October 1st, 2012, 04:12 PM | #1 |
Join Date: Jun 2012 Motorcycle(s): '12 Ninja 250r, '72 Honda 350 Posts: 23
Help!! install fender eliminator
Oh great ninja sensei i need advise, got the reat seat and rear faring removed and trying to install Yoshimura fender eliminator. I have read and seen all threads relating to this but most of you just mention how easy it is and how simple the instructions are! I must have had one to many hits to the head growing up because i have run into an impass.
Directions say: 1. remove passenger seat and disconnect tail light, turn sigs, and lic plate lite. (done i think) 2. remove stock fender by removing 6 bolts. (i only see 4 hex and those are removed, where are the other two? 3. drill out the 2 rivets on the turn signal bracket attached to the fender? WTF? what rivets do they mean the phillips that holds the turn sigs on? so no sense going on with the rest although they look fairly easy to follow. Any and all help would be greatly appreciated!!! |
October 2nd, 2012, 11:59 AM | #2 |
Join Date: Jul 2012 Motorcycle(s): 2009 Ninja 250R C.T. Blue Posts: 28
1) you probably did it right
2) the other two are the two that hold the tail lights 3) there are two small metal rivets on each turn signal bracket. they're the only silver parts of the black bracket. I can't find a pic right now, but i'll try to take a pic of where they should be later. |
October 3rd, 2012, 09:19 AM | #3 |
Thanks nvxdiz, still stumped on the rivits that need to be drilled out. do you access from underneath or from above? Any pics would be very helpful.
And thanks again for the help. |
October 4th, 2012, 09:29 AM | #4 |
Not my picture, but here is a pic of one of the turn signal brackets. Within the red circles, are the two rivets that you have to drill out from each bracket.
October 4th, 2012, 10:05 AM | #5 |
Thanks man, that really helps!!! I'll post a pic once i get it on.
October 8th, 2012, 10:31 AM | #6 |
October 8th, 2012, 02:14 PM | #7 |
looks good, the yoshi f.e. is definitely awesome!
October 9th, 2012, 09:43 AM | #8 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
yoshi f/e ftw!
Yoshimura fender eliminator install question | joecool | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 13th, 2014 08:20 PM |
How to install Yoshimura Fender Eliminator | reroka | 2008 - 2012 Ninja 250R Farkles | 4 | June 14th, 2014 05:20 AM |
Competiton Werkes Fender Elim Install | newninja123 | 2008 - 2012 Ninja 250R Farkles | 1 | July 10th, 2012 01:49 PM |
Help! Rear fender replacement (not fender eliminator) | mcnuggett | General Motorcycling Discussion | 7 | April 30th, 2012 08:24 PM |
Hotbodies Fender Install | james.gravley | 2008 - 2012 Ninja 250R Farkles | 23 | February 27th, 2012 06:49 AM |
