Old April 13th, 2013, 01:07 PM   #1
AGFE0914
AGFE0914's Avatar
Red face Throttle doesn't "snap back"
Hello people,
My throttle doesn't go back if I let it go. Excuse my poor terminology. Anybody else have this problem?
I am having trouble using the search engine on my iPod right now(left iPad at work) so if anyone has a thread that already discusses this can u lead me there?
Also, is this dangerous?
Thanks,
Anju
AGFE0914 is offline   Reply With Quote
Old April 13th, 2013, 01:50 PM   #2
mgentz
Board Member
Dangerous yes.
Causes:
Rusty/dirty cables
Binding
Weak spring
Old April 13th, 2013, 01:52 PM   #3
AGFE0914
AGFE0914's Avatar
Fixable?
Old April 13th, 2013, 02:04 PM   #4
Joshorilla
Bass Master General
Joshorilla's Avatar
You probably need a new return spring, or it may have come loose. Take it to a garage, they will fix it and it shouldn't be expensive.
Old April 13th, 2013, 02:26 PM   #5
Clean/lube the cable. If that doesn't work, replace the cable. If that still doesn't work, replace the return spring.
I'm betting it will be fine once you clean/lube the cable. If you notice any damage to the cable while you're cleaning/lubing it, replace it.
Old April 13th, 2013, 03:03 PM   #6
AGFE0914
AGFE0914's Avatar
Thanks bikes in shop til mon-Tuesday ill be sure they fix this
Old April 13th, 2013, 06:37 PM   #7
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Better make sure you tell them.
Old April 13th, 2013, 06:59 PM   #8
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
It could also be as simple as the grip touching the bar end. Try peeling back the outside edge of it (at the end of the handlebar) and twisting and releasing.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old April 13th, 2013, 07:46 PM   #9
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
I had that problem when i put my grips on. Did just that and it was all better. Hopefully its something that simple for you!
Old April 13th, 2013, 09:36 PM   #10
AGFE0914
AGFE0914's Avatar
Calling them as soon as they open
On another note they got my bike to start without cleaning carbs so no charge there. Just new tires, oil change and now throttle.
Old April 13th, 2013, 09:38 PM   #11
AGFE0914
AGFE0914's Avatar
Bike is at shop but can you clarify what you mean? I was playing with the throttle today and it was sticky last year but now, I liter equally have to bring the throttle back up it won't on its own, last year it did just at a very slow motion speed.
Old April 13th, 2013, 09:55 PM   #12
AGFE0914
AGFE0914's Avatar
The people at the shop who have my bike will let me know if this is the case
I'll keep u all posted (not that anyone cares lol)
Old April 13th, 2013, 11:09 PM   #13
Trailerboy531
Not sure why your bike is in for oil change.... they overcharge for something you can do on your own very easily. As for what I mean uh... The edge of the grip sometimes goes off of the edge of the throttle tube and hits the bar end which causes it to drag and slows the throttle return. If it's far enough off it can not return all together. If you roll the edge of the grip inward so that you can see the throttle tube and then twist it and let go it may return. If it does you just have to reposition your grip or trim the edge or something.
CVMA #531
Old April 13th, 2013, 11:31 PM   #14
chsonnu
Motorcycle(s): 2009 kawasaki Ninja 250R, 2001 Suzuki GS500
You could open up the throttle housing to see if the pull and push cables are where they're supposed to be. It's just two screws to open up the housing.
chsonnu is offline   Reply With Quote
Old April 14th, 2013, 07:44 AM   #15
CC Cowboy
CC Cowboy's Avatar
Hello people,
Thanks,
Anju
Are you sure you don't have the cruise control on?
Old April 15th, 2013, 05:34 PM   #16
AGFE0914
AGFE0914's Avatar
Hi Max,
You Were right about the throttle pealed it back and now I'm good, also didn't pay for oil change!!!
New tires and inspection done
Thanks much
Old April 15th, 2013, 05:58 PM   #17
Trailerboy531
glad it was simple!
CVMA #531
Old April 15th, 2013, 06:08 PM   #18
AGFE0914
AGFE0914's Avatar
I got my baby back baby back baby back!
Old April 15th, 2013, 06:27 PM   #19
CC Cowboy
CC Cowboy's Avatar
What was the starting problem?
Old April 15th, 2013, 07:24 PM   #20
AGFE0914
AGFE0914's Avatar
Carbs got a good cleansing.
Old April 15th, 2013, 08:15 PM   #21
sLick415
My condolences to your fellow Bostonians..
sLick415 is offline   Reply With Quote
Old April 15th, 2013, 08:54 PM   #22
AGFE0914
AGFE0914's Avatar
It's a very sad day for Boston.
[superbikeplanet.com] - Back in Stock & Shipping: "Roberts" and "Lawson" Yamaha Art P Ninjette Newsbot Motorcycling News 0 March 13th, 2015 01:40 PM
[superbikeplanet.com] - Back in Stock & Shipping For Christmas: "Roberts" and "Lawson Ninjette Newsbot Motorcycling News 0 December 13th, 2014 06:30 AM
Pregen went "pop" and now doesn't accelerate past 25-30 mph skucera 1986 - 2007 Ninja 250R Tech Talk 13 August 12th, 2013 02:41 PM
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl Ninjette Newsbot Motorcycling News 0 August 16th, 2012 04:30 PM
[twisted throttle] - Chris "Teach" McNeil putting the "Adventure" into Adventure Bike Ninjette Newsbot Motorcycling News 0 January 6th, 2012 11:00 AM
