn't look like anything has dripped on to it at all.
Yes, the smoke is white. Is that a sign of burning oil? I'm forgetting if burning oil was blue or white smoke.
Old August 21st, 2012, 11:44 AM   #17
burning oil is typically blueish but it depends on where and how hot it burns. if it was on the outside of the case it would probably look light bluish grey. the radiator is a closed system unless the water boils, the pressure becomes too much and the system has to purge the excess into the surge tank (the water "resevior"), once it cools down, a vacuum develops in the water system and pulls the extra back into the system. if it purges too much there is a drain line on the surge tank that leads down to the bottom of the bike. water and coolant typically burn white smoke. there are lots of water hoses going around there and if some spilled onto the engine it would evaporate/burn/disperse very quickly.
what im trying to get at is the surge tank might look normal and your radiator is actually low if the surge line isnt leading to the surge tank. or maybe you just really had to piss and didnt know it.
Old August 21st, 2012, 01:35 PM   #18
Monkeytofu
I told you bro
Monkeytofu's Avatar
Hmm, maybe my system is heating up too fast. I had my coolant cap slightly open for a day or two and maybe too much evaporated out and now there's an uneven mixture of water and coolant.
Thanks for the help guys, I'll check it out and see what I can find out
Oil leak.... skilletmo 2008 - 2012 Ninja 250R Tech Talk 13 October 24th, 2014 09:31 PM
Oil leak Xaero 1986 - 2007 Ninja 250R Tech Talk 11 November 16th, 2013 06:58 PM
Oil Leak? Fakker 1986 - 2007 Ninja 250R Tech Talk 5 September 6th, 2013 06:38 AM
Oil Leak thisisbenji 2008 - 2012 Ninja 250R Tech Talk 10 December 12th, 2012 06:59 PM
Oil Leak Help sjc88 1986 - 2007 Ninja 250R Tech Talk 7 December 29th, 2011 04:13 PM
