Old September 10th, 2012, 04:06 PM   #1
fixxervi6
Motorcycle(s): '01 250 '10 20 '09 GSXR 750 '97 KX100 '97 KX125 '06 GSXR 600
'01 engine assembly
Hello, I have an 01 engine that I split open, thinking it was going to be trash.
When I pulled the case bolts to split the case I just threw them all in a bag, I didn't keep track of where I pulled them out of.
I split the case and the problem turned out to be very simple, fixed the problem (gear problem in the transimission) and now it's time to reasemble.
Anyway, I have the service manual that gives me the torque specs, but not all of the bolts are the same length, I need to find something that will tell me what length bolt goes in which whole.
Also, the book says to use liquid gasket, but it doesn't say how much to apply, will any type of liquid gasket do?
thanks in advance
fixxervi6 is offline   Reply With Quote
Old September 10th, 2012, 04:11 PM   #2
paging @Racer x, the engine guru
and alex.s!!! sorry dude! I completely forgot that you've had your case open
Last futzed with by choneofakind; September 10th, 2012 at 08:11 PM.
Old September 10th, 2012, 04:16 PM   #3
use kawibond
there are only 2 bolts that fit in multiple holes, and they are in the oil pump (the shiny allens, there are 3 different sizes and they can be used interchangibly except for the long ones can only be used in the long holes. its easy to mix those up.
basically, the thicker bolts go on bottom, the thinner longer bolts go on top, the smaller thin bolts go along the perimeter and on the covers. dont forget the bolts inside the oil filter slot
Old September 10th, 2012, 06:29 PM   #4
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Alex has it
As for sealant. I use Honda bond . But not much. I clean clean clean the case half's. Then smear a VERY small amount of the gray sealer on the top side.
I put it on very thin and kinda rub it on. Using the sealer almost as a cleaner. You can see if it is sticking to the case half. Always wiping it off the edge or inside the case. After is sits for about fifteen minutes. I then put the bottom on and bolt it down. There are a number of things like the oil feed pipe that fits under the stater. And the shift fork that tangles in there making the assembly a bit tricky. You might want to try a dry run.
What you don't want is sealer squeezing into the case. The extra sealant breaks off in strings and clogs the oil pick up tube.
Worlds fastest 250 ninja
Old September 10th, 2012, 06:50 PM   #5
fixxervi6
Thanks guys, I'll give it a few dry runs.
Old September 19th, 2012, 07:07 AM   #6
fixxervi6
She's back together and she lives
I went to bikebandit.com and looked at their oem parts for the bolt pattern for the case, then just measured each bolt according to their parts list (parts list gives bolt size) and just threw them in based on the diagram, got it right on the first try.
Old September 29th, 2012, 08:08 AM   #7
I used Hondabond but switched to high-temp RTV sealant from the same company that makes Loctite. Seems to be what the service manual called for and I'm tired of manufacturers getting away with monopolistic practices like trying to force their parts, supplies, and tools on you.
Old February 22nd, 2013, 06:19 PM   #8
jayman87
Motorcycle(s): 2007 ninja ex250
Is this what you were talking about.
http://shop.advanceautoparts.com/web...=high+temp+rtv
I bought this before I thought to look up what other people use.
http://shop.advanceautoparts.com/web...rm=ultra+black
jayman87 is offline   Reply With Quote
Old February 25th, 2013, 04:50 PM   #9
Yep. I doubt the engine gets over 500-degrees so I'm sure they both work well.
[roadracingworld.com] - Suzuki Motor Corporation Moving ATV Engine Assembly Work To R Ninjette Newsbot Motorcycling News 0 June 17th, 2014 10:00 AM
Want to Buy: front/rear signals, headlight assembly, tail light assembly for 2009 rph12 Items Wanted 1 July 15th, 2012 08:02 PM
[kropotkin thinks...] - Engine List From Sepang 2010 - Engine Penalties Loom Ninjette Newsbot Motorcycling News 0 October 13th, 2010 04:00 PM
