Old January 16th, 2013, 02:42 PM   #1
cbzdel
Motorcycle(s): 2009 Ninja 250/2013 Ninja 300
Crank Case Vent Filter
After converting to a pod filter has anyone came up with a good option for the crank case vent?
I am looking for something that will be good in all weather riding.. Thought about getting a longer hose to extend it higher up so the side faring panels cover up the filter.
cbzdel is offline   Reply With Quote
Old January 16th, 2013, 02:45 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
@Jiggles
Old January 16th, 2013, 02:47 PM   #3
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I use a little K&N filter.
Worlds fastest 250 ninja
Old January 16th, 2013, 03:00 PM   #4
cbzdel
My plan was to use a little K&N filter or similar brand.. But is if I just stick it on top of the engine should I be worried about water?
Old January 16th, 2013, 03:08 PM   #5
lgk
i use the k&n filter.
you can buy covers for them, but i have a good hugger so never gets wet.
Old January 16th, 2013, 03:15 PM   #6
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
http://www.knfilters.com/vent.htm
I don't remember what size, half inch I think
AFM #676
Supersports are for n00bs
Old January 16th, 2013, 03:19 PM   #7
zip tie a napkin over the hole
Old January 16th, 2013, 03:22 PM   #8
Jiggles
Jiggles's Avatar
MOTM - Apr '13
This is just as good advice for condoms too
AFM #676
Old January 16th, 2013, 03:39 PM   #9
thats what the diaphram is, right? napkin ziptied over the hole....
Old January 16th, 2013, 11:07 PM   #10
cuong-nutz
cuong-nutz's Avatar
You can use those cheapy filters at the autoparts store.
HalfFast Racing Team
Old January 16th, 2013, 11:35 PM   #11
Racer x
Racer x's Avatar
You don't want to put a filter there. That goes to the exhaust ports. The valve cover gets blocked off.
Old January 16th, 2013, 11:52 PM   #12
cuong-nutz
cuong-nutz's Avatar
LOL. That would explain why it was so loud when I installed it
Old January 17th, 2013, 07:54 AM   #13
cbzdel
Thats what I am looking for
I will just do something simple like that and just monitor it the first few times in the rain. This is actaully going on my Ninja 300, but no one has really done this mod yet.. I figurered you guys would have an answer as well.
The top of the crank case on the 300 is different than the 250R.. My vent line comes out horizontal vs the 250R is vertical. (I am not talking about the rubber tube, the actual output)
Old January 17th, 2013, 08:32 AM   #14
Racer x
Racer x's Avatar
Can you take some photos of that on the 300?
The filter on this is really kinda useless. Air comes out of the crankcase most of the time. Only time air would go in is after you shut the engine off. As it cools down it would draw in a little.
Old January 17th, 2013, 08:37 AM   #15
cbzdel
I just dont want crap falling down in the hole.. Also looking for as much water protection as possible.. I live in WA and it RAINS here, and I ride in the rain all the time..
This pod filter conversion it freaking me about about riding in the rain but one I do and see the results I will be ok
I get get some pictures up, probably be tomorrow morning before it happens though..
Old January 17th, 2013, 08:47 AM   #16
Racer x
Racer x's Avatar
Also bugs will go into that hole and build a nest. Don't worry about pods in the rain. The side covers and tail get most of the water. You can add a hugger to the rear wheel. That keeps water and dirt from being thrown forward.
Old January 17th, 2013, 09:40 AM   #17
cbzdel
the side covers on the 300 are only about 1/2 the size of 250R side covers so the gap is alot larger but I guess I just like to worry
I am adding the GSXR rear shock as well so I need to hack up my undertail.. The 300 comes with a TINY hugger, it doesnt do much but I guess its better than nothing until something better comes out in the aftermarket world.. I know a 250R one would fit but I know there are a couple brands in the works so I would rather just wait to see what happens
Old January 18th, 2013, 02:13 PM   #18
mgentz
Board Member
run a hose up to the top of the motor or frame if your worried about water.
Old January 18th, 2013, 02:23 PM   #19
Racer x
Racer x's Avatar
That will work great.
Gas in Crank case sight? (The hole where you see 2T) gregoryl 1986 - 2007 Ninja 250R Tech Talk 18 October 10th, 2014 05:56 PM
White smoke from crank case breather mickheaven 2008 - 2012 Ninja 250R Tech Talk 8 September 14th, 2013 03:33 PM
crank case bolt size(generator cover) focus101 1986 - 2007 Ninja 250R Tech Talk 1 September 11th, 2013 06:10 PM
