September 4th, 2012, 12:58 PM | #1 |
Join Date: Mar 2011 Motorcycle(s): 250r '08 Candy Plasma (best) Blue Posts: 80
Wheel Size
Anyone know if pre-gen 250r wheels will install onto current gens?
September 4th, 2012, 01:25 PM | #2 |
pre-gen = 16" and new gen = 17"
Not sure if you can put the newgen rims/tires onto a pregen?!? |
September 4th, 2012, 01:27 PM | #3 | |
dont really see a disadvantage to dropping the rim size.... im more experienced in the car world and really going down a size can be beneficial as you get more usable side wall for roll over...i would assume that would hold true in the motorcycle world maybe i will go out and measure the bores and see if all the bolts will pass through them |
September 4th, 2012, 01:37 PM | #4 |
I know there are a lot more tire options for 17" rims, then for 16" rims...hopefully someone who knows for sure will pipe in
September 10th, 2012, 08:37 PM | #5 |
Accesories Guru
Join Date: May 2011 Motorcycle(s): '99 EX250(Cafe/fighter project) Posts: 537
Bite the bullet, aside from the disadvantage of having to hound your preference of tires on a 16" rim, the disc allocation on the new gen forks calls for the bigger wheel, the hubs are different and designed for ech gen and therefore not interchangeable.
2008+ Ninja 250 Carburetor Screw size, allen screw size! | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 2nd, 2015 11:49 AM |
[RoadRUNNER] - 2015 KTM RC390: Fun Size is the Best Size | Ninjette Newsbot | Motorcycling News | 0 | September 9th, 2014 03:01 AM |
wheel / tire size help | SON1C | General Motorcycling Discussion | 5 | September 25th, 2013 04:10 PM |
[sportrider - latest stories] - Wheel to Wheel AMA Pro Flat Track Action Returns to S | Ninjette Newsbot | Motorcycling News | 0 | September 24th, 2012 06:40 PM |
WTT: Size S Synergy Heated Gloves for Size M like kind | headshrink | Items Wanted | 0 | March 26th, 2009 01:45 PM |
