Old April 28th, 2013, 11:41 PM   #1
hexstylee
Motorcycle(s): 2013 636, 2011 250R
Bel Ray Chain Lube
Bel Ray super chain lube, cleaned off all the excess original grease off the original chain, which has about 1300 miles (was lubed at required times). Again used some degreaser and took off everything left it bare bones. This stuff makes it pratically oem again. comes out watery so i was like wtf this is cheap but then it dries out sticky. Amazed !
hexstylee is offline   Reply With Quote
Old April 29th, 2013, 05:13 AM   #2
Bones85
What kind of degreaser did you use? I've been using DuPont Motorcycle Degreaser and a grunge brush but I still can't get the chain to come out looking new.
Bones85 is offline   Reply With Quote
Old April 29th, 2013, 11:17 AM   #3
hexstylee
I used some home depot dregreaser its the inexpensive one in a matte clear bottle around a dollar or two. Works good doesnt stain. I used it on the chain along with an old tooth brushed got the job done good.
The way I did it is I started cleaning the chain before I washed the bike, degreaser does a better job. Be generous with it. I also use it in the wheels gets the brake dust and oily residue off.
Old April 29th, 2013, 11:34 AM   #4
1LoneWolf
1LoneWolf's Avatar
I use WD40 to clean the chain and it gets it looking brand new every time, then I lube with PJ1.
1LoneWolf is offline   Reply With Quote
Old April 29th, 2013, 04:45 PM   #5
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
I use the same two things and my chain looks new - even use the Chain Saver with great results.
Got some Bel Ray as a present, but never used it before returning.
Anyone can go fast in a straight line....
Once you go track, you never go back....
austexjg is offline   Reply With Quote
Old April 29th, 2013, 05:06 PM   #6
hexstylee
i was using maxima clear but wasnt doing good enough of a job. From the present the bel ray looks really good i was impressed will see once i get some miles on it and check out how it holds up.
Old April 29th, 2013, 05:18 PM   #7
sammy5001
Motorcycle(s): Kawasaki Ninja 300 ABS SE
Kerosene + PJ1. Cheap and works everytime. I gotta stay cheap since I have to clean and lube every week...doing 500 miles a week with commute.
sammy5001 is offline   Reply With Quote
[roadracingworld.com] - Sponsorship Opportunity With Bel-Ray Ninjette Newsbot Motorcycling News 0 October 3rd, 2012 11:10 PM
Chain Lube... What Do You Use and Why?? kkim General Motorcycling Discussion 75 June 3rd, 2012 05:04 PM
[sportrider - latest stories] - Bel-Ray Expands Innovative Lubricant Advisor on Bel-R Ninjette Newsbot Motorcycling News 0 March 15th, 2012 03:10 PM
[roadracingworld.com] - Sponsorship Opportunity With Bel-Ray Ninjette Newsbot Motorcycling News 0 August 19th, 2011 10:10 PM
[webbikeworld.com] - DuPont Chain Saver Motorcycle Chain Lube Review Ninjette Newsbot Motorcycling News 0 May 18th, 2009 09:50 PM
