Old September 11th, 2012, 10:48 AM   #1
Xer0-
Motorcycle(s): 06 250 rat, 20 400 krt
Tail light
Does anyone know of any company that makes a led tail/turn unit for pregens?
Or am I going to have to make my own?
Xer0- is offline   Reply With Quote
Old September 11th, 2012, 12:41 PM   #2
I'm unaware of any companies who make an LED tail light for the pregen. If you find anything, let me know.
Old September 11th, 2012, 03:30 PM   #3
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
I just put LED bulbs in my existing tail light housings, dual brightness for the center and single brightness for the two outers wired as extra brake lights.
Old September 13th, 2012, 08:47 AM   #4
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
Frugal, is it noticeably brighter?
iplante is offline   Reply With Quote
Old September 13th, 2012, 10:26 AM   #5
FrugalNinja250
The center bulb is dual filament in stock configuration, with about a 25/75% split in brightness. The new LED bulb is about 90% as bright on high as the incandescent bulb was, and it has more of a 40/60% split in brightness. However, the side bulbs are about the same brightness as the incandescent on high, and since the side LEDs are on/off instead of dim/bright the effect of brake lights is much more apparent.
Old September 13th, 2012, 10:42 AM   #6
LED's are great for the pods, like Frugal said.
If you're looking for a bright center brake light, use a 2357 bulb. Same running filament. Bright brake filament.
Old September 13th, 2012, 08:07 PM   #7
jschatte
jschatte's Avatar
Motorcycle(s): 1988 Ninja 250
I am running these replacements in all three sockets. They are expensive bulbs, but they illuminate just as well as the incandecents and use about a fifth of the power.
http://www.ebay.ca/itm/230817098823?...84.m1497.l2649
jschatte is offline   Reply With Quote
Old September 14th, 2012, 08:48 AM   #8
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
any led light needs the resister wired in though right?
im putting an R1 tail and light on my bike so i bought resisters and the led taillight
The King
rabies is offline   Reply With Quote
Old September 14th, 2012, 12:28 PM   #9
It only needs resistors if it's flashing, like a turn signal, and uses a load-based flasher.
Old September 14th, 2012, 08:30 PM   #10
rabies
rabies's Avatar
i hav yet to i stall an r1 integrated tailight on thebike. im sure wire the resisters with the turn signal power wires yes?
The King
Old September 14th, 2012, 10:38 PM   #11
Sure, you can wire resistors in line with the turn signals.
The other option is to buy an electronic flasher that doesn't depend on load for flash rate.
Old February 4th, 2013, 09:59 AM   #12
kazman1
King of Kazmania
kazman1's Avatar
Motorcycle(s): '02 ZRX 1200 R x2 - '03 EX250F
I wired in two 1157 lamp sockets in the outside lenses & installed three - 13 section white LED 1157 lamps.
All three lenses act as both running lights and brake lights.
OBTW... while I was at it I removed the red plastic piece in the bottom and siliconed a clear piece of plexi in, which lights the license plate on the homemade fender eliminator.
Did I mention I paid $400.00 for this bike
SAY WHAT YOU MEAN, DO WHAT YOU SAY
kazman1 is offline   Reply With Quote
Old February 4th, 2013, 10:18 AM   #13
Old February 4th, 2013, 11:06 AM   #14
iplante
iplante's Avatar
@kazman1, did you just cut your existing fender and leave the tabs for the turn signals or.. ?
WANTED for 88-07 Ninja 250:
Corbin Gunfighter & Lady seat
Old February 4th, 2013, 11:39 AM   #15
kazman1
King of Kazmania
kazman1's Avatar
Yup, old ZRX mod.
I'll soon transplant a pair of ZRX 3-wire front signals, using the wire from the now defunct license plate light to have front running lights. (red w/blue stripe I believe)
I believe in DOT spec lighting, there's a reason it's required...
IT WORKS.
Old February 4th, 2013, 12:30 PM   #16
iplante
iplante's Avatar
I'm planning on doing my own DIY fender elimination this summer. I plan on leaving the tabs for the turn signals - I don't want to integrate them in the tail light. I do think that the pregen's turn signals are ugly as ****, so I may put new gen rear turn signals instead.
For the front, I got some flush mount signals that I will install and try to wire as DRLs using http://www.tobefast.com/customled-ma...er-pr-479.html
Of course, none of that may happen if I don't have any $
Old February 4th, 2013, 05:41 PM   #17
^^ DRL's rock. If anything, make sure you do that.
Old February 4th, 2013, 08:11 PM   #18
I got some dual 1157 LEDs that I plan to wire as running lights, brake lights, and turn signals as soon as I can figure out how to to kill the running/brake function while the signal flashes.
Old February 4th, 2013, 08:26 PM   #19
There was a thread a while back about using a brake controller like you'd use on a trailer.
Old February 4th, 2013, 08:37 PM   #20
Yep, and it comes really close but it still needs another relay or two to work exactly right.
Old February 5th, 2013, 04:52 AM   #21
kazman1
King of Kazmania
kazman1's Avatar
Forgot to mention, move the turn signal stalk spacers to the inside of the fender.
Tightens up the rear
OEM Tail/Brake Light Comparison to LED Tail/Brake Light g21-30 2008 - 2012 Ninja 250R Farkles 19 November 7th, 2009 12:08 PM
