Old February 13th, 2013, 06:39 AM   #1
tubarney
J&E Pistons- 1 ring or 2 ring
I'm purchasing a set of J&E pistons for the 250. Does anyone know the difference between the 1 ring vs 2 ring?
Also, Is the stock piston a 1 ring or 2?
Old February 13th, 2013, 06:49 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Stock piston is two ring. I have always used two ring. But I have no idea why they make one ring. If you call the JE tech line they will answer all your questions. I am curious to know.
Worlds fastest 250 ninja
Old February 13th, 2013, 07:34 PM   #3
tubarney
Turns out they make a 3 ring & 2 ring. No 1 ring.
J&E response: "Hi Bradley,
The part numbers you gave me indicate a 3 ring versus 2 ring question so I'll assume that's what you're looking for. The real difference between the two is that the 2 ring design should have less parasitic drag in the bore while the 3 ring design should provide more durability. If you're racing and need every available horsepower go with the 2 ringer, if not go with the 3 ringer.
Thank you for choosing JE Pistons!
Tj"
[sportrider - tech] - O-Ring vs.X-Ring and Patching Tires | Ask the Geek Ninjette Newsbot Motorcycling News 0 March 4th, 2014 11:00 AM
Where did this O-ring come from? Skippii 1986 - 2007 Ninja 250R Tech Talk 7 May 21st, 2013 10:16 PM
[sportrider - latest stories] - O-Ring vs.X-Ring and Patching Tires | Ask the Geek Ninjette Newsbot Motorcycling News 0 September 5th, 2012 05:20 PM
[topix.net] - MotoGP Twin Ring Motegi Facts & Figures Ninjette Newsbot Motorcycling News 0 September 29th, 2010 03:00 PM
Engagement ring ztrack157 Miscellaneous 30 March 8th, 2010 10:04 AM
