May 4th, 2013, 08:53 AM | #1 |
MoVal's only ninjette :(
Join Date: Jul 2012 Motorcycle(s): 2012 Ninja 250r SE Black with a dash of yellow Posts: 120
What is this called?
I don't have my manual yet, but what is that cover called on the swing arm that has the bolt and two nuts that is used to adjust the alignment of the rear wheel? Hopefully I described that right.
Apparently, mine came off sometime in the past week. I only noticed this morning before my ride to work this morning. Gotta call my dealership to get that part, hopefully it's not one of those stupidly priced small parts. Thanks in advance.
Success is the ability to go from one failure to the next, without any loss of enthusiasm- |
May 4th, 2013, 09:03 AM | #2 |
Join Date: Jun 2012 Motorcycle(s): 2008 Ninja 250, 2009 Concours 14 Posts: 130
Part 11012? It's a Cap, Chain Adjuster, Bl. You're looking at a bit over $20 from RonAyers, or slightly more from the dealer.
Sounds like the nuts weren't tightened against each other, and when the rear one vibrated loose, everything else went with it. As long as the axle bolt and nut are tightened down well, you should 'technically' still be okay to ride it, but it's not something I'd do. Probably better to park it until the parts come in.
Igitur qui desiderat pacem, praeparat bellum... |
May 4th, 2013, 09:31 AM | #3 | |
Thanks again.
May 4th, 2013, 09:35 AM | #4 |
got it on order for $20.11. Thanks again.
May 4th, 2013, 10:55 AM | #5 |
Board Member
feel lucky nothing bad happened. a lot of things go bad when those are not tightened down.
May 4th, 2013, 11:22 AM | #6 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
I got both sides on eBay for $10 with free shipping. Don't be afraid to check eBay for these things. For this particular item you'd search "Ninja 250 chain adjuster"
CVMA #531 |
May 4th, 2013, 02:08 PM | #7 | |
Two valuable lessons learned today: 1) When at a red light, stop singing at the top of your lungs with the visor cracked open. 2) Check eBay for parts. thanks, it's been a productive day.
May 4th, 2013, 02:35 PM | #8 |
Whenever you need new parts ask yourself this question "Does it need to be new?"
Yes - Go to a parts dealer No - eBay and Craigslist
CVMA #531 |
June 3rd, 2013, 08:45 AM | #9 |
Join Date: Oct 2011 Motorcycle(s): 2004 Ninja 250F Posts: 308
I think you've got that wrong. When at a red light, make sure to check for nearby cars that will notice your singing. If spotted, begin drum solo and/or air guitar accompaniment.
What is this thing called? | Ninja Bob | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 9th, 2014 04:57 AM |
what are these called? | Finesse | 1986 - 2007 Ninja 250R Tech Talk | 11 | July 21st, 2014 08:55 PM |
First Post! - What is this called? Where can I get it? | Brian | 2008 - 2012 Ninja 250R Tech Talk | 12 | November 28th, 2013 09:13 AM |
What is this called? | zCasanova | 2008 - 2012 Ninja 250R Farkles | 5 | April 4th, 2012 03:20 AM |
what's that part called? | mz_twee | General Motorcycling Discussion | 2 | April 2nd, 2012 11:40 PM |
