Old November 4th, 2012, 07:05 PM   #1
deanomyte
Motorcycle(s): 99 honda rebel/ 04 ninjette
starting problems
Hi all, Just bought an 04 ninjette that was wrecked, no major damage that I have found yet. Bike ran before the wreck but doesn't start now.
What I've done so far: New battery, checked all fuses, checked the neutral switch and neutral light is on, Getting power to starter relay and consistent power when the start button is engaged on both sides of the relay. The starter just clicks once but does not turn the starter motor. I'm thinking the starter motor is toast!
Don't know if this is relevant but the clutch will only engage 1st gear, not up to 2nd from what I can tell, but haven't been able to get it to start.
deanomyte is offline   Reply With Quote
Old November 4th, 2012, 07:08 PM   #2
try push starting it... the rear tire has to be spinning for the positive neutral finder to let you get into 2nd/beyond
Old November 4th, 2012, 07:44 PM   #3
deanomyte
can't push start it yet the rear wheel is rubbing on the caliper mount on the top right side of the swing arm, it not bad but i need to get new chain tensioners to straighten out the wheel so it won't rub!
Old November 5th, 2012, 12:22 AM   #4
Lychee
sail away
Lychee's Avatar
pull off wheel and reassemble with correct spacer order
Old November 5th, 2012, 03:59 PM   #5
deanomyte
thats a great idea. but what about the starter motor, is it toast? I can't get any power to the starter motor itself, but the wire to the starter motor has power.
Old November 5th, 2012, 04:18 PM   #6
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Sounds like it is toast. If you're able to pushstart it then that I would be even more suspect. If you have a friend w/ a 250 you might ask to borrow theirs to double check. If not maybe check the connection is solid before looking for a used one...
Old November 5th, 2012, 04:20 PM   #7
--edited for stupidity--
when removing and replacing the starter, the little post can get rotated, if its rotated just right it will short and not turn the motor. try removing the motor and and checking resistance... try connecting it directly to a battery
Old November 5th, 2012, 06:59 PM   #8
deanomyte
thanks for that info, i'll give it a try!
Starting a MotoVlog! YamiLionheart Videos 3 April 22nd, 2013 03:28 PM
Problems starting engine Slono 2008 - 2012 Ninja 250R Tech Talk 7 March 31st, 2012 08:38 AM
starting problems dago 1986 - 2007 Ninja 250R Tech Talk 21 March 17th, 2012 01:50 PM
Problems Starting running a bike danius 2008 - 2012 Ninja 250R Tech Talk 0 October 28th, 2010 05:39 AM
Starting in First Momaru 2008 - 2012 Ninja 250R Tech Talk 11 April 12th, 2010 06:57 PM
