Old January 3rd, 2013, 08:49 PM   #1
cuong-nutz
cuong-nutz's Avatar
Where to find oversized piston rings?
I remember seeing a thread with a website that listed oversized piston rings but can't seem to find it. Can anyone help?
HalfFast Racing Team
Old January 3rd, 2013, 09:50 PM   #2
This one?
http://www.ninjette.org/forums/showt...light=oversize
Send a PM to Racer_x, he will know.
Old January 3rd, 2013, 09:54 PM   #3
hmm, i couldn't find anything with the google search or the traditional searches.
Old January 3rd, 2013, 10:04 PM   #4
lgk
Are you planning to bore it .020 over?
Old January 3rd, 2013, 10:33 PM   #5
cuong-nutz
cuong-nutz's Avatar
Originally Posted by Motofool View Post
This one?
Maybe I mistook seeing oversized rings for big bore pistons. Either way, I'll shoot Eric a PM.
@Racer x
Old January 4th, 2013, 06:17 AM   #6
lgk
NM, all the overbore kits are 2mm, which is a lot more than an just a rebuild.
Old January 4th, 2013, 06:33 AM   #7
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
First how do you know it's the rings? If the cylinder is just glazed you can hone the cylinder and install new rings. You can get a larger ring and cut your own ring gap if it is that far gone. But the pistons might need to be knerled to stop them from rocking. At that point I would just over bore.
Worlds fastest 250 ninja
Old January 4th, 2013, 07:13 AM   #8
cuong-nutz
cuong-nutz's Avatar
I did a wet compression test and it brought compression up to 180 from 70-90 psi. Can't tell if cylinders are just glazed or rings stuck without pulling the head.
Old January 4th, 2013, 08:16 AM   #9
Racer x
Racer x's Avatar
What happen? I am going to guess valves. But pulling the head is a must at 80 psi anyhow. Get the head off. Pull the cams and check the valves for leakage with liquid poured into the chambers. Or pull the cams ad do a leak down test with the cams out carbs and exhaust off.
Old January 4th, 2013, 08:45 AM   #10
cuong-nutz
cuong-nutz's Avatar
Bike had a hard time starting after each session during a track day. It would take longer and longer each time until finally it wouldn't start.
More here: http://www.ninjette.org/forums/showthread.php?t=120502
Old January 4th, 2013, 09:49 AM   #11
lgk
did you get your oil analyzed again?
what were the results?
Old January 4th, 2013, 11:13 AM   #12
cuong-nutz
cuong-nutz's Avatar
I have 3 samples I need to send off. I was waiting for them to send me more containers, but I think I'll pick up some stuff here at my lab and use in lieu of theirs.
After the initial analysis, I changed my oil at 2k, and about the interval thereafter.
Old January 5th, 2013, 12:44 AM   #13
cuong-nutz
cuong-nutz's Avatar
http://www.jepistons.com/Products/292754.aspx
Looks doable. I'll have to get a quote from my machinist on how much it'll be for a bore and balance. Might as well do a PnP while I'm at it.
Old January 5th, 2013, 05:43 AM   #14
Racer x
Racer x's Avatar
Balance is not nessacary. I am spinning the 265 set up to 14000 rpm on nitrous with no problems.
My machenest charged me 100 dollars to do two blocks. He said he should have charged me three hundred but he likes me.
Old January 5th, 2013, 02:29 PM   #15
lgk
are they the same weight as stock?
Old January 7th, 2013, 09:16 AM   #16
cuong-nutz
cuong-nutz's Avatar
According to this post: http://www.ninjette.org/forums/showp...84&postcount=5
and JE Piston's : http://www.jepistons.com/Catalogs/Po...inja_250r.aspx
12.5:1 64mm is 148 grams vs 12:1 62mm 140 grams stock.
Old January 8th, 2013, 08:30 PM   #17
cuong-nutz
cuong-nutz's Avatar
@Racer x, do you have any experience or knowledge with wiseco pistons? I was searching on ebay and found a seller that sells them for $100 per piston kit. Saves me an extra 100 vs going with JE Pistons.
http://www.ebay.com/itm/Wiseco-Pisto...d48216&vxp=mtr
Old January 8th, 2013, 08:45 PM   #18
Racer x
Racer x's Avatar
They have been making pistons for a long time, but I have not used them.
Old January 8th, 2013, 09:04 PM   #19
lgk
Have not used wiseco on a bike before, but have used them on my eclipse.
In that case, they held up great.
Old January 9th, 2013, 08:27 AM   #20
cuong-nutz
cuong-nutz's Avatar
I'll most likely order it if I can rule out stuck piston rings.
Is there a DIY on piston rings? cookiebug79 1986 - 2007 Ninja 250R Tech Talk 33 April 22nd, 2015 01:17 PM
Stuck piston rings or glazed walls cuong-nutz General Motorcycling Discussion 14 March 5th, 2013 04:26 AM
[sportrider - tech] - Suzuki Bandit Secondary Butterflies and Oversized Tires | Ask t Ninjette Newsbot Motorcycling News 0 April 6th, 2011 08:50 PM
o-rings omnomnom flyinhawaiian 2008 - 2012 Ninja 250R Tech Talk 18 September 3rd, 2010 09:57 AM
Where to buy Piston Rings? iceman.kcmo 1986 - 2007 Ninja 250R Tech Talk 5 January 28th, 2010 11:59 AM
