March 17th, 2013, 07:05 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only Posts: 150
Fuel indicator not reading full?
Fuel indicator does not go to full when tank is full, it does respond as the tank gets lower, though. Although its accuracy scares me, any ideas?
I did siphon gas out of the tank to empty, could that do anything?
http://www.1000rr.net/forums/showthread.php?t=90412 http://www.8thcivic.com/forums/ http://www.facebook.com/profile.php?id=1209877267 |
March 17th, 2013, 07:14 PM | #2 |
Boring is my middle name.
Join Date: Aug 2011 Motorcycle(s): '09 Ninja 250r Posts: 258
Most 250's have the same issue due to an inaccurate fuel sensor. My bike reads half full when it's actually full. Use your trip meter to gauge when you need to get gas.
March 17th, 2013, 07:26 PM | #3 |
No recalls etc for it if its so "common"
Any idea what part would need to be replaced so i could look it up on a fiche?
March 17th, 2013, 07:32 PM | #4 |
The Violet Vixen
Join Date: Jun 2012 Motorcycle(s): Perigee (250), Hotaru (250), Saturn (300), Pearl (300), Zero (S1000RR), Chibi (Z125), Xellos ('18 HP4R) Posts: A lot.
MOTM - Jun '16
In my case how I fill up has a big impact. If I put the gas pump in 'center line' and stop at cut off I actually have about half a gallon (ish) of capacity in the tank left that I can fill if I lift up the dispenser a bit and eyeball things (very carefully, of course). When I do the second my gauge tends to go completely full instead of the 3/4ths or so if I don't.
March 17th, 2013, 07:35 PM | #5 |
To fill the tank, you need to manually fill it. You can't let the handle automatically shut off. Fill it until it just touches or just covers the bottom of the filler neck. If you fill the tank while the bike is upright, you can squeeze in a little bit more.
March 17th, 2013, 07:44 PM | #6 |
I never let the handle shut off in any bike, always do it to the top through looking. Filter neck, not sure of that term, basically the metal rim or lip around the tank near the top?
March 17th, 2013, 09:29 PM | #7 |
Join Date: Dec 2012 Motorcycle(s): 2008 Ninja 250R Posts: 263
March 18th, 2013, 03:22 AM | #8 |
Join Date: Jun 2010 Motorcycle(s): 2008 Kawasaki Ninja 250R-J, 2005 Honda Superhawk VTR1000 Posts: 95
I find you can fill a bit over the fill-line, perhaps a 1/4 inch or so with no ill-effect. The fill-line is where there's a metal oval guard below the main metal ring that holds the hinged gas cap on. You can fill a tiny bit above that level pretty easily. I suspect the vacuum pressure hose would drip overfill gasoline out. My Honda Superhawk would pressurize if I went anything above the fill-guard and when parked (and maybe when riding) gasoline would drip out slowly, leaving a small spit-sized puddle underneath on the ground.
Fuel gauge is crap due to a resistor setting. On "E"mpty I still have 2 gallons left. It has to almost hit the bottom needle before I'm out. (proven) |
March 18th, 2013, 01:26 PM | #9 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
Mine never read full when I filled to the neck. Now, it only reads full. Useless piece of crap gauge.
March 18th, 2013, 01:28 PM | #10 |
There's a secondary fuel gauge. It's called the odometer.
March 18th, 2013, 01:36 PM | #11 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Dis.
I use the trip meter. My gauge reads about half when the tank is close to empty. I found that in the service manual that it operates on resistance and it has resistance values for both. In my case, if I could add about 50 ohms of resistance to the fuel sender, it should display properly. But being my lazy ass, I'll just stick with the trip meter as I always have. |
March 19th, 2013, 05:13 PM | #12 | |
March 19th, 2013, 05:16 PM | #13 |
March 19th, 2013, 05:16 PM | #14 |
Nobody likes broken anything. But crappy fuel gauges are a known issue on some of our 250's. First make sure you're actually filling it all the way up. Then if it's still really bugging you and the bike's under warranty, you can try for a replacement sender and/or gauge with your dealer. Most owners figure out which way the gauge errs, and move on to more important things. YMMV.
March 19th, 2013, 05:22 PM | #15 |
Sorry, I'll remove the sassy pants.
Just remember a broken fuel gauge isn't the end of the world. You have an odometer that's a great way to tell how much fuel is in the tank. You can also open the lid and physically look. I think the gas gauge on the newgen is dumb, especially when you consider how often they don't work properly. |
March 19th, 2013, 06:47 PM | #16 |
I love broken ****.
March 19th, 2013, 06:49 PM | #17 |
Broken **** adds character
March 19th, 2013, 08:11 PM | #18 |
lol i didnt call you broken ****, i called the fuel pump broken ****
Look I got the info I was looking for, Common problem on these models. I could see if kawasaki would do anything since it has 1500 miles but probably not. Next question is what part would fix this on the fiche, but the part is probably 200-300+
March 19th, 2013, 08:57 PM | #19 |
and if this is the correct part/fuel reader its only $57 http://www.cheapcycleparts.com/model...2449-fuel-tank
so I wonder if the problem is at the reader or on the gauge :\
March 19th, 2013, 09:56 PM | #20 |
Buy a cheap gauge set off ebay and see if that one works or not. That will tell you if it's the gauge or not.
Other option: fill the tank completely. Take off the plastic from the gauges. Pull off the needle, and re-install it so it's on the full marker with what you know is a full tank. Basically calibrate it. |
Koso fuel indicator + winter = ?? | NevadaWolf | 2008 - 2012 Ninja 250R Tech Talk | 7 | October 21st, 2013 01:16 PM |
Fuel gauge stuck at full | mgorven | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 27th, 2013 02:42 PM |
Pic of Speed reading with sprocket changes and full Yoshi exhaust and Jet kits | Hitman | Ninjettes At Speed | 3 | August 14th, 2012 02:56 PM |
Fuel Tank never get full? | Brently7785 | 2008 - 2012 Ninja 250R Tech Talk | 17 | August 30th, 2011 03:30 PM |
Evap line full of fuel | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 10 | June 18th, 2010 07:44 PM |
