#1 |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
Why you should change your coolant before 3 years
bike has 10 000km on it, 6000 miles. Kept undercover, and rarely ridden in rain. It is 2 years old. This is kawasaki factory coolant.
#2 |
white crap in the coolant means oil contamination, no? possible seal failure on the water pump or head gasket??? i suppose it could just be crap in the coolant. flush it all out and check again after 100 miles of riding... maybe check your oil too
#3 |
its not oil. Coolant develops white crap in it over time. I have my cylinder head off atm and it is one of the cleanest i've seen. This build up of white crap was in the bottom of the reserve tank.
#4 |
the green oil is motul v300. The best oil I've used, so clean.
#5 |
i think that happens when coolant boils.
might want to replace your radiator cap as well.
#6 |
Join Date: Jun 2012 Motorcycle(s): the cool ones Posts: 182
#7 |
Coolant in the reservoir is not completely air tight and is exposed to air. In a pressurized system it is not. The ethylene glycol breaks down over time and becomes oxidized. The greenish-gray crude is the result. Add some heat and it drys fast.
I changed my coolant @ 3 years 10 months and under 24k miles. The coolant in my reservoir didn't look like that because I switched it out in the summer of 2011. Something the manual does not mention doing. |
#8 | |
#9 |
Join Date: Nov 2011 Motorcycle(s): Ninja 250r Posts: 152
just changed mine too... 4½ year old , yup about time but thought old owner had done it since it was full serviced but nope... also white crap at the bottom of the reserve tank...
#10 |
I'll definitely be changing my coolant asap. I too still have the stock fluid in her:/
#11 |
It's so cheap i'll be doing it every year from now on. Not to mention easy, two bolts and a hose.
#12 |
L8APEX
Join Date: Nov 2011 Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org! Posts: 233
Use Engine Ice. Amazing stuff.
www.joemillersmoderngarage.com www.starr-cycle.com ***The most important concept of science isn't memorizing facts, it's observation of phenomena.*** ![]() |
#13 |
Board Member
#14 |
I use Engine Ice also. I don't have to drain it for winter. Best part? It's alright to use at Mid-Ohio
#15 |
Board Member
the orange stuff is propylene glyclol based and biodegradeable. If I go to the track I run the blue. I just don't like the blue due to the lack of freeze protection. Otherwise, I would leave it in all year.
Orange: http://www.liquidperformance.com/mot...nt-antifreeze/ Blue: http://www.liquidperformance.com/mot...acing-coolant/ |
#17 |
L8APEX
What happened to your vaccum line on the carb?!
#18 |
i chopped it with scissors. It was being a pain in the a**. So i taught the bastard a lesson. Don't need it anymore as i'm getting CR carbs.
I'm going to use engine ice too, the blue stuff. Just waiting for my head to be ported. |
#19 |
Join Date: Mar 2013 Motorcycle(s): 2006 ninja 250 Posts: 21
its just 2 bolt, the rad cap, the reservoir tank. there is no hose involved. if your draining via the lower hose than you wouldn't even need to use the bolts at all actually.
#20 |
#21 |
Join Date: Mar 2013 Motorcycle(s): 2012 Ninja 250 2013 GSXR 600 Posts: 96
#23 |
#24 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
#25 |
DIY: How To Change/Replace Your Coolant w/ Pictures | gilmorec61 | 2008 - 2012 Ninja 250R Tech Talk | 38 | March 31st, 2015 01:34 PM |
Attempting to change oil, huge accident happened with coolant. Kinda important. | Insane Pie | 2008 - 2012 Ninja 250R Tech Talk | 15 | December 3rd, 2014 03:30 PM |
[superbikeplanet.com] - Rossi: Two More Years! Two More Years! Two More Years! | Ninjette Newsbot | Motorcycling News | 0 | May 27th, 2014 12:40 PM |
2004 EX250 Leaking Coolant After Change | drc84 | 1986 - 2007 Ninja 250R Tech Talk | 9 | May 21st, 2014 03:11 PM |
[sportrider - latest stories] - 25 Years of World Superbike: "25 Exciting Years" | Ninjette Newsbot | Motorcycling News | 0 | May 1st, 2012 01:10 PM |
