View Poll Results: How wide are your chicken strips?
3/4" + 9 23.68%
5/8" 0 0%
1/2" 3 7.89%
3/8" 3 7.89%
1/4" 1 2.63%
1/8" 4 10.53%
No chicken strips -- I can lean all the way 4 10.53%
I'm a peg scrapin' fiend! 4 10.53%
Who cares? 10 26.32%
Voters: 38. You may not vote on this poll
Old January 9th, 2009, 10:18 PM   #1
stingray
Motorcycle(s): 2008 250r
How wide are your chicken strips? Can you scrape your pegs?
hey y'all, since this is a more "mature" crowd than those "other" forums, i'd like to get a thread and a poll started over here...
i've been riding since october and already logged 2800 miles. i go down some decent twisties around my area, but haven't been down any truly mountainous terrain yet. still practicing on my skills before braving the mountain curves.
for the record, i'm the type that doesn't mind going 70-90 mph down a deserted country road with some decent twisties. however, i still have about 3/8" of chicken strips! perhaps i'm being on the conservative side around tight turns, i dunno. i'm trying to build confidence to lean fully, but i usually get to a point where i question the bikes ability to grip the pavement so i tend to back it off.
so what is your opinion on the matter? should a sportbike rider at least be *CAPABLE* of fully leaning just in case an emergency scenario ever arises that calls for a full lean? now i'm not implying one should scrape the pegs every day, but at least have the ability to feel confident at full lean (thus no chicken strips).
i'll be riding tomorrow (saturday) and practicing leaning so i'll update.
stingray is offline   Reply With Quote
Old January 9th, 2009, 10:27 PM   #2
Cling
Cling's Avatar
Motorcycle(s): 06 Honda 1000RR, 08 Ninja 250
The tires on the 250 are very tall and thin, it doesnt take much lean to get this bike turning very fast, because of this you need to be going very fast and hard in order to rid your bike of the strips.... for some this is 'dangerously' fast.
Cling is offline   Reply With Quote
Old January 9th, 2009, 11:45 PM   #3
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
Motorcycle(s): 08 Kurosaki 250, 09 Honda 600RawrRawr
I don't ride nearly fast enough on the street to scrub the edges of my tire.
On the track, sure.
Depends on how much of your body you're using too. Some people keep their butt glued to the seat and lean way over when they could be leaning much less at the same speed using their body or go faster with the same lean + body positioning. I don't believe in trying to wear out the edge of your tires on the street. Take that ish to the track.
I ride pretty quick pace on mountain roads but still not to the edge of the tire. That kinda riding requires alot of commitment and trust in the turn, your tires, and half a dozen other conditions. I don't have those kinda balls for the street. The edges of my tires get ragged from the track and I never ride hard enough on the street to scrub that stuff off. But I can see how far I'm leaning in my street riding by looking at how much track rubber has been cleaned off.
I can't think of an avoidance situation where you would need to be leaned so far over scraping your pegs unless you were already cranked over pretty good and needed that extra lean to miss something? I dunno. That's what peg feelers are for. (I took mine off though. I know where my limit is.) Even on the track, for me, dragging peg means I need to back off or I'm being lazy with my body position.
In short, not having chicken strips is not necessarily a good thing. It doesn't really mean much.
I use the same riding technique and style on the street as I do on the track. I just ride slower on the street.
Kurosaki is offline   Reply With Quote
Old January 10th, 2009, 06:54 AM   #4
Cling
Cling's Avatar
Yep its very true, some people think they are 'being cool' by ridding all their bikes of chicken strips so easily because they can stay glued to the center of the seat around turns, but the funny thing is that somebody who has good form and gets off could do the same turn at the same speed with probably half the lean angle of the glued on person! I try to use my bottom as a gauge usually, I always try to get one full cheek off in the turns ;P
Old January 10th, 2009, 09:23 AM   #5
ScraitT
Green!
ScraitT's Avatar
Motorcycle(s): 08 Ninja 250R, 04 Honda CRF230F, 94 Honda XR80R
Chicken strips are the most misleading sign of a "good" rider.
I have no chicken strips on the left side of my tires. Why is that? Because of a U-turn I have to do on the way home. This is NOT a tight U-turn (about 4 lanes) and it is not at high speed (maybe 10 mph). I just have a little fun leaning the bike over through the turn with absolutely NO riding technique at all.
Now the right side of my tires probably has about 1/4th" on strip left because I rarely have to turn right. The closest I get is a large S-Turn on the way to work that I could easily do at max speed on the 250 and not have to lean to the edge.
I'd love to get a track day in and see how far I can really lean it the right way, but that cost a little more $$ then I have atm.
2008 Green 250R
ScraitT is offline   Reply With Quote
Old January 10th, 2009, 03:51 PM   #6
aloh
lolwut
aloh's Avatar
i love chicken strips.
08 Blue Ninja 250R
aloh is offline   Reply With Quote
Old January 10th, 2009, 03:53 PM   #7
BlueTyke
So slow I'm first!
BlueTyke's Avatar
Motorcycle(s): 06 Kawasaki Ninja EX250
I really wanted to vote but... I have only scraped peg on accident and even then I wouldn't be able to tell you how wide my 'strip' is...
My witty answer was... 3/4's inch fried please...
Learn from the mistakes of others, you cannot make them all yourself. Save yourself the trouble and Learn.
BlueTyke is offline   Reply With Quote
Old January 10th, 2009, 04:20 PM   #8
Guinss
Guinss's Avatar
Motorcycle(s): 2008 250R (Black)
By chicken strips you mean what areas of the tires that havent got "dirty" by riding right? Or have i misunderstood?
Have never thought of checking that kind of things after a ride. Will do that when season starts again
I've scraped footpegs on stock tires(roadwinner), only once at 15mph hehe, no problem. So that made me trust those pegs to be a limit for how long down i can go. But i dont know how much grip there are left after pegs are touching ground. probably some for safety matters.
Guinss is offline   Reply With Quote
Old January 10th, 2009, 04:27 PM   #9
HKr1
IC2(SW)
HKr1's Avatar
Old January 10th, 2009, 04:40 PM   #10
Broom
Track Junkie
Broom's Avatar
Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike
fyi for the noobs: chicken strips are the portion of your tread that hasn't had the release compound scrubed off yet.... you can tell the difference cause its a little shiny and the rest of the tread is dull.
it really is a poor gauge, but its still rewarding the first time you get rid of them. some tire profiles make it imposible to use the entire tire, while others are way too easy.
i saw this bike parked outside of a bar. it was a cbr1000 or something. made me sad that this poor bike never gets to do what it was designed for
Las Escobas -- Track Bikes Save Lives
JonBroom.com
Broom is offline   Reply With Quote
Old January 10th, 2009, 05:11 PM   #11
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
The roads around where I live are often a little banked, so it takes more speed to be able to go further on the tyre. There are places, tight corners that I can do 60 kph in my car in and the front is just about letting go, then I could be doing 100 kph round the same corner on the Ninja and she takes in no problems. I prefer to get off the seat and move, lean in more when I ride fast as I feel it keeps me in the zone and focused.
Also, I am not sure I trust the roads around here that much to be riding right to the edge as there are many things that can go wrong, and if you need a little more lean for whatever reason, and it is not available, things can turnout very nasty...
On the track is another story, there are fewer things that can go wrong (debis, stupid cagers etc etc) so you can push the bike further.
Viper-Byte is offline   Reply With Quote
Old January 10th, 2009, 07:25 PM   #12
stingray
thanks for the good info guys. i do tend to partially hang a buttcheek over in tighter turns, so that could definitely be a reason i still have some strips on the sides. i practiced some low speed u-turns, figure 8's, offset weaves, etc today and made them strips a little narrower. but i did manage to scrape my shoe that was below the shifter, that kinda sucks when it takes you by surprise!
at the very least, i like to know my bike's limit in case a hazard ever presents itself that requires a full lean maneuver. that said, i'm pretty sure i don't need to go much faster than i already do down the twisty country roads.
Old January 10th, 2009, 07:42 PM   #13
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
in that case - you left off the 'who cares' option....
Old January 10th, 2009, 07:51 PM   #14
Fixed.
Old January 10th, 2009, 08:00 PM   #15
aloh
lolwut
aloh's Avatar
an option for "too wide to fit in the dipping sauce" isnt there either
08 Blue Ninja 250R
Old January 10th, 2009, 08:05 PM   #16
noche_caliente
Originally Posted by Alex View Post
Fixed.
Thanks!
Old January 10th, 2009, 08:15 PM   #17
KnoxNinja
BRKDWN.
KnoxNinja's Avatar
Motorcycle(s): 89 GPX250R, 89 GPZ500S
I think I have a whole drumstick and half a thigh. I'm still new to riding, but when I practice taking turns, I try to take the turn as fast as I can while leaning the bike as little as possible. I try to increase my speed through the turn by mostly using body position. When I get that down, then I'll lean the bike more as necessary.
Oh, and that liter-bike up there is doing what it was designed for... going stupid fast in a straight line
KnoxNinja is offline   Reply With Quote
Old January 11th, 2009, 03:16 AM   #18
Guinss
Guinss's Avatar
at bike traffic school the teacher said that the bike often could lay down alot more than the rider dared.
Chicken strips anyone??? salcuta88 Free stuff! 12 October 25th, 2014 05:57 PM
Chicken strips? blink General Motorcycling Discussion 221 August 19th, 2014 07:58 PM
How are my chicken strips? rasta General Motorcycling Discussion 35 September 5th, 2013 06:29 AM
In defense of Chicken Strips eddiekay General Motorcycling Discussion 82 November 15th, 2012 05:58 PM
Chicken Strips Liist Riding Skills 68 January 28th, 2012 12:25 PM
