February 23rd, 2013, 03:53 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Scored Rear rotor
I put new pads on in the Fall and already one side of them is totally gone and before I knew it the rotor was scored.... Is it normal for the rear pads to wear out so much? I haven't even touched the front pads since buying the bike in July. Is it possible to re-use/machine this rotor or do I have to start looking for a replacement?
February 23rd, 2013, 04:04 PM | #2 | |
Bass Master General
And to replace or refinish would depend on how deep the scoring is. |
February 23rd, 2013, 04:26 PM | #3 |
There may be a couple of reasons your pads have worn out so fast.
1. cheap pads 2. brake drag Bike rotors normally do not get resurfaced or turned like car brake rotors. They are too thin. There are a few shops that specialize in grinding the rotors surface, but the rotor must be well within factory specs and not warped. Replacement is the usual fix. You may also want to get a Digital Thickness Gauge to see if your rotors are within spec. |
February 23rd, 2013, 04:52 PM | #4 |
Definitely cheap POS pads then. One thing gets fixed, another thing breaks!
February 24th, 2013, 12:19 PM | #5 |
Is it possible to get rust off a used rotor?
February 24th, 2013, 12:22 PM | #6 |
i just lightly sand them.
February 24th, 2013, 12:23 PM | #7 |
Bass Master General
If it's surface rust, yes, if it's just minimal superficial rust, i'd say simply pop it on and it'll come off while the pad is seating.
If you have access to, or know anybody with a medium blaster, a soft blast medium will take off the rust and refinish the disc perfectly. |
February 24th, 2013, 03:32 PM | #8 |
Brand and model?
Frozen pistons with dirt and grime can do that too.
February 24th, 2013, 04:07 PM | #9 |
WTB: brake rotor for rear | CZroe | Items Wanted | 3 | August 6th, 2011 08:20 PM |
WTB '08+ Rear Brake Rotor | smak | Items Wanted | 0 | March 20th, 2011 09:17 AM |
DIY: Rear Rotor Replacement | spooph | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 28th, 2011 12:57 PM |
