#1 |
Bass Master General
My oil sight glass is cloudy and has been getting more so over the last few months, I am assuming it's to do with the temperature being rather low and that I do fairly short journeys on my bike it gets some condensation?
Since my bike is going to be grounded for the next few weeks I may as well chuck in an oil change so that will be done soon, just wondering what causes this and if it's super serious? Sorry the pic is a bit rubbish. |
#2 |
That doesn't look like the classic cold weather/condensation milky color nor does it look like aerated or foamy oil. That looks more like a good size amount of water/coolant in your oil.
#3 | |
Bass Master General
Suggestions on fix's? My oil itself isn't milky, it's still lovely and new looking from the sight glass when I tip it to level. And you would have thought the oil would have emulsified with the coolant turning it a funny colour? |
#4 | |
Water vapor is a natural part of the exhaust gases, and it is pumped down into the crankcase while the rings-cylinder are cold and leaking more than normal. Maybe the crankcase is not properly ventilated (modification to snorkel?) Open the oil intake for a while when the environment is dry.
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#5 |
Bass Master General
The environment is NEVER dry
![]() ... I think I have answered my question, I took it out for a good ride, was quite aggressive on the clutch as to warm up the oil and it disappears after it's warm. I'll do my oil change later this month and see what's what then. Thanks very much for the help! - If I knew how to rate posts as useful I would ![]() |
#6 |
Condensation will come back after the air trapped inside the crankcase cools down.
The amount of water vapor that any mass of air can hold is proportional to its temperature. While the air cools down, it must let go certain amount of vapor. That vapor will find its dew point or temperature of condensation whenever it contacts cool surfaces, like the sight glass (which transfers the cooler ambient temperature very well to the internal surface). The pressure of that vapor should naturally make the excess leave the crankcase via the vent, equalizing in's and out's relative humidity (then, no more condensation after everything balances); that is why I asked about the snorkel and opening the fill up port for a while (after the engine and oil are cool). You are very welcome. ![]()
#7 | |
Bass Master General
This in itself probably explains it. My coo lent level is good. |
#8 | |
Sometimes that thin layer of condensation is microscopic (we cannot see it), but mixed with fine dust and oil, makes a perfect lubricant for our tires.
#9 | |
Bass Master General
I'm going to clean my tyres with dish soap at some point, they feel especially slippery, more so today, maybe I got some chain lube on them I can't figure it out. |
#10 |
Oil and Diesel on the road become more dangerous when water is present, since they float over the film of water and the tire is fully exposed to their "lubricating" effect.
Oil and Diesel on dry roads sinks down to the bottom of the micro-valleys; hence, not the full contact patches' areas reach down there. Many years ago, my brother had a very bad accident in a Jeep that slid and rolled over several times on a road that was just slightly wet. Glad your oil is not contaminated with coolant !!!
Oil level sight glass | adouglas | General Motorcycling Discussion | 53 | May 16th, 2013 02:30 PM |
Oil sight glass | BlueHairSar | 1986 - 2007 Ninja 250R Tech Talk | 20 | December 13th, 2012 01:23 PM |
Oil sight glass needed. | jonnyc | Items Wanted | 1 | August 12th, 2011 07:25 AM |
Foamy Oil in Sight Glass??? | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 19 | May 17th, 2010 07:00 PM |
Oil Sight Glass | empyrean | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 25th, 2009 10:25 AM |
